1. D2TSHR1439's Avatar
    When I was on 2.2 I got this same message, now I am back on 2.1 . Has anyone else ever got this image or know what may be causing it??
    Thanks Nick
    09-20-2010 04:09 PM
  2. D2TSHR1439's Avatar
    Forgot to mention. When I click on a ROM to load, it restarts but then boots normal. Droid screen then the Eye. No Install Screen at all.
    09-20-2010 04:10 PM
  3. Adiliyo's Avatar
    you do have the bootstrap recovery installed right?
    09-20-2010 05:31 PM
  4. tntdroid's Avatar
    Deff need that bootstrapper. Without it you will have those issues.
    Sent from my DROIDX using Tapatalk
    09-20-2010 05:32 PM
  5. D2TSHR1439's Avatar
    Yes, and either nothing happens and it loads normal or I get the same error.
    09-20-2010 05:47 PM
  6. JkdJedi's Avatar
    Do you still have root?
    09-20-2010 08:05 PM
  7. D2TSHR1439's Avatar
    Yup, still have root.
    09-21-2010 07:19 AM
  8. Adiliyo's Avatar
    just to clarify, you have gone either to the market or here to download the bootstrap recovery and then installed the apk and loaded the bootstrap before trying to use rom manager to boot into clockwork right?
    if you have, did you try to run the bootstrap application again? if not, i'd try that too
    D2TSHR1439 likes this.
    09-21-2010 09:46 AM
  9. powermanaf's Avatar
    I was also having this problem. It was unclear to me that after downloading the Droid X Bootstrapper I had to open the program and click "Bootstrap Recovery".
    09-21-2010 01:30 PM
  10. D2TSHR1439's Avatar
    Got it working! You, sir, are the man!
    09-21-2010 10:32 PM
