07-29-2020 04:07 PM
39 12
tools
  1. mustang7757's Avatar
    Example on mine 3 dots upper right corner Phone randomly goes straight to Voicemail, and no incoming texts.-screenshot_20200709-235110_settings.jpg
    07-09-2020 10:53 PM
  2. lemon40's Avatar
    A few months ago I did that APN reset after I wasn't getting MMS text messages from IOS properly and that fixed it. So I just did that, let's hope it helps.
    -d
    mustang7757 likes this.
    07-09-2020 11:05 PM
  3. mustang7757's Avatar
    07-09-2020 11:06 PM
  4. lemon40's Avatar
    Okay, was testing out the phone randomly this morning and it's been fine. But just this last time, straight to voicemail again, so I turned off wifi and once again, it worked just fine afterwards. I think my next step is to just do a factory restore. I was hoping to not have to go that far, but I don't know what else to do at this point.
    -d
    07-10-2020 11:25 AM
  5. mustang7757's Avatar
    -d
    You can, just don't restore anything start fresh see how it will be for a day or 2 then restore
    07-10-2020 11:28 AM
  6. lemon40's Avatar
    Yes, i meant factory reset, not restore.
    It will probably be a few days before I can get around to doing that though.
    -d
    07-10-2020 11:57 AM
  7. mustang7757's Avatar
    -d
    Ok , let us know!
    07-10-2020 11:59 AM
  8. lemon40's Avatar
    Okay, so another update.
    I never did get around to wiping the phone and starting over. But a couple of days ago I got a system update to the July 2020 updates.
    So far whether wifi is on or not, I haven't had it go straight to voicemail. So crossing my fingers that whatever the system update was, it fixed the issue.
    If it comes back again, I'll be sure to post.
    -d
    07-22-2020 10:58 AM
  9. mustang7757's Avatar
    -d
    Oh great , thanks for the update
    07-22-2020 11:19 AM
  10. lemon40's Avatar
    I spoke too soon. It came back. Same thing. Seems to happen more when I'm at work. If that's the case then maybe it's some weird signal thing at work, but I still usually have a strong signal, so it shouldn't do that. Plus it's still bizarre that toggling wifi fixes it. I guess I'll try factory resetting the phone.
    -d
    kbz1960 likes this.
    07-23-2020 02:59 PM
  11. mustang7757's Avatar
    -d
    Came back
    Ok try that , let's see if it will correct this .
    07-23-2020 03:00 PM
  12. lemon40's Avatar
    So now after a few days it will only happen at my work. So if this is the only place it happens, I'm not that concerned anymore as anyone who would actually need to call me can call my work number. Also, so far today it's been fine as I've been randomly testing.
    Strange that with a decent signal though at work it happens. I wonder if it has something to do with the tower over here, but then again it makes no sense that toggling wifi fixes it. *shrug*
    -d
    07-29-2020 11:27 AM
  13. B. Diddy's Avatar
    It may have to do with poor signal at work, which is a relatively common issue. Are you using wi-fi calling at work?
    07-29-2020 11:41 AM
  14. lemon40's Avatar
    I have no option for wifi calling on my phone and I can't connect my personal phone to the wifi. My signal is medium to strong 4G LTE, so if it's the signal, there's something wonky and it's not because of the strength.
    -d
    07-29-2020 04:07 PM
39 12
  1. Replies: 9
    Last Post: 07-03-2020, 04:16 PM
  2. How can I Disable cloud storage on my Android phone?
    Last Post: 06-04-2020, 03:02 AM
  3. Is "shell" malware? It has access to SMS, etc.
    By Helen95 in forum General Help and How To
    Last Post: 06-03-2020, 01:21 PM
  4. Is "shell" malware? It has access to SMS, etc.
    By Helen95 in forum Android Apps
    Last Post: 06-03-2020, 12:52 PM
