1. jay_g's Avatar
    I use the trq app on my nexus 4. Looking for a good windshield mount or vent mount.
    01-30-2015 07:45 AM
  2. Rukbat's Avatar
    Vent mounts are usually pretty weak. A Windshield mount, constantly exposed to the sun, will dry out and be useless in a couple of years (even the ones with the levers). Try Mountek nGroove Universal CD Slot Mount. They have a few different styles, and they all mount in the CD slot of the car radio (which is pretty useless if you have a phone with a decent amount of storage). Mine have been working well for years. (They're big - my Note 3 is nowhere near the limit. Even a Magellan GPS fits with no problem.)
    01-30-2015 12:26 PM
  3. xX_Rasher_Xx's Avatar
    I recently started using the Steelie Car Mount. There are some draw back, you have to attach a magnet to the back of your phone and a steel bearing to your dash. I like it so far.
    Posted via an Amazing Note 4
    01-30-2015 12:42 PM
  4. jay_g's Avatar
    Thanks
    02-02-2015 07:22 PM
  1. Why does my SD card in my Samsung Galaxy S3 say Damaged SD card. Mount Card.?
    By trini88 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-01-2015, 07:33 PM
  2. Replies: 3
    Last Post: 01-30-2015, 08:24 AM
  3. Replies: 4
    Last Post: 01-30-2015, 05:33 AM
  4. Replies: 1
    Last Post: 01-30-2015, 12:16 AM
  5. Looking for suggestions for wireless car charger
    By dataz722 in forum Samsung Galaxy S5
    Last Post: 01-28-2015, 04:25 PM
