I doubt if it would work unless it came with drivers for honeycomb, you would probably get better results by extending the range of your wifi at home. You can do this by replacing the stock antenna on the back of the router (1.5 db) with a 3,6,9, or 12 db antenna. You can order these online I believe newegg and buy.com both carry them in stock.
You could also daisy chain another router to your current one, purchase another router and put it either closer to your room or in it then turb both routers off and run cat5 cable from port 1- 4 of your original router to the WAN Ethernet in port of your new router.
It may also be possible for you to just relocate your home router closer to your room or in it but I would need more information on how everything is set up in your home first.
I know that Verizon fios uses the router and data connection for the guide and video on demand programming. If you have Time Warner of Comcast relocating the router may not be as complicated.
Here is an antenna I found at newegg that might help you out.
https://forums.androidcentral.com/e....aspx%3FItem%3DN82E16833995089&token=Mf0V--fG
