Thank you so much for your help man!
Did you get it figured out? You went through the worse so you should be a pro now...like the saying goes..practice makes perfect.
@ Cyber Warrior
Your guide to rooting is fantastic. I am a noob to rooting android phones but my first went flawlessly thanks to your guide. I did have a couple of questions though.
1-Using Titanium Backup Pro is it posible to make a multiple backups? For example making a backup of the current state of the phone now, then do a Factory Reset and make a 2nd backup in that state without erasing the first backup?
2-To install a custom rom using method 2 (Rom Manager) the youtube video says to check both boxes after selecting a rom (backup existing rom and wipe data and cache).
A) Does backup existing rom save the state of your phone so you can install the old rom (stock)
B) Does wipe data & cache affect your sd card at all?
C) If you try a rom and don't like it how do you return to the original rooted state?
If there is an for this just link please...
I am using the free rom manager, flash to clockworkmod recovery, select my droid x and hit okay. Phone says it has flashed. I then go to install from sd card, select apex zip and phone then reboots into current (stock) rom. What am I missimg? A factory reset somewhere? Help is appreciated, thanks!
I got bootstrapper, ran it, then ran rom manager...overkill? possibly, but I got the rom installed and have been geeking with it, some differences from the stock that I'll have to get used to (especially with email notification (???)) but love some of the stuff that stock doesn't have...and boy, is it snappy!
I used z4root tonight on my Droid X, and now need to know what to do with a rooted phone. What apps do I need, what ROMs for the Droid X are recommended. I did download Titanium Backup and followed the initial backup, along with freezing a couple of annoying apps (City ID, Blockbuster). I also downloand ROM Manager to hopefully make my experience a little easier. However, I am new to the entire process and need any and all guidance that the rooting vetrans in this forum can provide. Depending on how well the experience goes with the phone, I will be building up the nerve to root my NOOK next. Thanks in advance.
I've been rockin' the OG Droid til last wk. Decided to "upgrade" to the DX after killing my OG... RIP, buddy...
I was running a UD ROM on there and am familiar with rooting / loading ROMs.
I've rooted my DX and am wanting to load either Liberty or UD for my OS by using ROM Mgr. Problem is this: Thru RM, I tell my phone to boot into recovery, or install a new ROM from my card. The Super User Perm is granted. My phone reboots with normal DX annimations. ROM Mgr doesn't seem to be doing it's job and I'm not sure why...
Any ideas / suggestions are appreciated & I TYIA
-GNRPowdeR
EDIT: Hadn't loaded / purchased Bootstrapper... RM seems to be working, now...
