1. Nathan-NL's Avatar
    Where can I buy one?
    09-04-2014 06:57 PM
  2. neonworm's Avatar
    09-04-2014 09:34 PM
  3. Nathan-NL's Avatar
    Thank you for your response!
    But unfortunately this accessory isn't available in my country and I believe from seeing pictures outside of the Google Play Store that's it exactly the same cable as included with the Nexus 4. I remember it being longer for one. My original cable has been damaged which is the reason why I'm looking for a new replacement cable.
    Once again thank you for thinking with me. I too have not found one yet either.
    10-13-2014 05:13 PM
  4. acejavelin's Avatar
    Any quality micro USB cable will work fine, you don't need an "original" one... I use ones from Mediatek most of the time, but also the ones that come with Samsungs, Pantechs, HTCs, or pretty much any device that uses microUSB. Just pick a reliable seller in your area and get a generic one, or an OEM one for another device.
    10-14-2014 09:33 AM
  5. Bugstomper2000's Avatar
    I don't see why you want a factory replacement. Any micro usb 2.0 cable will work fine.
    01-02-2015 09:29 PM
  1. Samsung S4 USB can't connect to Kenwood stereo
    Last Post: 09-04-2014, 08:27 PM
  2. Nexus 10 USB charging plug
    Last Post: 09-04-2014, 04:57 PM
  3. Replies: 0
    Last Post: 09-04-2014, 06:36 AM
  4. USB Headphones work with Nvidia Shield but not Nexus 7
    Last Post: 09-04-2014, 03:31 AM
  5. Need to find this charging cable
    By Unregistered in forum Ask a Question
    Last Post: 09-03-2014, 06:50 PM
