Hmm, I'm running out of ideas. A factory reset might be the next step.
Is Visual Voicemail preinstalled, or can you uninstall that temporarily?
Anyone recommend reset network in settings? Just skimming through the thread .
You also try resetting to default APN ?Yes, that was the last thing I tried. The 611 lady recommend that and it didn't seem to work.
Yes, I could possibly have a lemon. LOL
It looks like I could delete visual voicemail, I won't try that now because I have some messages I need to keep, but I will see if that does anything, I'm guessing it won't, but who knows.
I'm hoping I get the July updates soon and that fixes it, but considering the June one didn't, it's doubtful.
-d
You can, just don't restore anything start fresh see how it will be for a day or 2 then restoreOkay, was testing out the phone randomly this morning and it's been fine. But just this last time, straight to voicemail again, so I turned off wifi and once again, it worked just fine afterwards. I think my next step is to just do a factory restore. I was hoping to not have to go that far, but I don't know what else to do at this point.
-d
Ok , let us know!Yes, i meant factory reset, not restore.
It will probably be a few days before I can get around to doing that though.
-d
Oh great , thanks for the updateOkay, so another update.
I never did get around to wiping the phone and starting over. But a couple of days ago I got a system update to the July 2020 updates.
So far whether wifi is on or not, I haven't had it go straight to voicemail. So crossing my fingers that whatever the system update was, it fixed the issue.
If it comes back again, I'll be sure to post.
-d
Came backI spoke too soon. It came back. Same thing. Seems to happen more when I'm at work. If that's the case then maybe it's some weird signal thing at work, but I still usually have a strong signal, so it shouldn't do that. Plus it's still bizarre that toggling wifi fixes it. I guess I'll try factory resetting the phone.
-d
