1. DarthSergous's Avatar
    So I rooted my Nexus 4 and now the hotspot feature doesn't seem to work. It doesn't even ask for the password, it just says unable to connect on both my laptop and iPad Mini. You guys know what might be causing this? It worked when I wasn't rooted while I was using FoxFi
    I just added root access, stayed with Stock 4.2.2
    07-03-2013 08:39 PM
  2. digitalslacker's Avatar
    try using it without any security and see if you can connect.
    it's possible the type of encryption being used isn't supported on the devices you are trying to connect to the phone with.
    root shouldn't affect it, it'll work fine with or without root
    Sent from my Transformer Prime TF201 using Tapatalk HD
    2defmouze likes this.
    07-03-2013 08:43 PM
  3. DarthSergous's Avatar
    That worked, thanks a lot! Switch to WPA PSK from WPA2 PSK. Thanks again.
    07-03-2013 09:00 PM
  4. digitalslacker's Avatar
    glad it worked! I spent hrs a few years ago trying to figure that one out!
    07-06-2013 09:26 AM
  1. Replies: 5
    Last Post: 11-21-2013, 06:28 PM
  2. Adware help
    By markin#AC in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-21-2013, 10:05 AM
  3. Should i buy a 32gb gs4(Please give advice)
    By legend32 in forum Samsung Galaxy S4
    Last Post: 07-04-2013, 12:31 PM
  4. Need help!
    By Rick Rab in forum Samsung Galaxy S4
    Last Post: 07-03-2013, 11:26 PM
  5. Please Help, My android tablet wont fully turn on!!
    By Audrey123 in forum General Help and How To
    Last Post: 07-03-2013, 08:17 PM
