I disagree fella, I myself can verify that Mugen power LiIon battery is superior comparing mAh to mAh against stock HTC batteries. I mean its not just BS they do have respected branch in the market when it comes to manufacturing batteries which is durable and long lasting which is tested by many. But for it to work you have to completely discharge it few times I normally do it for 2-3days before actual use for optical performance.
HyperNode said:
This SS is of Mugen Power 1300 mAh right after fully charged.
HyperNode said:
Okay so this morning after I replaced the Mugen battery with stock battery I fully charged it and took this screenshot.
From the looks of it both seems same and at this point I am totally convinced that the stock battery is better. This image on top I uploaded from work on my HD2 as I'm typing from there and my current charge is 83% at 5:53PM when I am submitting this post. So you tell me which is better.
Now keep in mind the stock battery is 1230 mAh and the Mugen power stock size battery was 1300 mAh. So the only difference here was 70+ extra mAh yet after extended test and usage I can respectfully say I got 3-4hours extra with Mugen than the stock size which is alot when you compare the batteries and its only 70 mAh extra which is nothing.
Now keep in mind from those SS the TBattery 0.60 does not verify the actual full mAh as its preset to the max of stock battery which is bug in the program. At the beginning to me it did seem the stock battery was superior as time went on and after many full discharges, Mugen power battery come on top.
