1. DarkS3ct0r's Avatar
    Is there anyway to change this on the X?
    I find it even annoying it goes by 10% increments.
    I am rooted as well, if that helps my chances of doing something like this.
    10-29-2010 02:33 AM
  2. xliderider's Avatar
    The app Gauge Battery Widget can put an icon in your notification bar with the percentage of battery left. You don't even need to have the widget on your screen. Unfortunately, the increments are still by 10s.
    DarkS3ct0r likes this.
    10-29-2010 03:49 AM
  3. moosc's Avatar
    It is a bug in the Droid x software. There are threads around the area that states Motorola is aware of it.
    10-29-2010 07:19 AM
  4. DarkS3ct0r's Avatar
    I do currently have Battery Indicator Pro, and that works, just still does the 10% thing.
    Thanks for the info, I hope a fix for it comes out with 2.3.
    10-29-2010 01:12 PM
