Ive been reading and saw that the Triumph's signal is pretty lackluster when compared to the V, but how bad is it really?
In my experience, coming from a PRL hacked OV, the PRL hacked MT definitely has a better signal. There are still the occasional data receptivity issues, but those aren't specific to the MT, the OV had just the same amount of them.Ive been reading and saw that the Triumph's signal is pretty lackluster when compared to the V, but how bad is it really?
The 800 Mhz band is used to roam onto VZW's network, which you cant do with on VM service anyways. Both devices only use 1900mhz afaik...
Ah, ok. Thanks for the info. I guess the moderator from Motorola was unaware of that too because she seemed to think that it was part of the problem.
It's weird that most of the phones for VM have dual antennas and seem to get decent signal though. I mean, why would they pack that second antenna in the OV? In case of future expansion maybe?
Oh well, I guess it's just a coincidence that the MT with a single antenna gets worse reception. I just hope they figure out a way to fix it because right now it's ruining an otherwise pretty nice phone.
