This is my second time installing a custom ROM on my phone. I downloaded Cyanogen 2.0.3 (i think thats the latest one) and after i do the back up (Rom Manager), i get the Cyanogen animation and nothing happens after that. It stays like that. I tried doing the factory reset (after taking the battery out and turning the power on + volume down) but it doesnt let me. It says
Parsing...[SD ZIP]
[1] RADIO_V2
Do you want to start update?
If i click yes, it does it and then it goes back to the cyanogen animation. If i click no then the only option it gives me is to reboot and it goes back to the animation too!!! =(
I think its because i might not have cleared and wipe the data before intalling....
What should i do???? Please help!
Thanks in advance
Parsing...[SD ZIP]
[1] RADIO_V2
Thanks in advance
