1. JkdJedi's Avatar
    OK, I know we all have this in our phones already and your thinking your late dude, but I had to share a DETAIL that I'm thinking most don't know. see if you can find it in the vid and let me know what you think, HINT: /DATA
    09-20-2011 07:54 PM
  2. miamifin33's Avatar
    Sorry for being naive, but the X comes pre loaded with this script?
    09-21-2011 06:52 PM
  3. jerseyboy357's Avatar
    No no its a script that came out a while back that a good number of us installed. That vid link shows off some of the detailed powers possible having in your device.
    09-21-2011 07:38 PM
  4. miamifin33's Avatar
    Recommended to use?
    09-21-2011 08:30 PM
  5. jerseyboy357's Avatar
    After watching the video, its really up to you. Android has so many memory processes it doesnt hurt. I've had it in the past, with minimal to no notice of change, which can be good. Havent re-installed since I jumped on the MIUI GB. I need to re-watch that link so I know wtf Jedi is taking about,lol guess I need a few more beers in me!
    09-21-2011 08:42 PM
  6. jerseyboy357's Avatar
    im getting an error while following the directions in the vid. After long pressing the zip to open it and selecting Run as Root, the text tells me "1: Syntax Error: "(" unexpected"
    I havent gone past that part in the video yet, Jedi, share your jedi powers with us, what happened for you?
    09-21-2011 09:05 PM
  7. miamifin33's Avatar
    So Jedi, what's the verdict?
    09-22-2011 09:38 AM
  8. jerseyboy357's Avatar
    Got mine to work. Had to extract using Root Explorer then Ran as root in Script manager. Boosh.
    09-22-2011 12:16 PM
  9. miamifin33's Avatar
    Notice any difference?
    09-22-2011 12:46 PM
  10. jerseyboy357's Avatar
    Yes. My battery is still at 50 2hrs later. Thats after moderate use and being in + the whole time. I know the balanced settings are lower so I can consider this undervolted and sped up at the same time. Like I said, BOOSH!
    09-22-2011 02:16 PM
