- Forum
- Motorola Android Phones
- More Motorola Phones
- Verizon Droid X Forums
- Motorola Droid X
- Motorola X Rooting, ROMs, and Hacks
Urgent help - clockworkmod recovery lockup
- I used ROM manager to create a backup ROM and wanted to test it out so I used "manage and restore backup" and in that process (bootloader restoring data, etc) it got to a file (dock_preferences.xml) and has been sitting there for about 20 minutes. Only thing I can think of now is pulling the batter...!!
Will I have to sbf if I do that? I really didn't want to have to do that.
Please help ASAP.02-18-2011 09:06 PMLike 0 - tntdroidDroideratorI used ROM manager to create a backup ROM and wanted to test it out so I used "manage and restore backup" and in that process (bootloader restoring data, etc) it got to a file (dock_preferences.xml) and has been sitting there for about 20 minutes. Only thing I can think of now is pulling the batter...!!
Please help ASAP.02-18-2011 09:18 PMLike 0 - OK, just pulled the battery and re-started. I am having to go through the whole Android set up like it was brand new...
Do you suggest that I download ROM manager again and just try "manage and restore backup"...?
Trevor02-18-2011 09:26 PMLike 0 - OK, re-rooting right now. Z4 showed I was still rooted but when I tried 'bootstrap recovery' it said it didn't have permissions.
One question though. Why go through "droid x bootstrap" to apply backup rather than using "rom manager"?
This is my first attempt of loading/backuping roms and things are going as well as expected. Thanks much for the help.02-18-2011 09:58 PMLike 0 -
- tntdroidDroideratorOK, re-rooting right now. Z4 showed I was still rooted but when I tried 'bootstrap recovery' it said it didn't have permissions.
This is my first attempt of loading/backuping roms and things are going as well as expected. Thanks much for the help.02-18-2011 10:05 PMLike 0 - For some reason z4 isn't working good (sits for 10+ minutes before I give up on it). Couldn't I just use the cam + vol + power button method to get to the same thing??02-18-2011 10:18 PMLike 0
- tntdroidDroideratorsometimes z4 is like that. Just give it a few times. If your talking about recovery it would be home and the power key. When you get the droid guy then hit the search key. Your now in stock recovery. You can wipe cache and data but can not load backups and stuff. Bootstrapper needs to be installed to flash a rom and also do other stuff in bootstrap recovery.02-18-2011 10:57 PMLike 0
- OK, so I tried z4 numerous times (temp + perm) giving it 10+ minutes each never would work even after reboot. So I did the vol+cam+power button and did get into clockworkmod recovery, chose 'backup and restore' and chose the backup I created a couple days ago (same one I chose in rom manger earlier). It got to copying the same file (dock_preferences.xml) and has been there for about 20 minutes.
I am guessing at this point the backup is corrupt??? and this back up is a total loss. It passes the md5 checksum which I would think means that the file is (at least should be) ok..
Any suggestions, other than cutting my losses?02-18-2011 11:06 PMLike 0 - tntdroidDroideratorOK, so I tried z4 numerous times (temp + perm) giving it 10+ minutes each never would work even after reboot. So I did the vol+cam+power button and did get into clockworkmod recovery, chose 'backup and restore' and chose the backup I created a couple days ago (same one I chose in rom manger earlier). It got to copying the same file (dock_preferences.xml) and has been there for about 20 minutes.
Any suggestions, other than cutting my losses?02-18-2011 11:16 PMLike 0 - No I didn't rename it. Since I wanted to experiment other roms I guess now is my chance.
Do you know where I could get the full 2.3.340 sbf. I searched for hours last night and while I could find links they all seemed dead to me.
I think I have the 2.3.320 or 2.3.322 sbf and could update from there, but the 2.3.340 would save time.
Is this reletively common for these 'nandroid' or clockworkmod recoveries to be corrupt?
Trevor02-18-2011 11:27 PMLike 0 - tntdroidDroideratorNo I didn't rename it. Since I wanted to experiment other roms I guess now is my chance.
Trevorread in the post and if you have questions about what to do let me know. You will need the sbf and rsd lite 4.8.
Sent from my DROIDX using Tapatalk02-18-2011 11:57 PMLike 0 - Right under my nose the whole time...oh well.
Running liberty now. will sbf back when (if) ready to go back to full moto blur.
Really though...'tntdroid' thank so much for holding my hand on this one. I have entered the world of cutom roms/backups and hopefully someday I can help somebody else through this to repay the favor.02-19-2011 12:16 AMLike 0 - tntdroidDroideratorRight under my nose the whole time...oh well.
Sent from my DROIDX using Tapatalk02-19-2011 12:28 AMLike 0
- Forum
- Motorola Droid X
