1. Jerry Runnels's Avatar
    My Nexus 10 has worked fine for the past couple of years. Suddenly, however, when i start it it goes through the normal bootup , shows the ANDROID LOGO, and then goes into a routing of "optimizing" of 159 apps i have loaded on it. When it completes the optimizing instead of opening up to my apps screen, it simply shuts down. I can start it again and it goes through the same routine and again shuts down. I made sure it is fully charged and tried it again with the same result. I dont know how to get it to open up to my apps etc so i can use it, or repair/change what is causing this new interim opening step.
    If i cant "fix" this should i reset it? If so how do i do that?
    Thanks for any help on this problem.
    08-12-2016 08:49 AM
  2. B. Diddy's Avatar
    Try wiping the cache partition: http://www.wijngaard.org/wipe-cache-partition-nexus-10/
    If that doesn't work, then try a factory data reset.
    A last resort would be to manually reinstall the firmware: How to manually update your Nexus | Android Central
    08-14-2016 02:52 AM
  3. Jerry Runnels's Avatar
    Thank you for the suggestion. I think it was overloaded with apps and the battery charge was less than i thought. Anyway i did an App purge, recharged the battery and it is working fine now like it has in the past.
    B. Diddy likes this.
    08-14-2016 09:49 AM
  4. Jerry Runnels's Avatar
    I finally decided to replace my battery on my Nexus 10 ...just finished the installation and it boots up fine,but dont seem to be able to open any programs. I have restarted it several times but the touchscreen doesnt seem to be working. I just restarted it and the old message i have had in the past...ANDROID IS STARTING...optimizing my apps....which takes a long time and i dont know what it means or why it does that.
    I am going to try to do a hard reset to start fresh...not sure what else to do...the tablet seems to be working fine....i didnt disconnect anything but the battery cables, screws etc.
    Any help appreciated.
    02-11-2017 02:11 PM
  5. Jerry Runnels's Avatar
    My Nexus 10 just finished optimizing the apps and completed booting up....but i cant open any programs with the touch screen even though it appears to be working fine in all other respects.,Any idea what would cause the touch screen not to function?
    02-11-2017 02:35 PM
  1. Replies: 1
    Last Post: 08-19-2016, 03:01 AM
  2. I am starting to dislike my note 5 :(
    By veggie59 in forum Samsung Galaxy Note 5
    Last Post: 08-15-2016, 06:13 AM
  3. Replies: 1
    Last Post: 08-12-2016, 01:52 PM
  4. How do I deactivate message blocking on my LG K7 phone?
    Last Post: 08-12-2016, 01:51 PM
  5. Replies: 3
    Last Post: 08-12-2016, 12:23 PM
