anon(167668)
Correction: changing that piece of code will solve the problem entirely.
We will just have to agree to disagree. But for the life of me I cannot understand your position. Google could solve this on its own in probably less time than it's taken us to write these posts. But instead you want literally the entire internet to change to accommodate the xoom. Just baffling.
I don't think you understand how HTML headers work. It identifies the type of device you're running on. The "fix" would be to fabricate the device you're using. For example, the 'desktop' UAstring option in the debug menu makes the xoom pretend it's a Mac. The issue is that sites are just scanning for "Android", not if it's a cell phone or not. This issue will get fixed when Honeycomb becomes more popular with other devices released.
