1. william hutson's Avatar
    I have updated my Nexus 4 to 4.3, but I was trying to root it using Nexus 4 Toolkit with the most recent update as 4.2.2. I unlocked the bootloader and started to try to root it, but something didn't work right and now the phone is in an infinite loop. I don't know what I'm doing, but it seems to me that it is in the middle of the process but did using 4.2.2 Root mess it up? I'm just trying to figure out how to get it back to factory settings.....no rooting. PLEASE HELP!!!!
    08-05-2013 05:53 PM
  2. Rizy7's Avatar
    Why on earth would you use 4.2.2 settings on 4.3?? Where is it looping? On the nexus x or the google logo?
    08-06-2013 12:08 PM
  3. Noam Daloya's Avatar
    i have the same problem on the x logo
    08-06-2013 01:36 PM
  4. Rizy7's Avatar
    What were you doing before it started to boot loop? Try wiping cache and dalvik cache first. If that doesn't work then try factory reset
    08-06-2013 04:31 PM
  5. Noam Daloya's Avatar
    i try factory reset its not working
    08-06-2013 05:02 PM
  6. Rizy7's Avatar
    If you are using a rom then try flashing the rom again, if not, looks like youll have to restore factory images.. Factory Image Restore
    08-06-2013 05:19 PM
  7. Noam Daloya's Avatar
    man i restored my factory image not help
    08-06-2013 06:41 PM
  8. Rizy7's Avatar
    How long have you waited? The first boot always takes long
    08-06-2013 10:08 PM
  1. Nexus 4 Audio Stops/Pauses Frequently
    By inomad in forum Google Nexus 4
    Last Post: 12-25-2013, 01:41 PM
  2. In need of some serious help! please!
    By kingro93 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 09-20-2013, 07:17 PM
  3. Galaxy S2 HELP!
    By AaidenX in forum Samsung Galaxy S II
    Last Post: 08-05-2013, 11:13 PM
  4. Left widget glowing on lock screen dash? Help!
    By FecalMasterpiece in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-05-2013, 11:00 PM
  5. HTC One no storage help...
    By Patticus Finch in forum HTC One Rooting, ROMs & Hacks
    Last Post: 08-05-2013, 07:04 PM
