it looks to be a lot better than the motorola OEM case.....anyone have one or know where I can find more pics/info about this cdase? Thanks
Sprint - All Accessories
I have the Sprint case and it's far superior to the original Verizon case. The plastic "frame" that clips the tablet in place is fully covered in leather. Very secure, no scratching. Really glad I waited to buy.
Sent from my Xoom using Tapatalk
From what it looks like in the photo its the same case...
Same case.
That's the same leather case that Verizon sells for 39.99, and I have it. Look over at the accessories section in XDA for the verizon product number.
The only leather case that verizon sells has a plastic back to it...which scuffs the device it self
this case has the back wrapped in leather to prevent that
Do some research before you make a statement as if it were fact, especially since I have the case. I even told you where to look for the info. :-!
New - Official Verizon/Moto Leather Folio Case - Now With Pics! - xda-developers
obviously the cases I posted is not a OEM motorola leather case so it is different.......take a chill pill and enjoy life a little bit.....different manufacturers...one is Acase..one is motorola
Um...okay. My point was valid but you dismissed it like you knew what you were talking about. You can take your chill pill and shove up your....I mean give it to someone who is in need.
I'm sorry if I did that...last time I went to verizon all they had was the original case which scratched back....the leather protected one is something new
I just figured it was the same OEM motorola case.....sorry for the confusion
I checked three stores in the area (corporate stores). All three put in the part number for that case and each one came up with the existing case with the plastic clips... so dont say people are not researching, because going TO vzw doesn't mean you'll find this new case...
One store employee said "oh I know that case, and came out with a box with the plastic one, shaking his head saying he swore it was a different case...
apparently vzw may be going to switch out cases from the scratching one quietly or something...
