1. rugved parte's Avatar
    Hi android central.....
    I have got Motorola one power....and there is very low signal level on it.....I tried resetting my phone as Motorola instructed me....but it didn't help.....I told them to fix network but no answer from them......the problem is there from the first day.... when I bought this phone....but when I change the network mode in 2G....the network gets full....again in 3G the phone signal level gets full.....but when I turn on 4G.....the signal is low.....tell me it's a bug or not...if there is bug.....then please fix it..... Motorola one power...has many users who have this bug.....please fix it.....guys.....
    09-01-2019 09:44 AM
  2. Rukbat's Avatar
    It's a carrier that has a low 4G signal level where you are. Motorola has nothing to do with that, you're just using the wrong carrier.
    We don't fix phones. We're not Motorola and we're not your carrier, we're just a forum that helps people with phones.
    rugved parte likes this.
    09-01-2019 02:04 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Which carrier are you on, and what's the exact model number of the phone? Are you certain your phone supports your carrier's network bands?
    Also, if you have a case on, see if taking it off helps.
    09-01-2019 10:00 PM
  4. rugved parte's Avatar
    I'm using Airtel and Jio and the model number is..... XT1942-2
    09-01-2019 10:50 PM
  5. B. Diddy's Avatar
    Looks like the phone should support those carriers' bands. Do you have a case on?
    Also, go to the Settings>Mobile Networks>Preferred Network Type ​menu (if available). What's it set to?
    09-01-2019 11:20 PM
  6. rugved parte's Avatar
    No....now they have solved the case.... preferred network type is 4g......is there a bug in 4g..,.. will getting network improvement update can fix 4g
    09-02-2019 02:13 AM
  7. B. Diddy's Avatar
    Sorry, what do you mean that "they have solved the case"?
    Sometimes, certain phone models will have worse cellular radios than others, so their reception is worse. Or it might just be a defect with your particular phone. Have you told Lenovo that the problem persists? Try asking them for a warranty replacement.
    09-02-2019 03:43 AM
  8. rugved parte's Avatar
    I tried asking for warranty replacement..... But they say there is no option for us to replace.....
    09-02-2019 04:06 AM
  9. rugved parte's Avatar
    Today they mail me and said......
    Dear Rugved,
    Greetings from Lenovo-Motorola!
    I hope you are having a good day. If you are facing the issue even after resetting the device, kindly visit the service centre as informed earlier so the engineers at the service centre can diagnose the device and help you further.
    We will also consider your feedback regarding the update.
    Thanks & Regards,
    Lohit
    Lenovo-Motorola Smartphones
    09-02-2019 04:12 AM
  10. rugved parte's Avatar
    They will contact me.... tomorrow....regarding the update.....sir will they can fix 4G bugs with an update......?
    09-02-2019 04:15 AM
  11. rugved parte's Avatar
    Hi....
    But when I turn on 2G and 4G.....the network gets full.... can you explain the problem......?
    09-02-2019 01:17 PM
  12. B. Diddy's Avatar
    It sounds like they want you to bring the phone to a service center, so it might be worth doing that and asking the technician in person about warranty coverage (assuming there's been no damage to the phone).
    I have no idea if they can fix 4G bugs with an update, because it's not clear what's causing the poor reception (hardware vs firmware). All you can do is update and see if it works better afterwards.
    09-02-2019 09:48 PM
  13. rugved parte's Avatar
    What if it's about firmware?
    09-09-2019 03:12 AM
  14. B. Diddy's Avatar
    If it's firmware corruption, then reinstalling the firmware might help. But if it's a bug in the firmware, then you'd have to hope Lenovo pushes a patch that fixes it. Sorry, but not much more I can say about that.
    09-09-2019 11:25 PM
  1. Your phone's temperature is too low...
    By Paladin in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-03-2019, 11:09 PM
  2. Does an unlocked phone have and signal differences on verizon?
    By miyanc in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-01-2019, 09:08 PM
  3. My samsung level up headphones will not play audio for media on my Samsung s7???
    Last Post: 08-27-2019, 11:01 AM
  4. LG Escape 3 only gets 2G signal
    Last Post: 08-25-2019, 10:01 PM
  5. battery level indicator like Energy bar
    By Borarjti in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 08:17 PM
