1. geeforce1's Avatar
    I am having trouble installing any roms...here are my specs
    Droid X
    Rooted
    Froyo 2.2.1
    Verizon system: 2.3.340
    I am using Rom Manager and have flashed backup with clockwork. The problem is that every rom I download or install it just reboots and then nothing happens...Am I doing something wrong?
    02-17-2011 01:18 AM
  2. droidxixis's Avatar
    Are you wiping the phone before you try to install the new ROM? That could mess things up if you don't. (make sure you make a backup of your current ROM first)
    One other thing...I recommend getting Droid X Bootstrapper to install ROMs, if you don't have it already. I just use ROM manager to make backups. Then Bootstrapper to install stuff.
    02-17-2011 03:24 AM
  3. davidnc's Avatar
    Droid X
    Rooted
    Froyo 2.2.1
    Ya have to use bootstrapper since the boot is locked down, Rom manager is a personal preference
    I dont use rom manager but install my roms just with bootstrapper.
    http://www.appbrain.com/app/droid-x-...oidx.bootstrap
    02-17-2011 05:31 AM
  4. tntdroid's Avatar
    Yup bootstrapper is a must. No roms without it.
    Sent from my DROIDX using Tapatalk
    02-17-2011 05:43 AM
  5. geeforce1's Avatar
    Thanks for the help. I will download bootstrap and see if that will work.
    02-17-2011 10:47 AM
  6. JkdJedi's Avatar
    Rom Manager and Bootstrap are made from the same Dev. and where made to work together. Kinda like Batman and Robin.
    02-18-2011 12:08 PM
  7. Bald Steve's Avatar
    I do everything in Bootstrap. One of the only times I've bricked was when I tried to install ZapX via Rom Manager.
    02-18-2011 01:20 PM
  8. geeforce1's Avatar
    Thanks everyone...I got it to work with liberty...now on to the fun stuff!!!
    02-19-2011 12:27 PM
