Nothing you can pry up with a small tool?
How much space do you need to make up?
How about depositing a small solder dot with an soldering iron? Use a sharp pointed iron.
...or soldering a small spring if you needed more space than a dot could make up? Again, use a sharp pointed iron and only wet both surfaces. Then insert the tip into the spring bring the spring in contact with the offending connection and hit it with freeze spray to solidify/bond it. Just use slight tension to pull the iron away. It will probably be stuck to the spring too, but will let go momentarily.
06-20-2011 02:49 PM
