1. trip4219's Avatar
    Ok, so my phone failed to update a few times with the OTA today...i figured the best thing to do was to flash the .sbf file and try again...apparently that was a HUGE mistake and my phone now reads:
    Bootloader
    30.03
    Err:A5,70,70,00,1F
    MEM_MAP Blank
    Service Req'd
    Battery OK
    OK to Program
    Connect USB
    Data Cable
    can anyone help me out? i desperately need the phone working again
    09-22-2010 07:53 PM
  2. doctorlove316's Avatar
    So you actually ran the 2.2 OTA update successfully and then tried to flash the .sbf?
    09-22-2010 07:57 PM
  3. trip4219's Avatar
    it said that it failed to install, so i figured i better sbf to stock and then try again...so i don't know what the heck happened, but when i sbf'd that's what happened...i'm pretty sure i'm screwed, but i was hoping there maybe some hope
    09-22-2010 08:04 PM
  4. doctorlove316's Avatar
    Read this, the guy was in the same boat, same error messages and everything. Ended up having to go into VZW and play dumb to get a new phone.
    DX Completely Bricked, SBF Wont Help - xda-developers
    trip4219 likes this.
    09-22-2010 08:06 PM
  5. trip4219's Avatar
    thanks for the link...looks like i'm in the same boat as a number of others...
    if a MOD see's this, feel free to delete
    09-22-2010 08:36 PM
  6. Flawson's Avatar
    So, just to be crystal clear, you tried the ota, it said "failed to install", and then you flashed sbf...right? As in, it updated your bootloader but not your os version, then when you flashed, it bricked?
    Is this correct?
    Sent from my DROIDX using Tapatalk
    09-22-2010 09:51 PM
  7. trip4219's Avatar
    yes, as best i can tell thats what must have happened
    09-22-2010 09:59 PM
  8. Flawson's Avatar
    Damn. I'm getting two different outcomes from flashing sbf from two people with about the same problem as me.
    At least it's still alive, but I have got to figure out what's wrong, at this point I am looking st being stuck with my factory reset 2.1 for quite a while...
    09-22-2010 10:04 PM
  9. derpudel's Avatar
    To be safe, don't do it (try to use the sbf to go backwards from 2.2 OTA)...have some patience. Better to be on 2.1 and have a phone that is usable, than to have one that is DOA.
    In time, there may be a way to do all this, but all of us must wait this out...and see how this plays out.
    I'm sitting on 2.1 still...and happy about it. I actually don't want to upgrade to 2.2 after hearing all the issues with it. I have a completely working phone right now, with NO issues...there just isn't a compelling reason to upgrade.
    09-22-2010 10:56 PM
  10. Flawson's Avatar
    Okay, I figured out the answer to MY particular problem. Posted in my "havent totally screwed up yet" thread
    09-22-2010 10:58 PM
