1. Callindril's Avatar
    Got everything setup and running with the 2.3.15 leak, and works great, but seems every time I try to use the Bootstrap app to go into recovery, it reboots the phone fine, but always hangs/locks on the "M" screen...Ive let it sit there for 20 min at a time, and it doesn't do anything...
    If I do a battery pull during the "M"-Hang, it will sometimes reboot fine and run normally, sometimes boot into Recovery (Like I wanted it too), and sometimes will go back to the "M"-Hang, and require another battery pull...
    Using Rom Manager to reboot and load something new does the same thing...
    Is this normal, or is something not right on my installation?
    Thanks
    Cal
    09-30-2010 11:56 AM
  2. doctorlove316's Avatar
    I would try to go into ROM Manager and flash the clockwork recovery and then try again. Should work.
    09-30-2010 12:12 PM
  3. Adiliyo's Avatar
    that doesn't seem right
    i would try wiping data and cache, it seemed to help when mine did that
    09-30-2010 12:13 PM
  4. JkdJedi's Avatar
    +1 On the wiping, do a back up first!
    09-30-2010 09:23 PM
