My Nexus 4 had been running Cyanogenmod (cm-12.1-20151007-SNAPSHOT-YOG4PAO334-mako) correctly for months. Two days ago, the screen failed to auto-rotate when I tilted the phone so I decided to reboot and see if that worked. Not only did it not work, the device went into a bootloop.
I'm able to use adb, fastboot, and access TWRP.
I've already tried reflashing CM12 to no avail. I've also tried going back to stock by following the stickied guide to no avail. That's where I'm at right now. I have everything stock except for the recovery partition where I have TWRP.
Here's the TWRP log:
Here's the dmesg log:
Here's the last kernel message log:
Any ideas?
Code:
__bionic_open_tzdata: couldn't find any tzdata when looking for localtime!
__bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
__bionic_open_tzdata: couldn't find any tzdata when looking for posixrules!
Starting TWRP 2.8.7.0 on Wed Jan 6 17:16:27 2016
(pid 155)
BOARD_HAS_NO_REAL_SDCARD := true
RECOVERY_SDCARD_ON_DATA := true
TW_NO_USB_STORAGE := true
TW_INCLUDE_CRYPTO := true
I:Found brightness file at '/sys/devices/i2c-0/0-0038/backlight/lm3530/brightness'
I:TWFunc::Set_Brightness: Setting brightness control to 255
Starting the UI...Pixel format: 768x1280 @ 32bpp
Pixel format: RGBX_8888
Not using qualcomm overlay, 'msmfb44_80601'
framebuffer: fd 4 (768 x 1280)
I:Scaling the curtain width 1.600000x and height 1.600000x
=> Linking mtab
Renaming regular /etc/recovery.fstab -> /etc/recovery.fstab.bak
Moving /etc/twrp.fstab -> /etc/recovery.fstab
=> Processing recovery.fstab
I:Processing '/boot'
I:Processing '/recovery'
I:Processing '/system'
I:Processing '/data'
I:Setting up '/data' as data/media emulated storage.
I:Created '/sdcard' folder.
I:mount -o bind '/data/media' '/sdcard' process ended with RC=0
I:mount -o bind '/data/media/0' '/sdcard' process ended with RC=0
I:Processing '/cache'
I:Processing '/usb-otg'
I:Created '/usb-otg' folder.
I:Backup folder set to '/data/media/0/TWRP/BACKUPS/02174adbd7d4c784'
I:Settings storage is '/data/media/0'
Updating partition details...
I:Data backup size is 77MB, free: 13024MB.
E:Unable to mount '/usb-otg'
I:Actual block device: '', current file system: 'vfat'
...done
I:Unmounting main partitions...
Partition Logs:
/boot | /dev/block/mmcblk0p6 | Size: 22MB
Flags: Can_Be_Backed_Up IsPresent Can_Flash_Img
Primary_Block_Device: /dev/block/mmcblk0p6
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Backup_Display_Name: Boot
Storage_Path: /boot
Current_File_System: emmc
Fstab_File_System: emmc
Backup_Method: dd
/recovery | /dev/block/mmcblk0p7 | Size: 22MB
Flags: IsPresent Can_Flash_Img
Primary_Block_Device: /dev/block/mmcblk0p7
Display_Name: Recovery
Storage_Name: recovery
Backup_Path: /recovery
Backup_Name: recovery
Backup_Display_Name: Recovery
Storage_Path: /recovery
Backup_Method: dd
/system | /dev/block/mmcblk0p21 | Size: 827MB Used: 815MB Free: 12MB Backup Size: 815MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI IsPresent
Primary_Block_Device: /dev/block/mmcblk0p21
Display_Name: System
Storage_Name: System
Backup_Path: /system
Backup_Name: system
Backup_Display_Name: System
Storage_Path: /system
Current_File_System: ext4
Fstab_File_System: ext4
Backup_Method: files
/data | /dev/block/mmcblk0p23 | Size: 13231MB Used: 77MB Free: 13024MB Backup Size: 77MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent Can_Be_Encrypted Has_Data_Media Can_Encrypt_Backup Use_Userdata_Encryption Is_Storage Is_Settings_Storage
Symlink_Path: /data/media/0
Symlink_Mount_Point: /sdcard
Primary_Block_Device: /dev/block/mmcblk0p23
Crypto_Key_Location: /dev/block/platform/msm_sdcc.1/by-name/metadata
Display_Name: Data
Storage_Name: Internal Storage
Backup_Path: /data
Backup_Name: data
Backup_Display_Name: Data
Storage_Path: /data/media/0
MTP_Storage_ID: 65537
/cache | /dev/block/mmcblk0p22 | Size: 551MB Used: 9MB Free: 541MB Backup Size: 9MB
Primary_Block_Device: /dev/block/mmcblk0p22
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
Backup_Display_Name: Cache
Storage_Path: /cache
/usb-otg | | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
Primary_Block_Device: /dev/block/sda1
Alternate_Block_Device: /dev/block/sda
Display_Name: usb-otg
Storage_Name: usb-otg
Backup_Path: /usb-otg
Backup_Name: usb-otg
Backup_Display_Name: usb-otg
Storage_Path: /usb-otg
Current_File_System: vfat
Fstab_File_System: vfat
I:Loading package: TWRP (/script/ui.xml)
I:Load XML directly
I:Loading package: TWRP (/data/media/0/TWRP/theme/ui.zip)
I:Loading zip theme
I:Loading package: TWRP (/twres/ui.xml)
I:Load XML directly
I:Checking resolution...
I:Scaling theme width 1.600000x and height 1.600000x, offsets x: 0 y: 0
I:Loading resources...
open_png /twres/images/twrplogo.png
libpng warning: iCCP: Not recognizing known sRGB profile that has been edited
open_png /twres/images/menu-button.png
open_png /twres/images/file.png
open_png /twres/images/folder.png
open_png /twres/images/slideout.png
open_png /twres/images/indeterminate001.png
open_png /twres/images/indeterminate002.png
open_png /twres/images/indeterminate003.png
open_png /twres/images/indeterminate004.png
open_png /twres/images/indeterminate005.png
open_png /twres/images/indeterminate006.png
open_png /twres/images/indeterminate007.png
open_png /twres/images/progress_empty.png
open_png /twres/images/progress_fill.png
open_png /twres/images/checkbox_empty.png
open_png /twres/images/checkbox_checked.png
open_png /twres/images/radio_empty.png
open_png /twres/images/radio_selected.png
open_png /twres/images/medium-button.png
open_png /twres/images/sort-button.png
open_png /twres/images/minus-button.png
open_png /twres/images/plus-button.png
open_png /twres/images/home-icon.png
open_png /twres/images/back-icon.png
open_png /twres/images/slider.png
open_png /twres/images/slider-used.png
open_png /twres/images/slider-touch.png
open_png /twres/images/unlock.png
open_png /twres/images/keyboard1.png
open_png /twres/images/keyboard2.png
open_png /twres/images/keyboard3.png
open_png /twres/images/keyboard4.png
open_png /twres/images/cursor.png
I:Loading variables...
I:Loading mouse cursor...
I:Loading pages...
I:PageSet::CheckInclude loading filename: '/twres/portrait.xml'
I:Loading included resources...
I:Loading included variables...
I:Loading included pages...
I:Loading page main
I:Loading page main2
I:Loading page install
I:Loading page flash_confirm
I:Loading page flash_zip
I:Loading page flash_done
I:Loading page install_image
I:Loading page flashimage_confirm
I:Loading page clear_vars
I:Loading page confirm_action
I:Loading page action_page
I:Loading page singleaction_page
I:Loading page action_complete
I:Loading page filecheck
I:Loading page rebootcheck
I:Loading page wipe
I:Loading page advancedwipe
I:Loading page formatdata
I:Loading page formatdata_confirm
I:Loading page checkpartitionlist
I:Loading page partitionoptions
I:Loading page refreshfilesystem
I:Loading page selectfilesystem
I:Loading page backup
I:Loading page backupname1
I:Loading page backupname2
I:Loading page backupencryption
I:Loading page backupencryption2
I:Loading page checkbackuppassword
I:Loading page backup_run
I:Loading page restore
I:Unable to open '/data/media/0/TWRP/BACKUPS/02174adbd7d4c784'
I:Loading page restore_read
I:Loading page restore_decrypt
I:Loading page try_restore_decrypt
I:Loading page restore_select
I:Loading page renamebackup
I:Loading page restore_run
I:Loading page selectstorage
I:Loading page mount
I:Loading page usb_mount
I:Loading page usb_umount
I:Loading page system_readonly_check
I:Loading page settings
I:Loading page timezone
I:Loading page screen
I:Loading page Vibrate
I:Loading page partsdcard
I:Loading page htcdumlock
I:Loading page lock
I:Loading page filemanagerlist
I:Loading page filemanageroptions
I:Loading page choosedestinationfolder
I:Loading page filemanagerrenamefile
I:Loading page filemanagerrenamefolder
I:Loading page filemanagerchmod
I:Loading page filemanagerconfirm
I:Loading page filemanageracction
I:Loading page decrypt
I:Loading page decrypt_pattern
I:Loading page trydecrypt
I:Loading page terminalfolder
I:Loading page terminalcommand
I:Loading page sideload
I:Loading page fixperms
I:Loading page installsu
I:Set page: 'clear_vars'
I:Set page: 'main2'
I:Switching packages (TWRP)
SELinux contexts loaded from /file_contexts
Full SELinux support is present.
I:Not using /misc, not defined in fstab.
Startup Commands:
ro.qc.sensors.wl_dis=true
ro.sf.lcd_density=320
ro.com.google.clientidbase=android-google
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.com.android.wifi-watchlist=GoogleGuest
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.boot.emmc=true
ro.boot.baseband=mdm
ro.boot.hardware=mako
ro.boot.serialno=02174adbd7d4c784
ro.boot.bootloader=MAKOZ30f
ro.omni.device=mako
ro.omni.version=5.0.2-20150621-mako-HOMEMADE
ro.twrp.boot=1
ro.twrp.version=2.8.7.0
ro.wifi.channels=
ro.allow.mock.location=1
ro.board.platform=msm8960
ro.build.id=LRX22G
ro.build.date=Sun Jun 21 18:29:54 EDT 2015
ro.build.date.utc=0
ro.build.host=build
ro.build.tags=test-keys
ro.build.type=eng
ro.build.user=jenkins
ro.build.display.id=omni_mako-eng 5.0.2 LRX22G 5 test-keys
ro.build.product=mako
ro.build.version.sdk=21
ro.build.version.release=5.0.2
ro.build.version.codename=REL
ro.build.version.incremental=5
ro.build.version.all_codenames=REL
ro.build.description=omni_mako-eng 5.0.2 LRX22G 5 test-keys
ro.build.fingerprint=google/omni_mako/mako:5.0.2/LRX22G/5:eng/test-keys
ro.build.characteristics=nosdcard
ro.config.ringtone=Orion.ogg
ro.config.alarm_alert=Argon.ogg
ro.config.notification_sound=pixiedust.ogg
ro.dalvik.vm.native.bridge=0
ro.kernel.android.checkjni=1
ro.secure=0
ro.zygote=zygote32
ro.carrier=unknown
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.name=omni_mako
ro.product.board=MAKO
ro.product.brand=google
ro.product.model=Nexus 4
ro.product.device=mako
ro.product.locale.region=US
ro.product.locale.language=en
ro.product.manufacturer=LGE
ro.baseband=mdm
ro.bootmode=unknown
ro.hardware=mako
ro.opengles.version=196608
ro.qualcomm.bt.hci_transport=smd
ro.qualcomm.sensors.smd=true
ro.revision=11
ro.serialno=02174adbd7d4c784
ro.telephony.call_ring.multiple=0
ro.bootloader=MAKOZ30f
ro.debuggable=1
ro.modversion=OmniROM-5.0.2-20150621-mako-HOMEMADE
ro.factorytest=0
ro.setupwizard.enterprise_mode=1
drm.service.enabled=true
net.bt.name=Android
net.change=net.bt.name
init.svc.adbd=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
init.svc.set_permissive=stopped
rild.libpath=/system/lib/libril-qc-qmi-1.so
twrp.crash_counter=0
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.egl.recordable.rgba8888=1
media.aac_51_output_enabled=true
dalvik.vm.isa.arm.features=div
dalvik.vm.heapsize=512m
dalvik.vm.dex2oat-Xms=64m
dalvik.vm.dex2oat-Xmx=512m
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=512k
dalvik.vm.dexopt-flags=m=y
dalvik.vm.heapstartsize=8m
dalvik.vm.dex2oat-filter=interpret-only
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.image-dex2oat-Xms=64m
dalvik.vm.image-dex2oat-Xmx=64m
dalvik.vm.image-dex2oat-filter=verify-none
dalvik.vm.heaptargetutilization=0.75
persist.hwc.mdpcomp.enable=true
persist.sys.usb.config=mtp,adb
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.root_access=1
persist.audio.dualmic.config=endfire
persist.audio.fluence.mode=endfire
persist.audio.fluence.voicecall=true
persist.audio.handset.mic=dmic
persist.audio.handset.mic.type=digital
persist.audio.lowlatency.rec=false
persist.radio.apm_sim_not_pwdn=1
service.adb.root=1
keyguard.no_require_sim=true
telephony.lteOnCdmaDevice=0
I:Copying file /cache/recovery/log to /cache/recovery/last_log
tw_get_context got selinux context: u:object_r:media_rw_data_file:s0
I:Got default contexts and file mode for storage files.
I:Attempt to load settings from settings file...
I:Settings file '/data/media/0/TWRP/.twrps' not found.
I:Copying file /etc/recovery.fstab to /cache/recovery/recovery.fstab
I:Version number saved to '/cache/recovery/.version'
__bionic_open_tzdata: couldn't find any tzdata when looking for CST6CDT,M3.2.0,M11.1.0!
I:TWFunc::Fixup_Time: Pre-fix date and time: 2016-01-06--11-16-29
I:TWFunc::Fixup_Time: Setting time offset from file /sys/class/rtc/rtc0/since_epoch
I:TWFunc::Fixup_Time: Date and time corrected: 2016-01-06--11-16-29
I:Enabling MTP during startup
I:Starting MTP
Starting MTP
I:Get_Max_FileSize::maxFileSize: 17592186044416
I:sending message to add 65537 '/data/media/0' 'Internal Storage'
I:Message sent, add storage ID: 65537
MTP Enabled
I:Check_Lifetime_Writes result: '0'
I:Set page: 'system_readonly'
created new mtpserver object
MtpServer::run fd: 15
mtppipe add storage 65537 '/data/media/0'
MtpStorage id: 65537 path: /data/media/0
I:operation_start: 'Toggle System Mount'
I:operation_end - status=0
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'advanced'
I:Set page: 'confirm_action'
I:Set page: 'action_page'
I:operation_start: 'Copy Log'
I:Copying file /tmp/recovery.log to /data/media/0/recovery.log
Code:
<6>[ 0.000000] Booting Linux on physical CPU 0
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.4.0-Bricked-TWRP-Edition-g27406e9-05626-gc3e7a05 (showp1984@jarvis) (gcc version 4.7.2 20120910 (prerelease) (Linaro GCC 4.7-2012.09) ) #1 SMP PREEMPT Sat Nov 2 21:45:13 CET 2013
<4>[ 0.000000] CPU: ARMv7 Processor [510f06f2] revision 2 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
<4>[ 0.000000] Machine: QCT APQ8064 MAKO
<2>[ 0.000000] Truncating memory at 0xc0000000 to fit in 32-bit physical address space
<6>[ 0.000000] memory pool 3 (start fe9ff000 size 1600000) initialized
<6>[ 0.000000] Initialized persistent memory from 88700000-887fffff
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<3>[ 0.000000] smem_find(137, 80): wrong size 72
<6>[ 0.000000] socinfo_init: v6, id=109, ver=1.1, raw_id=1817, raw_ver=1817, hw_plat=8, hw_plat_ver=65536
<6>[ 0.000000] accessory_chip=0 hw_plat_subtype=1
<7>[ 0.000000] On node 0 totalpages: 493055
<7>[ 0.000000] Normal zone: 1536 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 169984 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 2556 pages used for memmap
<7>[ 0.000000] HighMem zone: 318979 pages, LIFO batch:31
<6>[ 0.000000] allocating 21626880 bytes at c280e000 (82a0e000 physical) for fb
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c3cb1000 s16256 r8192 d12416 u36864
<7>[ 0.000000] pcpu-alloc: s16256 r8192 d12416 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 488963
<5>[ 0.000000] Kernel command line: console=ttyHSL0,115200,n8 androidboot.hardware=mako lpj=67677 user_debug=31 uart_console=enable lcd_maker_id=primary lge.hreset=off lge.reset=mode_reset gpt=enable lge.kcal=rrr|ggg|bbb|K lge.rev=rev_11 androidboot.emmc=true androidboot.serialno=02174adbd7d4c784 androidboot.bootloader=MAKOZ30f androidboot.baseband=mdm
<6>[ 0.000000] UART CONSOLE : enable
<6>[ 0.000000] kcal is 0|0|0|
<6>[ 0.000000] kcal not calibrated yet : 0
<6>[ 0.000000] set to default : 255
<6>[ 0.000000] BOARD : LGE input rev_11
<6>[ 0.000000] BOARD : LGE matched rev_11
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Memory: 134MB 74MB 7MB 1MB 253MB 1456MB = 1925MB total
<5>[ 0.000000] Memory: 1909876k/1992820k available, 62344k reserved, 1286140K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0d387d0 (13506 kB)
<5>[ 0.000000] .init : 0xc0e00000 - 0xc0f03f80 (1040 kB)
<5>[ 0.000000] .data : 0xc0f04000 - 0xc0ff13b4 ( 949 kB)
<5>[ 0.000000] .bss : 0xc0ff13f4 - 0xc1270bcc (2558 kB)
<6>[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:921
<6>[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30520ns, wraps every 131084001ms
<6>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.000183] Calibrating delay loop (skipped) preset value.. 13.53 BogoMIPS (lpj=67677)
<6>[ 0.000213] pid_max: default: 32768 minimum: 301
<6>[ 0.000427] Security Framework initialized
<6>[ 0.000457] SELinux: Initializing.
<7>[ 0.000518] SELinux: Starting in permissive mode
<6>[ 0.000610] Mount-cache hash table entries: 512
<6>[ 0.001831] Initializing cgroup subsys debug
<6>[ 0.001861] Initializing cgroup subsys cpuacct
<6>[ 0.001861] Initializing cgroup subsys freezer
<6>[ 0.001983] CPU: Testing write buffer coherency: ok
<6>[ 0.002258] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[ 0.002289] hw perfevents: enabled with ARMv7 Krait PMU driver, 5 counters available
<6>[ 0.002380] Setting up static identity map for 0x80baa568 - 0x80baa5f0
<6>[ 0.005615] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<6>[ 0.008057] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
<6>[ 0.010499] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
<6>[ 0.010621] Brought up 4 CPUs
<6>[ 0.010621] SMP: Total of 4 processors activated (54.14 BogoMIPS).
<6>[ 0.024507] dummy:
<6>[ 0.024935] NET: Registered protocol family 16
<3>[ 0.025453] AXI: msm_bus_fabric_init_driver(): msm_bus_fabric_init_driver
<6>[ 0.027590] meminfo_init: smem ram ptable found: ver: 0 len: 6
<6>[ 0.027620] Found 2 memory banks grouped into 16 memory regions
<6>[ 0.027834] gpiochip_add: registered GPIOs 0 to 151 on device: msmgpio
<3>[ 0.028597] smem_find(137, 80): wrong size 72
<6>[ 0.028628] socinfo_init: v6, id=109, ver=1.1, raw_id=1817, raw_ver=1817, hw_plat=8, hw_plat_ver=65536
<6>[ 0.028628] accessory_chip=0 hw_plat_subtype=1
<6>[ 0.028719] msm_rpm_init: RPM firmware 3.0.16842886
<3>[ 0.048557] msm_rpm_get_status(): Status id 433 not defined for target
<3>[ 0.048588] msm_rpm_get_status(): Status id 433 not defined for target
<3>[ 0.048618] msm_rpm_get_status(): Status id 433 not defined for target
<3>[ 0.048649] msm_rpm_get_status(): Status id 433 not defined for target
<6>[ 0.066656] pm8921_probe: PMIC revision 1: F4
<6>[ 0.066656] pm8921_probe: PMIC revision 2: 06
<6>[ 0.066687] pm8921_probe: PMIC version: PM8921 rev 3.0
<6>[ 0.066687] pm8921_probe: PMIC Restart Reason: Triggered from CHG (usb charger insertion)
<6>[ 0.067816] gpiochip_add: registered GPIOs 152 to 195 on device: pm-gpio
<6>[ 0.068304] pm_gpio_probe: OK: base=152, ngpio=44
<6>[ 0.068579] gpiochip_add: registered GPIOs 196 to 207 on device: pm8xxx-mpp
<6>[ 0.068670] pm8xxx_mpp_probe: OK: base=196, ngpio=12
<6>[ 0.070746] pm8821_probe: PMIC revision 1: PM8821 rev F3
<6>[ 0.070776] pm8821_probe: PMIC revision 2: PM8821 rev 0B
<6>[ 0.070776] pm8821_probe: PMIC version: PM8821 ver 2.1
<6>[ 0.071326] gpiochip_add: registered GPIOs 208 to 211 on device: pm8xxx-mpp
<6>[ 0.071387] pm8xxx_mpp_probe: OK: base=208, ngpio=4
<6>[ 0.071905] gpio_vreg_probe: id=86, name=ext_dsv_load, gpio=86, gpio_label=ext_dsv_load_en
<6>[ 0.073157] saw_probe: id=0, name=8921_s5
<6>[ 0.073493] saw_probe: id=1, name=8921_s6
<6>[ 0.073859] saw_probe: id=2, name=8821_s0
<6>[ 0.074225] saw_probe: id=3, name=8821_s1
<6>[ 0.082954] persistent_ram: found existing buffer, size 36260, start 36260
<6>[ 0.192308] console [ram-1] enabled
<6>[ 0.193743] [NORMAL-DEBUG] apq8064_device_uart_gsbi4.id : 0
<6>[ 0.193834] [DEBUG] uart_enable : 1
<6>[ 0.196368] [Touch D] apq8064_init_input: NOT DCM KDDI, reg synaptics driver
<4>[ 0.197588] ------------[ cut here ]------------
<4>[ 0.197680] WARNING: at arch/arm/mach-msm/subsystem_restart.c:617 subsys_restart_init+0xdc/0x114()
<4>[ 0.197833] Modules linked in:
<4>[ 0.198016] [<c0017100>] (unwind_backtrace+0x0/0xf8) from [<c00948d0>] (warn_slowpath_null+0x38/0xa8)
<4>[ 0.198168] [<c00948d0>] (warn_slowpath_null+0x38/0xa8) from [<c0e0bb30>] (subsys_restart_init+0xdc/0x114)
<4>[ 0.198351] [<c0e0bb30>] (subsys_restart_init+0xdc/0x114) from [<c00088e8>] (do_one_initcall+0x10c/0x170)
<4>[ 0.198504] ---[ end trace da227214a82491b7 ]---
<6>[ 0.200976] sps:BAM 0x12244000 enabled: ver:0x5, number of pipes:20
<6>[ 0.201129] sps:BAM 0x12244000 is registered.
<6>[ 0.201678] sps:sps is ready.
<6>[ 0.230489] bio: create slab <bio-0> at 0
<6>[ 0.231191] ION heap vmalloc created
<6>[ 0.231313] ION heap mm created at a0000000 with size 3800000
<6>[ 0.231497] ION heap mm_fw created at 9fe00000 with size 1e0000
<6>[ 0.231588] ION heap mfc created at a3800000 with size 2000
<6>[ 0.231771] ION heap iommu created
<6>[ 0.231893] ION heap qsecom created at fea07000 with size 780000
<6>[ 0.232076] ION heap audio created at ff187000 with size 4cf000
<5>[ 0.233389] pm8xxx_pwm_probe: OK
<5>[ 0.234091] SCSI subsystem initialized
<6>[ 0.234549] sps:BAM 0x28084000 enabled: ver:0x12, number of pipes:31
<6>[ 0.234640] sps:BAM 0x28084000 is registered.
<6>[ 0.235556] usbcore: registered new interface driver usbfs
<6>[ 0.235800] usbcore: registered new interface driver hub
<6>[ 0.236075] usbcore: registered new device driver usb
<6>[ 0.236471] input: pmic8xxx_pwrkey as /devices/platform/msm_ssbi.0/pm8921-core/pm8xxx-pwrkey/input/input0
<6>[ 0.237387] Linux media interface: v0.10
<6>[ 0.237540] Linux video capture interface: v2.00
<7>[ 0.238058] Registered led device: red
<7>[ 0.238577] Registered led device: green
<7>[ 0.238913] Registered led device: blue
<6>[ 0.239859] msm_iommu_dev: device vpe mapped at f0400000, with 2 ctx banks
<6>[ 0.240073] msm_iommu_dev: device mdp0 mapped at f0600000, with 2 ctx banks
<6>[ 0.240317] msm_iommu_dev: device mdp1 mapped at f0800000, with 2 ctx banks
<6>[ 0.240531] msm_iommu_dev: device rot mapped at f0a00000, with 2 ctx banks
<6>[ 0.240805] msm_iommu_dev: device ijpeg mapped at f0c00000, with 2 ctx banks
<6>[ 0.241049] msm_iommu_dev: device vfe mapped at f0e00000, with 2 ctx banks
<6>[ 0.241263] msm_iommu_dev: device vcodec_a mapped at f1000000, with 2 ctx banks
<6>[ 0.241507] msm_iommu_dev: device vcodec_b mapped at f1200000, with 2 ctx banks
<6>[ 0.241782] msm_iommu_dev: device gfx3d mapped at f1400000, with 3 ctx banks
<6>[ 0.241996] msm_iommu_dev: device jpegd mapped at f1600000, with 2 ctx banks
<6>[ 0.242240] msm_iommu_dev: device gfx3d1 mapped at f1800000, with 3 ctx banks
<6>[ 0.242545] msm_iommu_dev: device vcap mapped at f1a00000, with 2 ctx banks
<6>[ 0.243033] msm_iommu_ctx msm_iommu_ctx.2: context vpe_src using bank 0
<6>[ 0.243338] msm_iommu_ctx msm_iommu_ctx.3: context vpe_dst using bank 1
<6>[ 0.243552] msm_iommu_ctx msm_iommu_ctx.4: context mdp_port0_cb0 using bank 0
<6>[ 0.243857] msm_iommu_ctx msm_iommu_ctx.5: context mdp_port0_cb1 using bank 1
<6>[ 0.244162] msm_iommu_ctx msm_iommu_ctx.6: context mdp_port1_cb0 using bank 0
<6>[ 0.244407] msm_iommu_ctx msm_iommu_ctx.7: context mdp_port1_cb1 using bank 1
<6>[ 0.244712] msm_iommu_ctx msm_iommu_ctx.8: context rot_src using bank 0
<6>[ 0.244925] msm_iommu_ctx msm_iommu_ctx.9: context rot_dst using bank 1
<6>[ 0.245200] msm_iommu_ctx msm_iommu_ctx.10: context ijpeg_src using bank 0
<6>[ 0.245505] msm_iommu_ctx msm_iommu_ctx.11: context ijpeg_dst using bank 1
<6>[ 0.245750] msm_iommu_ctx msm_iommu_ctx.12: context vfe_imgwr using bank 0
<6>[ 0.246024] msm_iommu_ctx msm_iommu_ctx.13: context vfe_misc using bank 1
<6>[ 0.246268] msm_iommu_ctx msm_iommu_ctx.14: context vcodec_a_stream using bank 0
<6>[ 0.246574] msm_iommu_ctx msm_iommu_ctx.15: context vcodec_a_mm1 using bank 1
<6>[ 0.246909] msm_iommu_ctx msm_iommu_ctx.16: context vcodec_b_mm2 using bank 0
<6>[ 0.247184] msm_iommu_ctx msm_iommu_ctx.17: context gfx3d_user using bank 0
<6>[ 0.247520] msm_iommu_ctx msm_iommu_ctx.18: context gfx3d_priv using bank 1
<6>[ 0.247794] msm_iommu_ctx msm_iommu_ctx.0: context jpegd_src using bank 0
<6>[ 0.248008] msm_iommu_ctx msm_iommu_ctx.1: context jpegd_dst using bank 1
<6>[ 0.248374] msm_iommu_ctx msm_iommu_ctx.19: context gfx3d1_user using bank 0
<6>[ 0.248679] msm_iommu_ctx msm_iommu_ctx.20: context gfx3d1_priv using bank 1
<6>[ 0.248954] msm_iommu_ctx msm_iommu_ctx.21: context vcap_vc using bank 0
<6>[ 0.249259] msm_iommu_ctx msm_iommu_ctx.22: context vcap_vp using bank 1
<6>[ 0.249443] Advanced Linux Sound Architecture Driver Version 1.0.25.
<6>[ 0.250114] Bluetooth: Core ver 2.16
<6>[ 0.250236] NET: Registered protocol family 31
<6>[ 0.250328] Bluetooth: HCI device and connection manager initialized
<6>[ 0.250419] Bluetooth: HCI socket layer initialized
<6>[ 0.250511] Bluetooth: L2CAP socket layer initialized
<6>[ 0.250877] Bluetooth: SCO socket layer initialized
<6>[ 0.251274] cfg80211: Calling CRDA to update world regulatory domain
<6>[ 0.251457] cfg80211: World regulatory domain updated:
<6>[ 0.251548] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
<6>[ 0.251701] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[ 0.251854] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[ 0.251915] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
<6>[ 0.252067] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[ 0.252220] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[ 0.252983] earjack debugger probed
<6>[ 0.253502] Switching to clocksource gp_timer
<6>[ 0.289088] NET: Registered protocol family 2
<6>[ 0.289485] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.290157] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
<6>[ 0.291500] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
<6>[ 0.292232] TCP: Hash tables configured (established 131072 bind 65536)
<6>[ 0.292385] TCP: reno registered
<6>[ 0.292476] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.292659] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.293056] NET: Registered protocol family 1
<6>[ 0.293544] Trying to unpack rootfs image as initramfs...
<6>[ 0.590752] Freeing initrd memory: 4148K
<6>[ 0.591912] Detected 5 counters on the L2CC PMU.
<6>[ 0.594231] pil_qdsp6v4 pil_qdsp6v4.0: using secure boot
<6>[ 0.596001] pil_riva pil_riva: using secure boot
<6>[ 0.599023] pil_dsps pil_dsps: using secure boot
<6>[ 0.600549] pil_gss pil_gss: using secure boot
<3>[ 0.602777] smd_channel_probe_worker: allocation table not initialized
<6>[ 0.608698] msm_dsps driver version 4.03.
<6>[ 0.610376] NET: Registered protocol family 27
<6>[ 0.614588] lpass_fatal_init: lpass SSR driver init'ed.
<6>[ 0.615016] wcnss_8960: module initialized
<6>[ 0.615565] gss_8064_init: gss fatal driver init'ed.
<6>[ 0.616419] acpuclk-8064 acpuclk-8064: SPEED BIN: 0
<6>[ 0.616664] acpuclk-8064 acpuclk-8064: ACPU PVS: 3
<6>[ 0.619258] acpuclk-8064 acpuclk-8064: CPU0: 15 frequencies supported
<6>[ 0.619410] acpuclk-8064 acpuclk-8064: CPU1: 15 frequencies supported
<6>[ 0.619502] acpuclk-8064 acpuclk-8064: CPU2: 15 frequencies supported
<6>[ 0.619655] acpuclk-8064 acpuclk-8064: CPU3: 15 frequencies supported
<6>[ 0.620265] kcal_ctrl_init
<6>[ 0.620906] persistent_ram: no valid data in buffer (sig = 0x4e4f524d)
<5>[ 0.621944] msm_rpm_log_probe: OK
<3>[ 0.624935] mdm_modem_probe: registered mdm id 0
<3>[ 0.625026] mdm_do_first_power_on:id 0: Powering on modem for the first time
<6>[ 0.625331] mdm_pblrdy_change: mdm id 0: pbl ready:0
<6>[ 0.660705] mdm_pblrdy_change: mdm id 0: pbl ready:1
<6>[ 0.874988] usbcore: registered new interface driver hsic_sysmon
<6>[ 0.875476] audit: initializing netlink socket (disabled)
<5>[ 0.875598] type=2000 audit(0.880:1): initialized
<4>[ 0.992125] highmem bounce pool size: 64 pages
<6>[ 1.001526] NTFS driver 2.1.30 [Flags: R/W].
<6>[ 1.002044] fuse init (API version 7.18)
<6>[ 1.002472] msgmni has been set to 1226
<7>[ 1.002594] SELinux: Registering netfilter hooks
<6>[ 1.006317] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
<6>[ 1.006653] io scheduler noop registered
<6>[ 1.006836] io scheduler deadline registered
<6>[ 1.007508] io scheduler cfq registered (default)
<6>[ 1.008576] lm3530 probed
<6>[ 1.012269] mipi_dsi base phy_addr = 0x4700000 virt = 0xf1c00000
<6>[ 1.012604] mmss_sfpb base phy_addr = 0x5700000,virt = 0xf00f8000
<6>[ 1.013825] mipi_lgit_lcd_probe start
<6>[ 1.014191] setting pdata->panel_info.fb_num to 3. type: 8
<6>[ 1.026430] FrameBuffer[0] 768x1280 size=11796480 bytes is registered successfully!
<4>[ 1.026766] load_565rle_image: Can not open /initlogo.rle
<7>[ 1.027346] Registered led device: lcd-backlight
<6>[ 1.028567] setting pdata->panel_info.fb_num to 1. type: 7
<6>[ 1.029696] FrameBuffer[1] 1920x1080 size=0 bytes is registered successfully!
<4>[ 1.029940] load_565rle_image: Can not open /initlogo.rle
<6>[ 1.030489] mdp4_dtv_vsync_init: ndx=0
<3>[ 1.030703] hdmi_msm hdmi_msm.1: external_common_state_create: sysfs group cf919008
<6>[ 1.030886] hdmi_msm hdmi_msm.1: hdmi_msm_config_hdcp_feature: HDCP Feature: Enabled
<6>[ 1.031710] setting pdata->panel_info.fb_num to 1. type: 10
<3>[ 1.031985] Inside writeback_driver_init
<3>[ 1.032351] Inside writeback_probe
<6>[ 1.033114] FrameBuffer[2] 1280x720 size=0 bytes is registered successfully!
<4>[ 1.033328] load_565rle_image: Can not open /initlogo.rle
<6>[ 1.035067]
<6>[ 1.035067] msm_vidc_enc: Inside vid_enc_init()
<6>[ 1.035464]
<6>[ 1.035464] msm_vidc_enc: Inside vid_enc_vcd_init()
<3>[ 1.036380] smux_init: unable to create log context
<6>[ 1.037234] msm_serial_hs module loaded
<6>[ 1.037631] msm_serial_hsl: detected port #0
<6>[ 1.037875] msm_serial_hsl.0: ttyHSL0 at MMIO 0x16340000 (irq = 184) is a MSM
<6>[ 1.038119] msm_serial_hsl: console setup on port #0
<6>[ 1.038364] console [ttyHSL0] enabled
<6>[ 1.038791] msm_serial_hsl: driver initialized
<6>[ 1.040408] msm_rotator_probe: rotator_hw_revision=2
<6>[ 1.043918] diagchar initialized now
<6>[ 1.045750] kgsl kgsl-3d0: |kgsl_iommu_init| MMU type set for device is IOMMU
<6>[ 1.054936] brd: module loaded
<6>[ 1.059179] loop: module loaded
<6>[ 1.061529] anx7808 init gpio
<6>[ 1.094124] anx7808 dvdd is already on
<6>[ 1.124248] sp_tx_hardware_poweron: anx7808 power on
<6>[ 1.125286] sp_tx_chip_located: ANX7808 BA is found.
<5>[ 1.126629] sp_tx_vbus_powerdown: 3.3V output disabled
<6>[ 1.184159] sp_tx_hardware_powerdown: anx7808 power down
<5>[ 1.184251] sp_tx_set_sys_state: SP_TX To System State:
<5>[ 1.184404] sp_tx_set_sys_state: STATE_CABLE_PLUG
<6>[ 1.184983] tabla2x-slim tabla2x-slim: Platform data from board file
<6>[ 1.251762] wcd9xxx_check_codec_type: codec is tabla_codec
<6>[ 1.251976] wcd9xxx_check_codec_type: Read codec idbytes & version
<6>[ 1.251976] byte_0[00000002] byte_1[00000000] byte_2[00000000]
<6>[ 1.251976] byte_3[00000001] version = 2
<4>[ 1.254295] i2c-core: driver [tabla-i2c-core] using legacy suspend method
<4>[ 1.254478] i2c-core: driver [tabla-i2c-core] using legacy resume method
<6>[ 1.255974] bcm2079x-i2c 0-a1fa: bcm2079x_probe, probing bcm2079x driver flags = 10
<6>[ 1.256371] bcm2079x-i2c 0-a1fa: requesting IRQ 317
<6>[ 1.256828] bcm2079x-i2c 0-a1fa: bcm2079x_probe, probing bcm2079x driver exited successfully
<6>[ 1.257958] SCSI Media Changer driver v0.25
<6>[ 1.259758] rmnet_init: BAM devices[8]
<6>[ 1.283290] PPP generic driver version 2.4.2
<6>[ 1.283839] PPP BSD Compression module registered
<6>[ 1.284022] PPP Deflate Compression module registered
<6>[ 1.285884] modprobe (109): undefined instruction: pc=b6ec77f0
<6>[ 1.286067] Code: 0000991d e1a02001 e3a01000 e92d0001 (eee01b10)
<6>[ 1.287929] modprobe (111): undefined instruction: pc=b6eec7f0
<6>[ 1.288142] Code: 0000991d e1a02001 e3a01000 e92d0001 (eee01b10)
<6>[ 1.289211] PPP MPPE Compression module registered
<6>[ 1.289394] NET: Registered protocol family 24
<6>[ 1.289638] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 1.289974] CSLIP: code copyright 1989 Regents of the University of California.
<6>[ 1.290492] wcnss_wlan probed in built-in mode
<6>[ 1.292171] usbcore: registered new interface driver asix
<6>[ 1.292629] usbcore: registered new interface driver cdc_ether
<6>[ 1.292934] usbcore: registered new interface driver net1080
<6>[ 1.293361] usbcore: registered new interface driver cdc_subset
<6>[ 1.293667] usbcore: registered new interface driver zaurus
<6>[ 1.294338] usbcore: registered new interface driver cdc_ncm
<6>[ 1.294674] msm_otg msm_otg: msm_otg probe
<3>[ 1.295040] msm_otg msm_otg: failed to get phy_clk
<6>[ 1.295315] msm_otg msm_otg: OTG regs = f01f2000
<6>[ 1.298214] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 1.311460] msm_hsic_host msm_hsic_host: Qualcomm EHCI Host Controller using HSIC
<6>[ 1.311643] msm_hsic_host msm_hsic_host: new USB bus registered, assigned bus number 1
<6>[ 1.334228] msm_hsic_host msm_hsic_host: irq 261, io mem 0x12510000
<6>[ 1.354219] msm_hsic_host msm_hsic_host: USB 2.0 started, EHCI 1.00
<6>[ 1.354646] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.354738] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.354890] usb usb1: Product: Qualcomm EHCI Host Controller using HSIC
<6>[ 1.354982] usb usb1: Manufacturer: Linux 3.4.0-Bricked-TWRP-Edition-g27406e9-05626-gc3e7a05 ehci_hcd
<6>[ 1.355165] usb usb1: SerialNumber: msm_hsic_host
<6>[ 1.355745] hub 1-0:1.0: USB hub found
<6>[ 1.355898] hub 1-0:1.0: 1 port detected
<6>[ 1.357179] usbcore: registered new interface driver cdc_acm
<6>[ 1.357363] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 1.357515] Initializing USB Mass Storage driver...
<6>[ 1.357729] usbcore: registered new interface driver usb-storage
<6>[ 1.357881] USB Mass Storage support registered.
<6>[ 1.358034] usbcore: registered new interface driver ums-alauda
<6>[ 1.358217] usbcore: registered new interface driver ums-cypress
<6>[ 1.358431] usbcore: registered new interface driver ums-datafab
<6>[ 1.358675] usbcore: registered new interface driver ums-freecom
<6>[ 1.358828] usbcore: registered new interface driver ums-isd200
<6>[ 1.359072] usbcore: registered new interface driver ums-jumpshot
<6>[ 1.359224] usbcore: registered new interface driver ums-karma
<6>[ 1.359468] usbcore: registered new interface driver ums-onetouch
<6>[ 1.359621] usbcore: registered new interface driver ums-sddr09
<6>[ 1.359865] usbcore: registered new interface driver ums-sddr55
<6>[ 1.360048] usbcore: registered new interface driver ums-usbat
<6>[ 1.360354] usbcore: registered new interface driver usbserial
<6>[ 1.360445] usbserial: USB Serial Driver core
<6>[ 1.360689] usbcore: registered new interface driver qc_csvt
<6>[ 1.360811] USB Serial support registered for qc_csvt
<6>[ 1.361086] usbcore: registered new interface driver usb_ehset_test
<6>[ 1.361239] usbcore: registered new interface driver diag_bridge
<6>[ 1.361696] usbcore: registered new interface driver mdm_bridge
<6>[ 1.362612] usbcore: registered new interface driver ks_bridge
<6>[ 1.362765] ksb_init: init done
<6>[ 1.363131] msm_otg msm_otg: phy_reset: success
<6>[ 1.363955] msm_hsusb msm_hsusb: [ci13xxx_start] hw_ep_max = 32
<6>[ 1.364352] mbim_init: initialize 1 instances
<6>[ 1.364565] mbim_init: Initialized 1 ports
<6>[ 1.366671] rndis_qc_init: initialize rndis QC instance
<6>[ 1.367129] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.367282] android_usb gadget: Number of LUNs=1
<6>[ 1.367373] lun0: LUN: removable file: (no medium)
<6>[ 1.367892] android_usb gadget: android_usb ready
<6>[ 1.369418] input: keypad_8064 as /devices/platform/msm_ssbi.0/pm8921-core/pm8xxx-keypad/input/input1
<4>[ 1.370364] [Touch D]touch enable
<6>[ 1.574423] input: touch_dev as /devices/virtual/input/input2
<6>[ 1.596490] [Touch] common[1] finger[17] flash[52] button[0]
<6>[ 1.597588] [Touch] IC is 7020, H pattern, panel is G2, Firmware: E028.
<6>[ 1.599603] [Touch] fw_rev[0:0] product_id[PLG137:PLG137] force_upgrade[0]
<6>[ 1.599694] [Touch] Touch driver is initialized
<6>[ 1.600183] [Touch] DO NOT UPDATE 7020 G2 H pattern FW-upgrade is not executed
<6>[ 1.601220] using rtc device, pm8xxx_rtc, for alarms
<6>[ 1.601403] rtc-pm8xxx rtc-pm8xxx: rtc core: registered pm8xxx_rtc as rtc0
<6>[ 1.601953] i2c /dev entries driver
<6>[ 1.602594] usbcore: registered new interface driver uvcvideo
<6>[ 1.602685] USB Video Class driver (1.1.1)
<3>[ 1.604028] __jrchoi: msm_sensor_init_module: E
<3>[ 1.632260] msm_eeprom_probe probe_fail
<6>[ 1.632687] msm_server_update_sensor_info mctl_node_name[0] = video1
<3>[ 1.661101] msm_eeprom_probe probe_fail
<6>[ 1.661529] msm_server_update_sensor_info mctl_node_name[1] = video3
<6>[ 1.665557] msm_cam_server_request_irq IRQ Router hw is not present.
<6>[ 1.666259] lm3559_init
<7>[ 1.666656] Registered led device: spotlight
<6>[ 1.672821] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
<6>[ 1.673309] cpuidle: using governor ladder
<6>[ 1.673462] cpuidle: using governor menu
<6>[ 1.673950] mmc0: SDCC Version: 0x0000001a
<6>[ 1.675293] mmc0: bam physical base=0x12402000
<6>[ 1.675446] mmc0: bam virtual base=0xf0320000
<6>[ 1.675537] sps:BAM 0x12402000 is registered.
<6>[ 1.675629] mmc0: BAM device registered. bam_handle=0xef005a00
<6>[ 1.676026] sps:BAM 0x12402000 enabled: ver:0x5, number of pipes:6
<6>[ 1.676575] mmc0: Qualcomm MSM SDCC-BAM at 0x0000000012402000 irq 130
<6>[ 1.676789] mmc0: Qualcomm MSM SDCC-DML at 0x0000000012400800
<3>[ 1.676972] mmc0: No card detect facilities available
<6>[ 1.678803] mmc0: Qualcomm MSM SDCC-core at 0x0000000012400000 irq 136,0 dma -1 dmacrcri -1
<6>[ 1.678956] mmc0: Controller capabilities: 0x0000039e
<6>[ 1.679047] mmc0: 8 bit data mode enabled
<6>[ 1.679200] mmc0: 4 bit data mode disabled
<6>[ 1.679291] mmc0: polling status mode disabled
<6>[ 1.679383] mmc0: MMC clock 400000 -> 96000000 Hz, PCLK 0 Hz
<6>[ 1.679536] mmc0: Slot eject status = 0
<6>[ 1.679627] mmc0: Power save feature enable = 1
<6>[ 1.679780] mmc0: SPS-BAM data transfer mode available
<6>[ 1.680756] usbcore: registered new interface driver usbhid
<6>[ 1.680909] usbhid: USB HID core driver
<6>[ 1.681825] ashmem: initialized
<6>[ 1.682008] logger: created 256K log 'log_main'
<6>[ 1.682282] logger: created 256K log 'log_events'
<6>[ 1.682496] logger: created 256K log 'log_radio'
<6>[ 1.682679] logger: created 256K log 'log_system'
<6>[ 1.683564] usbcore: registered new interface driver snd-usb-audio
<3>[ 1.685304] tabla_probe
<6>[ 1.686189] amp_enable: amp enable bypass(2)
<6>[ 1.686311] amp_enable: AMP_EN is set to 0
<6>[ 1.687471] msm_pcm_probe: dev name msm-voip-dsp
<6>[ 1.687959] msm-dai-q6-mi2s msm-dai-q6-mi2s: msm_dai_q6_mi2s_platform_data_validation: playback sdline 0 capture sdline 8
<6>[ 1.688112] msm-dai-q6-mi2s msm-dai-q6-mi2s: msm_dai_q6_mi2s_platform_data_validation: playback ch_max 0 capture ch_mx 8
<6>[ 1.689333] msm_pcm_probe: dev name msm-pcm-dsp
<6>[ 1.689760] msm_pcm_probe: dev name msm-multi-ch-pcm-dsp
<6>[ 1.690187] msm_pcm_probe: dev name msm-lowlatency-pcm-dsp
<6>[ 1.690370] adding pm_qos request in low latency driver
<6>[ 1.690462] done adding pm_qos request in low latency driver
<6>[ 1.691591] msm_compr_probe: dev name msm-compr-dsp
<6>[ 1.692324] msm-pcm-lpa msm-pcm-lpa: msm_pcm_probe: dev name msm-pcm-lpa
<3>[ 1.693514] msm8930_audio_init: Not the right machine type
<3>[ 1.693636] msm_audio_init: Not the right machine type
<6>[ 1.693789] msm_audio_init: Not APQ8064 in I2S mode
<6>[ 1.694399] usb 1-1: new high-speed USB device number 2 using msm_hsic_host
<6>[ 1.695132] tabla codec probe...
<6>[ 1.756783] usb 1-1: New USB device found, idVendor=05c6, idProduct=9008
<6>[ 1.757088] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 1.757271] usb 1-1: Product: QHSUSB__BULK
<6>[ 1.757546] usb 1-1: Manufacturer: Qualcomm CDMA Technologies MSM
<6>[ 1.821303] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
<6>[ 1.822157] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
<6>[ 1.822951] asoc: snd-soc-dummy-dai <-> CS-VOICE mapping ok
<6>[ 1.823805] asoc: snd-soc-dummy-dai <-> VoIP mapping ok
<6>[ 1.824568] asoc: snd-soc-dummy-dai <-> MultiMedia3 mapping ok
<6>[ 1.825453] asoc: snd-soc-dummy-dai <-> SLIMBUS0_HOSTLESS mapping ok
<6>[ 1.826186] asoc: snd-soc-dummy-dai <-> INT_FM_HOSTLESS mapping ok
<6>[ 1.827010] asoc: msm-stub-rx <-> msm-dai-q6.241 mapping ok
<6>[ 1.827681] asoc: msm-stub-tx <-> msm-dai-q6.240 mapping ok
<6>[ 1.828567] asoc: snd-soc-dummy-dai <-> MultiMedia4 mapping ok
<6>[ 1.829421] asoc: snd-soc-dummy-dai <-> AUXPCM_HOSTLESS mapping ok
<6>[ 1.830215] asoc: snd-soc-dummy-dai <-> HDMI_HOSTLESS mapping ok
<6>[ 1.831008] asoc: snd-soc-dummy-dai <-> VOICE_STUB mapping ok
<6>[ 1.831771] asoc: snd-soc-dummy-dai <-> VoLTE mapping ok
<6>[ 1.832626] asoc: snd-soc-dummy-dai <-> MultiMedia5 mapping ok
<6>[ 1.833908] asoc: tabla_rx1 <-> msm-dai-q6.16384 mapping ok
<6>[ 1.838760] asoc: tabla_tx1 <-> msm-dai-q6.16385 mapping ok
<6>[ 1.839340] asoc: msm-stub-rx <-> msm-dai-q6.12288 mapping ok
<6>[ 1.840042] asoc: msm-stub-tx <-> msm-dai-q6.12289 mapping ok
<6>[ 1.840714] asoc: msm-stub-rx <-> msm-dai-q6.12292 mapping ok
<6>[ 1.841416] asoc: msm-stub-tx <-> msm-dai-q6.12293 mapping ok
<6>[ 1.842026] asoc: msm-stub-rx <-> msm-dai-q6-hdmi.8 mapping ok
<6>[ 1.842789] asoc: msm-stub-rx <-> msm-dai-q6.224 mapping ok
<6>[ 1.843491] asoc: msm-stub-tx <-> msm-dai-q6.225 mapping ok
<6>[ 1.844193] asoc: msm-stub-rx <-> msm-dai-q6.2 mapping ok
<6>[ 1.844956] asoc: msm-stub-tx <-> msm-dai-q6.3 mapping ok
<6>[ 1.845627] asoc: tabla_rx2 <-> msm-dai-stub mapping ok
<6>[ 1.846268] asoc: tabla_tx1 <-> msm-dai-stub mapping ok
<6>[ 1.846940] asoc: msm-stub-rx <-> msm-dai-q6.16386 mapping ok
<6>[ 1.847611] asoc: msm-stub-tx <-> msm-dai-q6.16387 mapping ok
<6>[ 1.848374] asoc: tabla_tx2 <-> msm-dai-q6.16389 mapping ok
<6>[ 1.849107] asoc: tabla_rx3 <-> msm-dai-q6.16388 mapping ok
<6>[ 1.849778] asoc: msm-stub-rx <-> msm-dai-q6.16392 mapping ok
<6>[ 1.850450] asoc: msm-stub-tx <-> msm-dai-q6.16393 mapping ok
<6>[ 1.851030] asoc: tabla_tx3 <-> msm-dai-stub mapping ok
<6>[ 1.851762] asoc: msm-stub-rx <-> msm-dai-q6.16390 mapping ok
<6>[ 1.852403] asoc: msm-stub-tx <-> msm-dai-q6.16391 mapping ok
<6>[ 1.855180] input: apq8064-tabla-snd-card Button Jack as /devices/platform/soc-audio.0/sound/card0/input3
<6>[ 1.855608] input: apq8064-tabla-snd-card Headset Jack as /devices/platform/soc-audio.0/sound/card0/input4
<6>[ 1.860155] oprofile: using arm/armv7-krait
<6>[ 1.860399] u32 classifier
<6>[ 1.860491] Actions configured
<6>[ 1.860643] Netfilter messages via NETLINK v0.30.
<6>[ 1.860827] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.861712] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.861956] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.862108] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.862475] xt_time: kernel timezone is -0000
<6>[ 1.863024] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.863573] arp_tables: (C) 2002 David S. Miller
<6>[ 1.863757] TCP: cubic registered
<6>[ 1.863940] Initializing XFRM netlink socket
<6>[ 1.864794] NET: Registered protocol family 10
<6>[ 1.868609] Mobile IPv6
<6>[ 1.868823] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.869159] IPv6 over IPv4 tunneling driver
<6>[ 1.869952] NET: Registered protocol family 17
<6>[ 1.870135] NET: Registered protocol family 15
<6>[ 1.870441] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.870654] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.870746] Bluetooth: RFCOMM ver 1.11
<6>[ 1.870837] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.870990] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.871081] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.871356] L2TP core driver, V2.0
<6>[ 1.871478] PPPoL2TP kernel driver, V2.0
<6>[ 1.872028] VFP support v0.3: implementor 51 architecture 64 part 6f variant 0 rev 2
<5>[ 1.872272] Registering SWP/SWPB emulation handler
<6>[ 1.872424] clock_late_init: Removing enables held for handed-off clocks
<6>[ 1.877765] [MPDEC]: msm_mpdec_init init complete.
<6>[ 1.881214] MSM Watchdog Initialized
<6>[ 1.903189] registered taskstats version 1
<6>[ 1.904806] rtc-pm8xxx rtc-pm8xxx: setting system clock to 2016-01-06 17:16:26 UTC (1452100586)
<6>[ 1.905142] mmc0: new HS200 MMC card at address 0001
<6>[ 1.906088] mmcblk0: mmc0:0001 016G92 14.6 GiB
<3>[ 1.908347] read_ocv_trim: program rev reg is 0x54
<3>[ 1.908408] read_ocv_trim: trim reg is 0x42
<3>[ 1.908499] read_ocv_trim: trim delta is 7
<3>[ 1.908591] pm8921_is_usb_chg_plugged_in: called before init
<4>[ 1.912131] Alternate GPT is invalid, using primary GPT.
<6>[ 1.912528] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25
<3>[ 1.928429] pm8921_is_usb_chg_plugged_in: called before init
<3>[ 1.929681] pm8921_is_usb_chg_plugged_in: called before init
<6>[ 1.930047] ocv_ir_compensation: comp ocv = 3730892, ocv = 3724673, ibatt_ua = 28400, rbatt_mohm = 219
<0>[ 1.930474] calculate_unusable_charge_uah: Using shutdown_iavg_ma = 500 in all samples
<3>[ 1.930657] pm8921_is_batfet_closed: called before init
<3>[ 1.954524] pm8921_is_usb_chg_plugged_in: called before init
<6>[ 1.954585] adjust_soc: ibat_ua = 284200, vbat_uv = 3640892, soc = 30, batt_temp=275
<3>[ 1.957576] pm8921_get_batt_state: called before init
<6>[ 1.957668] pm8921_bms_probe: OK battery_capacity_at_boot=30 volt = 3647157 ocv = 3774716
<3>[ 1.958675] power_supply usb: driver failed to report `present' property: 4294967274
<3>[ 1.958828] power_supply usb: driver failed to report `present' property: 4294967274
<3>[ 1.958980] power_supply pm8921-dc: driver failed to report `present' property: 4294967274
<3>[ 1.959072] power_supply pm8921-dc: driver failed to report `present' property: 4294967274
<3>[ 1.960415] pm8921_get_batt_state: called before init
<3>[ 1.962826] pm8921_get_batt_state: called before init
<6>[ 1.976773] unplug_check_worker: usb_now=500, usb_target = 500
<6>[ 1.984922] wlc: bq51051b_wlc_probe: probe
<6>[ 1.985106] wlc: bq51051b_wlc_hw_init: hw_init
<3>[ 1.985624] power_supply wireless: driver failed to report `present' property: 4294967274
<6>[ 1.986235] [Touch] CHARGER = 1
<3>[ 1.986265] power_supply wireless: driver failed to report `present' property: 4294967274
<6>[ 1.986754] batt_temp_ctrl_init
<6>[ 1.986906] batt_temp_ctrl_probe
<6>[ 1.988799] android_vibrator: default amplitude 88
<6>[ 1.989165] android vibrator probed
<6>[ 1.989653] fsa8008 init
<6>[ 1.990538] fsa8008 probe
<7>[ 1.990782] hsd_probe: hi->irq_detect = 369
<7>[ 1.991210] hsd_probe: hi->irq_key = 371
<6>[ 1.992125] input: hs_detect as /devices/virtual/input/input5
<6>[ 1.992736] ALSA device list:
<6>[ 1.993071] #0: apq8064-tabla-snd-card
<6>[ 1.995208] Freeing init memory: 1036K
<7>[ 2.011200] SELinux: 2048 avtab hash slots, 5257 rules.
<7>[ 2.017823] SELinux: 2048 avtab hash slots, 5257 rules.
<7>[ 2.017854] SELinux: 1 users, 2 roles, 428 types, 0 bools, 1 sens, 1024 cats
<7>[ 2.017884] SELinux: 86 classes, 5257 rules
<7>[ 2.018678] SELinux: Completing initialization.
<7>[ 2.018678] SELinux: Setting up existing superblocks.
<7>[ 2.018708] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 2.018739] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 2.019410] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 2.019441] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 2.019441] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.019471] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 2.028475] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 2.028506] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 2.028506] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 2.028536] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 2.028567] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 2.028658] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.028689] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<6>[ 2.094704] msm_otg msm_otg: Avail curr from USB = 500
<6>[ 2.095070] msm_otg msm_otg: current: 0 -> 500 (mA)
<6>[ 2.095254] pm_power_set_property_usb: usb_target_ma 0
<6>[ 2.099130] msm_hsusb msm_hsusb: CI13XXX_CONTROLLER_RESET_EVENT received
<6>[ 2.174637] unplug_check_worker: Stopping Unplug Check Worker USB == 500mA
<5>[ 2.235037] type=1403 audit(1452100586.820:2): policy loaded auid=4294967295 ses=4294967295
<5>[ 2.242759] type=1404 audit(1452100586.820:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<3>[ 2.510056] init: could not import file '/init.recovery.mako.rc' from '/init.rc'
<3>[ 2.513108] healthd: wakealarm_init: timerfd_create failed
<7>[ 3.084144] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 3.087135] enable_store: android_usb: already disabled
<3>[ 3.087746] init: Unable to open persistent property directory /data/property errno: 2
<3>[ 3.091194] init: Warning! Service recovery needs a SELinux domain defined; please fix!
<6>[ 3.095803] adb_open
<6>[ 3.096108] mtp_bind_config
<6>[ 3.096322] adb_bind_config
<5>[ 3.099679] type=1400 audit(1452100587.680:4): avc: denied { write } for pid=154 comm="toolbox" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:recovery:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[ 3.100228] type=1400 audit(1452100587.680:5): avc: denied { setenforce } for pid=154 comm="toolbox" scontext=u:r:recovery:s0 tcontext=u:object_r:kernel:s0 tclass=security
<5>[ 3.100564] type=1404 audit(1452100587.680:6): enforcing=0 old_enforcing=1 auid=4294967295 ses=4294967295
<6>[ 3.124889] recovery (155): undefined instruction: pc=b6d87908
<6>[ 3.124980] Code: e320f000 e320f000 f26001f0 e12fff1e (ec510f1e)
<6>[ 3.184922] mipi_dsi_controller_cfg: DSI status=8 failed
<6>[ 3.184983] mipi_dsi_panel_power: mipi lcd function started status = 1
<4>[ 3.185014] ext_dsv_load: Failed to create debugfs directory
<6>[ 3.187059] mipi_dsi_panel_power : reset start.
<6>[ 3.207599] mipi_lgit_lcd_on started
<6>[ 3.226583] msm_otg msm_otg: Avail curr from USB = 0
<6>[ 3.227346] android_work: android_work: did not send uevent (0 0 (null))
<6>[ 3.231252] mipi_lgit_lcd_on finished
<6>[ 3.265038] adjust_soc: ibat_ua = 331300, vbat_uv = 3699629, soc = 30, batt_temp=275
<5>[ 3.309690] type=1400 audit(1452100587.890:7): avc: denied { execmem } for pid=155 comm="recovery" scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=process
<5>[ 3.309873] type=1400 audit(1452100587.890:8): avc: denied { execute } for pid=155 comm="recovery" path="/dev/ashmem" dev="tmpfs" ino=7838 scontext=u:r:init:s0 tcontext=u:object_r:ashmem_device:s0 tclass=chr_file
<6>[ 3.337311] android_work: android_work: sent uevent USB_STATE=CONNECTED
<6>[ 3.341156] android_work: android_work: sent uevent USB_STATE=DISCONNECTED
<5>[ 3.388676] type=1400 audit(1452100587.970:9): avc: denied { rename } for pid=155 comm="recovery" name="recovery.fstab" dev="rootfs" ino=4395 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file
<6>[ 3.469433] android_work: android_work: sent uevent USB_STATE=CONNECTED
<6>[ 3.470654] android_usb gadget: high-speed config #1: android_usb
<6>[ 3.470929] msm_otg msm_otg: Avail curr from USB = 500
<6>[ 3.471295] msm_otg msm_otg: current: 0 -> 500 (mA)
<6>[ 3.471448] pm_power_set_property_usb: usb_target_ma 0
<6>[ 3.525072] android_work: android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 3.627498] EXT4-fs (mmcblk0p23): recovery complete
<6>[ 3.628811] EXT4-fs (mmcblk0p23): mounted filesystem with ordered data mode. Opts:
<7>[ 3.629024] SELinux: initialized (dev mmcblk0p23, type ext4), uses xattr
<6>[ 3.759438] EXT4-fs (mmcblk0p23): mounted filesystem with ordered data mode. Opts:
<7>[ 3.759804] SELinux: initialized (dev mmcblk0p23, type ext4), uses xattr
<6>[ 3.899404] EXT4-fs (mmcblk0p23): mounted filesystem with ordered data mode. Opts:
<7>[ 3.899771] SELinux: initialized (dev mmcblk0p23, type ext4), uses xattr
<6>[ 3.957363] EXT4-fs (mmcblk0p22): mounted filesystem with ordered data mode. Opts:
<7>[ 3.957576] SELinux: initialized (dev mmcblk0p22, type ext4), uses xattr
<5>[ 3.959926] type=1400 audit(1452100588.541:10): avc: denied { create } for pid=155 comm="recovery" name="fstab" scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file
<6>[ 3.982664] EXT4-fs (mmcblk0p21): mounted filesystem with ordered data mode. Opts:
<7>[ 3.982878] SELinux: initialized (dev mmcblk0p21, type ext4), uses xattr
<6>[ 4.106455] SELinux: Context u:object_r:adb_data_file:s0 is not valid (left unmapped).
<6>[ 4.802472] EXT4-fs (mmcblk0p21): mounted filesystem with ordered data mode. Opts:
<7>[ 4.802838] SELinux: initialized (dev mmcblk0p21, type ext4), uses xattr
<6>[ 5.578727] mtp_open
<6>[ 7.105692] msm_ta_detect_work: USB exit ta detection - frindex
<6>[ 20.470959] [MPDEC]: CPU[2] on->off | Mask=[1101] | time online: 20475
<6>[ 20.732672] [MPDEC]: CPU[3] on->off | Mask=[1100] | time online: 20737
<6>[ 20.994994] [MPDEC]: CPU[1] on->off | Mask=[1000] | time online: 20999
<6>[ 22.025759] adjust_soc: ibat_ua = -173500, vbat_uv = 3803389, soc = 30, batt_temp=272
<6>[ 42.105875] adjust_soc: ibat_ua = -205400, vbat_uv = 3813228, soc = 30, batt_temp=272
<6>[ 62.106088] adjust_soc: ibat_ua = -262900, vbat_uv = 3830817, soc = 30, batt_temp=272
<6>[ 82.105905] adjust_soc: ibat_ua = -269800, vbat_uv = 3836782, soc = 30, batt_temp=271
<6>[ 99.668029] lm3530_backlight_off, on: 1
<6>[ 99.715733] mipi_lgit_lcd_off started
<6>[ 99.845750] mipi_lgit_lcd_off finished
<6>[ 99.845811] mipi_dsi_panel_power: mipi lcd function started status = 0
<6>[ 99.851945] lm3530_backlight_off, on: 0
<6>[ 102.105936] adjust_soc: ibat_ua = -367200, vbat_uv = 3867193, soc = 30, batt_temp=270
Code:
[ 0.000000] Linux version 3.4.0-perf-gdffc258 (android-build@vpee9.mtv.corp.google.com) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Jul 8 23:25:22 UTC 2015
[ 0.000000] allocating 21626880 bytes at c231a000 (8251a000 physical) for fb
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c37bd000 s15680 r0 d12992 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 479747
[ 0.000000] Memory: 134MB 74MB 7MB 1MB 253MB 1420MB = 1889MB total
[ 0.000000] Memory: 1877648k/1997456k available, 57708k reserved, 1286140K highmem
[ 0.000000] .text : 0xc0008000 - 0xc0c629f4 (12651 kB)
[ 0.000000] .init : 0xc0d00000 - 0xc0e03d40 (1040 kB)
[ 0.000000] .data : 0xc0e04000 - 0xc0ee82f8 ( 913 kB)
[ 0.000000] .bss : 0xc0ee831c - 0xc10e201c (2024 kB)
[ 0.000183] pid_max: default: 32768 minimum: 301
[ 0.000579] Mount-cache hash table entries: 512
[ 0.001861] Initializing cgroup subsys debug
[ 0.001892] Initializing cgroup subsys freezer
[ 0.002014] CPU: Testing write buffer coherency: ok
[ 0.002289] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002319] hw perfevents: enabled with ARMv7 Krait PMU driver, 5 counters available
[ 0.002380] Setting up static identity map for 0x80a27078 - 0x80a27100
[ 0.005676] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008118] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010560] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010682] Brought up 4 CPUs
[ 0.010682] SMP: Total of 4 processors activated (54.14 BogoMIPS).
[ 0.026857] dummy:
[ 0.027285] NET: Registered protocol family 16
[ 0.028261] AXI: msm_bus_fabric_init_driver(): msm_bus_fabric_init_driver
[ 0.030978] meminfo_init: smem ram ptable found: ver: 0 len: 6
[ 0.031008] Found 2 memory banks grouped into 16 memory regions
[ 0.031191] gpiochip_add: registered GPIOs 0 to 151 on device: msmgpio
[ 0.031954] smem_find(137, 80): wrong size 72
[ 0.032046] socinfo_init: v6, id=109, ver=1.1, raw_id=1817, raw_ver=1817, hw_plat=8, hw_plat_ver=65536
[ 0.032076] accessory_chip=0 hw_plat_subtype=1
[ 0.032076] msm_rpm_init: RPM firmware 3.0.16842886
[ 0.052556] msm_rpm_get_status(): Status id 433 not defined for target
[ 0.052586] msm_rpm_get_status(): Status id 433 not defined for target
[ 0.052617] msm_rpm_get_status(): Status id 433 not defined for target
[ 0.052647] msm_rpm_get_status(): Status id 433 not defined for target
[ 0.070990] pm8921_probe: PMIC revision 1: F4
[ 0.070990] pm8921_probe: PMIC revision 2: 06
[ 0.071020] pm8921_probe: PMIC version: PM8921 rev 3.0
[ 0.071020] pm8921_probe: PMIC Restart Reason: Triggered from CHG (usb charger insertion)
[ 0.072180] gpiochip_add: registered GPIOs 152 to 195 on device: pm-gpio
[ 0.072669] pm_gpio_probe: OK: base=152, ngpio=44
[ 0.072974] gpiochip_add: registered GPIOs 196 to 207 on device: pm8xxx-mpp
[ 0.073035] pm8xxx_mpp_probe: OK: base=196, ngpio=12
[ 0.075141] pm8821_probe: PMIC revision 1: PM8821 rev F3
[ 0.075141] pm8821_probe: PMIC revision 2: PM8821 rev 0B
[ 0.075171] pm8821_probe: PMIC version: PM8821 ver 2.1
[ 0.075751] gpiochip_add: registered GPIOs 208 to 211 on device: pm8xxx-mpp
[ 0.075812] pm8xxx_mpp_probe: OK: base=208, ngpio=4
[ 0.076361] gpio_vreg_probe: id=86, name=ext_dsv_load, gpio=86, gpio_label=ext_dsv_load_en
[ 0.077674] saw_probe: id=0, name=8921_s5
[ 0.078040] saw_probe: id=1, name=8921_s6
[ 0.078406] saw_probe: id=2, name=8821_s0
[ 0.078773] saw_probe: id=3, name=8821_s1
[ 0.087807] persistent_ram: found existing buffer, size 49916, start 49916
[ 0.243918] console [ram-1] enabled
[ 0.245322] [NORMAL-DEBUG] apq8064_device_uart_gsbi4.id : 0
[ 0.245414] [DEBUG] uart_enable : 1
[ 0.248100] [Touch D] apq8064_init_input: NOT DCM KDDI, reg synaptics driver
[ 0.249259] ------------[ cut here ]------------
[ 0.249443] WARNING: at /usr/local/google/buildbot/repo_clients/https___partner-android.googlesource.com_a_kernel_manifest/l-mr1-dev-msm-mako-3.4-clean-wip/private/msm-lge/arch/arm/mach-msm/subsystem_restart.c:617 subsys_restart_init+0xd8/0x108()
[ 0.249687] [<c00138fc>] (unwind_backtrace+0x0/0xe0) from [<c006d4c0>] (warn_slowpath_common+0x48/0x60)
[ 0.249809] [<c006d4c0>] (warn_slowpath_common+0x48/0x60) from [<c006d590>] (warn_slowpath_null+0x18/0x1c)
[ 0.249961] [<c006d590>] (warn_slowpath_null+0x18/0x1c) from [<c0d0b1bc>] (subsys_restart_init+0xd8/0x108)
[ 0.250144] [<c0d0b1bc>] (subsys_restart_init+0xd8/0x108) from [<c0d009b0>] (do_one_initcall+0x90/0x160)
[ 0.250328] [<c0d009b0>] (do_one_initcall+0x90/0x160) from [<c0d00b68>] (kernel_init+0xe8/0x1a4)
[ 0.250511] [<c0d00b68>] (kernel_init+0xe8/0x1a4) from [<c000eae0>] (kernel_thread_exit+0x0/0x8)
[ 0.250694] ---[ end trace 73795d74079f31ec ]---
[ 0.253197] sps:BAM 0x12244000 enabled: ver:0x5, number of pipes:20
[ 0.253349] sps:BAM 0x12244000 is registered.
[ 0.253929] sps:sps is ready.
[ 0.284449] bio: create slab <bio-0> at 0
[ 0.285243] ION heap vmalloc created
[ 0.285365] ION heap mm created at a0000000 with size 5c00000
[ 0.285487] ION heap mm_fw created at 9fe00000 with size 1e0000
[ 0.285670] ION heap mfc created at a5c00000 with size 2000
[ 0.285792] ION heap iommu created
[ 0.286006] ION heap qsecom created at fea07000 with size 780000
[ 0.286128] ION heap audio created at ff187000 with size 4cf000
[ 0.287501] pm8xxx_pwm_probe: OK
[ 0.288264] SCSI subsystem initialized
[ 0.288631] sps:BAM 0x28084000 enabled: ver:0x12, number of pipes:31
[ 0.288814] sps:BAM 0x28084000 is registered.
[ 0.289668] usbcore: registered new interface driver usbfs
[ 0.289943] usbcore: registered new interface driver hub
[ 0.290187] usbcore: registered new device driver usb
[ 0.290645] input: pmic8xxx_pwrkey as /devices/platform/msm_ssbi.0/pm8921-core/pm8xxx-pwrkey/input/input0
[ 0.291622] Linux media interface: v0.10
[ 0.291774] Linux video capture interface: v2.00
[ 0.294094] msm_iommu_dev: device vpe mapped at f0400000, with 2 ctx banks
[ 0.294368] msm_iommu_dev: device mdp0 mapped at f0600000, with 2 ctx banks
[ 0.294643] msm_iommu_dev: device mdp1 mapped at f0800000, with 2 ctx banks
[ 0.294887] msm_iommu_dev: device rot mapped at f0a00000, with 2 ctx banks
[ 0.295162] msm_iommu_dev: device ijpeg mapped at f0c00000, with 2 ctx banks
[ 0.295376] msm_iommu_dev: device vfe mapped at f0e00000, with 2 ctx banks
[ 0.295650] msm_iommu_dev: device vcodec_a mapped at f1000000, with 2 ctx banks
[ 0.295956] msm_iommu_dev: device vcodec_b mapped at f1200000, with 2 ctx banks
[ 0.296169] msm_iommu_dev: device gfx3d mapped at f1400000, with 3 ctx banks
[ 0.296444] msm_iommu_dev: device jpegd mapped at f1600000, with 2 ctx banks
[ 0.296719] msm_iommu_dev: device gfx3d1 mapped at f1800000, with 3 ctx banks
[ 0.296963] msm_iommu_dev: device vcap mapped at f1a00000, with 2 ctx banks
[ 0.297512] msm_iommu_ctx msm_iommu_ctx.2: context vpe_src using bank 0
[ 0.297726] msm_iommu_ctx msm_iommu_ctx.3: context vpe_dst using bank 1
[ 0.298061] msm_iommu_ctx msm_iommu_ctx.4: context mdp_port0_cb0 using bank 0
[ 0.298367] msm_iommu_ctx msm_iommu_ctx.5: context mdp_port0_cb1 using bank 1
[ 0.298611] msm_iommu_ctx msm_iommu_ctx.6: context mdp_port1_cb0 using bank 0
[ 0.298947] msm_iommu_ctx msm_iommu_ctx.7: context mdp_port1_cb1 using bank 1
[ 0.299191] msm_iommu_ctx msm_iommu_ctx.8: context rot_src using bank 0
[ 0.299496] msm_iommu_ctx msm_iommu_ctx.9: context rot_dst using bank 1
[ 0.299832] msm_iommu_ctx msm_iommu_ctx.10: context ijpeg_src using bank 0
[ 0.300045] msm_iommu_ctx msm_iommu_ctx.11: context ijpeg_dst using bank 1
[ 0.300381] msm_iommu_ctx msm_iommu_ctx.12: context vfe_imgwr using bank 0
[ 0.300625] msm_iommu_ctx msm_iommu_ctx.13: context vfe_misc using bank 1
[ 0.300930] msm_iommu_ctx msm_iommu_ctx.14: context vcodec_a_stream using bank 0
[ 0.301266] msm_iommu_ctx msm_iommu_ctx.15: context vcodec_a_mm1 using bank 1
[ 0.301541] msm_iommu_ctx msm_iommu_ctx.16: context vcodec_b_mm2 using bank 0
[ 0.301907] msm_iommu_ctx msm_iommu_ctx.17: context gfx3d_user using bank 0
[ 0.302304] msm_iommu_ctx msm_iommu_ctx.18: context gfx3d_priv using bank 1
[ 0.302517] msm_iommu_ctx msm_iommu_ctx.0: context jpegd_src using bank 0
[ 0.302823] msm_iommu_ctx msm_iommu_ctx.1: context jpegd_dst using bank 1
[ 0.303128] msm_iommu_ctx msm_iommu_ctx.19: context gfx3d1_user using bank 0
[ 0.303494] msm_iommu_ctx msm_iommu_ctx.20: context gfx3d1_priv using bank 1
[ 0.303799] msm_iommu_ctx msm_iommu_ctx.21: context vcap_vc using bank 0
[ 0.304074] msm_iommu_ctx msm_iommu_ctx.22: context vcap_vp using bank 1
[ 0.304349] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.305020] Bluetooth: Core ver 2.16
[ 0.305203] NET: Registered protocol family 31
[ 0.305325] Bluetooth: HCI device and connection manager initialized
[ 0.305478] Bluetooth: HCI socket layer initialized
[ 0.305569] Bluetooth: L2CAP socket layer initialized
[ 0.305966] Bluetooth: SCO socket layer initialized
[ 0.306363] cfg80211: Calling CRDA to update world regulatory domain
[ 0.306577] cfg80211: World regulatory domain updated:
[ 0.306668] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.306821] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 0.306912] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 0.307065] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 0.307248] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 0.307340] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 0.308103] earjack debugger probed
[ 0.309079] Switching to clocksource gp_timer
[ 0.347108] NET: Registered protocol family 2
[ 0.347474] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.348267] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.349641] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.350434] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.350618] TCP: reno registered
[ 0.350709] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350892] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.351350] NET: Registered protocol family 1
[ 0.351747] Trying to unpack rootfs image as initramfs...
[ 0.409949] Freeing initrd memory: 1124K
[ 0.411628] Detected 5 counters on the L2CC PMU.
[ 0.413734] pil_qdsp6v4 pil_qdsp6v4.0: using secure boot
[ 0.415473] pil_riva pil_riva: using secure boot
[ 0.418586] pil_dsps pil_dsps: using secure boot
[ 0.420173] pil_gss pil_gss: using secure boot
[ 0.422432] smd_channel_probe_worker: allocation table not initialized
[ 0.428506] msm_dsps driver version 4.03.
[ 0.430001] NET: Registered protocol family 27
[ 0.433053] lpass_fatal_init: lpass SSR driver init'ed.
[ 0.433297] wcnss_8960: module initialized
[ 0.433663] gss_8064_init: gss fatal driver init'ed.
[ 0.434304] acpuclk-8064 acpuclk-8064: SPEED BIN: 0
[ 0.434396] acpuclk-8064 acpuclk-8064: ACPU PVS: 3
[ 0.437051] acpuclk-8064 acpuclk-8064: CPU0: 12 frequencies supported
[ 0.437143] acpuclk-8064 acpuclk-8064: CPU1: 12 frequencies supported
[ 0.437326] acpuclk-8064 acpuclk-8064: CPU2: 12 frequencies supported
[ 0.437417] acpuclk-8064 acpuclk-8064: CPU3: 12 frequencies supported
[ 0.438028] kcal_ctrl_init
[ 0.438608] persistent_ram: no valid data in buffer (sig = 0x4e4f524d)
[ 0.439890] msm_rpm_log_probe: OK
[ 0.442820] mdm_modem_probe: registered mdm id 0
[ 0.443003] mdm_do_first_power_on:id 0: Powering on modem for the first time
[ 0.443247] mdm_pblrdy_change: mdm id 0: pbl ready:0
[ 0.478528] mdm_pblrdy_change: mdm id 0: pbl ready:1
[ 0.690523] usbcore: registered new interface driver hsic_sysmon
[ 0.691011] audit: initializing netlink socket (disabled)
[ 0.691164] type=2000 audit(0.690:1): initialized
[ 0.692690] highmem bounce pool size: 64 pages
[ 0.702945] fuse init (API version 7.18)
[ 0.703372] msgmni has been set to 1157
[ 0.707889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.708103] io scheduler noop registered
[ 0.708469] io scheduler deadline registered
[ 0.709018] io scheduler cfq registered (default)
[ 0.710209] lm3530 probed
[ 0.714115] mipi_dsi base phy_addr = 0x4700000 virt = 0xf1c00000
[ 0.714359] mmss_sfpb base phy_addr = 0x5700000,virt = 0xf00f8000
[ 0.715733] mipi_lgit_lcd_probe start
[ 0.715916] setting pdata->panel_info.fb_num to 3. type: 8
[ 0.728246] FrameBuffer[0] 768x1280 size=11796480 bytes is registered successfully!
[ 0.728582] load_565rle_image: Can not open /initlogo.rle
[ 0.730535] setting pdata->panel_info.fb_num to 1. type: 7
[ 0.731634] FrameBuffer[1] 1920x1080 size=0 bytes is registered successfully!
[ 0.731939] load_565rle_image: Can not open /initlogo.rle
[ 0.732458] mdp4_dtv_vsync_init: ndx=0
[ 0.732763] hdmi_msm hdmi_msm.1: external_common_state_create: sysfs group cf938a08
[ 0.732885] hdmi_msm hdmi_msm.1: hdmi_msm_config_hdcp_feature: HDCP Feature: Enabled
[ 0.733740] setting pdata->panel_info.fb_num to 1. type: 10
[ 0.734014] Inside writeback_driver_init
[ 0.734442] Inside writeback_probe
[ 0.735235] FrameBuffer[2] 1280x720 size=0 bytes is registered successfully!
[ 0.735540] load_565rle_image: Can not open /initlogo.rle
[ 0.737189]
[ 0.737189] msm_vidc_enc: Inside vid_enc_init()
[ 0.737677]
[ 0.737677] msm_vidc_enc: Inside vid_enc_vcd_init()
[ 0.738593] smux_init: unable to create log context
[ 0.739508] msm_serial_hs module loaded
[ 0.739874] msm_serial_hsl: detected port #0
[ 0.740119] msm_serial_hsl.0: ttyHSL0 at MMIO 0x16340000 (irq = 184) is a MSM
[ 0.740393] msm_serial_hsl: console setup on port #0
[ 0.740668] console [ttyHSL0] enabled
[ 0.741095] msm_serial_hsl: driver initialized
[ 0.742713] msm_rotator_probe: rotator_hw_revision=2
[ 0.746406] diagchar initialized now
[ 0.748054] kgsl kgsl-3d0: |kgsl_iommu_init| MMU type set for device is IOMMU
[ 0.758950] brd: module loaded
[ 0.763314] loop: module loaded
[ 0.765145] anx7808 init gpio
[ 0.799664] anx7808 dvdd is already on
[ 0.829818] sp_tx_hardware_poweron: anx7808 power on
[ 0.830764] sp_tx_chip_located: ANX7808 BA is found.
[ 0.832198] sp_tx_vbus_powerdown: 3.3V output disabled
[ 0.890065] sp_tx_hardware_powerdown: anx7808 power down
[ 0.890157] sp_tx_set_sys_state: SP_TX To System State:
[ 0.890340] sp_tx_set_sys_state: STATE_CABLE_PLUG
[ 0.890950] tabla2x-slim tabla2x-slim: Platform data from board file
[ 0.957485] wcd9xxx_check_codec_type: codec is tabla_codec
[ 0.957698] wcd9xxx_check_codec_type: Read codec idbytes & version
[ 0.957698] byte_0[00000002] byte_1[00000000] byte_2[00000000]
[ 0.957698] byte_3[00000001] version = 2
[ 0.960048] i2c-core: driver [tabla-i2c-core] using legacy suspend method
[ 0.960231] i2c-core: driver [tabla-i2c-core] using legacy resume method
[ 0.961727] bcm2079x-i2c 0-a1fa: bcm2079x_probe, probing bcm2079x driver flags = 10
[ 0.962307] bcm2079x-i2c 0-a1fa: requesting IRQ 317
[ 0.962643] bcm2079x-i2c 0-a1fa: bcm2079x_probe, probing bcm2079x driver exited successfully
[ 0.963863] SCSI Media Changer driver v0.25
[ 0.965725] tun: Universal TUN/TAP device driver, 1.6
[ 0.966061] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.966427] rmnet_init: BAM devices[8]
[ 0.991759] PPP generic driver version 2.4.2
[ 0.992308] PPP BSD Compression module registered
[ 0.992491] PPP Deflate Compression module registered
[ 0.993468] PPP MPPE Compression module registered
[ 0.993682] NET: Registered protocol family 24
[ 0.994079] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.994262] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.994811] wcnss_wlan probed in built-in mode
[ 0.996520] usbcore: registered new interface driver asix
[ 0.996795] usbcore: registered new interface driver cdc_ether
[ 0.997222] usbcore: registered new interface driver net1080
[ 0.997497] usbcore: registered new interface driver cdc_subset
[ 0.997924] usbcore: registered new interface driver zaurus
[ 0.998412] usbcore: registered new interface driver cdc_ncm
[ 0.998901] msm_otg msm_otg: msm_otg probe
[ 0.999145] msm_otg msm_otg: failed to get phy_clk
[ 0.999420] msm_otg msm_otg: OTG regs = f01f2000
[ 1.002868] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.016175] msm_hsic_host msm_hsic_host: Qualcomm EHCI Host Controller using HSIC
[ 1.016389] msm_hsic_host msm_hsic_host: new USB bus registered, assigned bus number 1
[ 1.039798] msm_hsic_host msm_hsic_host: irq 261, io mem 0x12510000
[ 1.060155] msm_hsic_host msm_hsic_host: USB 2.0 started, EHCI 1.00
[ 1.060582] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.060705] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.060857] usb usb1: Product: Qualcomm EHCI Host Controller using HSIC
[ 1.061040] usb usb1: Manufacturer: Linux 3.4.0-perf-gdffc258 ehci_hcd
[ 1.061132] usb usb1: SerialNumber: msm_hsic_host
[ 1.061773] hub 1-0:1.0: USB hub found
[ 1.061925] hub 1-0:1.0: 1 port detected
[ 1.063207] usbcore: registered new interface driver cdc_acm
[ 1.063390] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.063482] Initializing USB Mass Storage driver...
[ 1.063726] usbcore: registered new interface driver usb-storage
[ 1.063848] USB Mass Storage support registered.
[ 1.064031] usbcore: registered new interface driver ums-alauda
[ 1.064184] usbcore: registered new interface driver ums-cypress
[ 1.064397] usbcore: registered new interface driver ums-datafab
[ 1.064550] usbcore: registered new interface driver ums-freecom
[ 1.064764] usbcore: registered new interface driver ums-isd200
[ 1.064886] usbcore: registered new interface driver ums-jumpshot
[ 1.065099] usbcore: registered new interface driver ums-karma
[ 1.065344] usbcore: registered new interface driver ums-onetouch
[ 1.065466] usbcore: registered new interface driver ums-sddr09
[ 1.065679] usbcore: registered new interface driver ums-sddr55
[ 1.065832] usbcore: registered new interface driver ums-usbat
[ 1.066137] usbcore: registered new interface driver usbserial
[ 1.066229] usbserial: USB Serial Driver core
[ 1.066442] usbcore: registered new interface driver qc_csvt
[ 1.066564] USB Serial support registered for qc_csvt
[ 1.066717] usbcore: registered new interface driver usb_ehset_test
[ 1.066961] usbcore: registered new interface driver diag_bridge
[ 1.067358] usbcore: registered new interface driver mdm_bridge
[ 1.068274] usbcore: registered new interface driver ks_bridge
[ 1.068426] ksb_init: init done
[ 1.068792] msm_otg msm_otg: phy_reset: success
[ 1.069647] msm_hsusb msm_hsusb: [ci13xxx_start] hw_ep_max = 32
[ 1.070074] mbim_init: initialize 1 instances
[ 1.070288] mbim_init: Initialized 1 ports
[ 1.072455] rndis_qc_init: initialize rndis QC instance
[ 1.072943] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.073126] android_usb gadget: Number of LUNs=1
[ 1.073218] lun0: LUN: removable file: (no medium)
[ 1.073706] android_usb gadget: android_usb ready
[ 1.075324] input: keypad_8064 as /devices/platform/msm_ssbi.0/pm8921-core/pm8xxx-keypad/input/input1
[ 1.076270] [Touch D]touch enable
[ 1.280421] input: touch_dev as /devices/virtual/input/input2
[ 1.302182] [Touch] common[1] finger[17] flash[52] button[0]
[ 1.303403] [Touch] IC is 7020, H pattern, panel is G2, Firmware: E028.
[ 1.305478] [Touch] fw_rev[0:0] product_id[PLG137:PLG137] force_upgrade[0]
[ 1.305539] [Touch] Touch driver is initialized
[ 1.306149] [Touch] DO NOT UPDATE 7020 G2 H pattern FW-upgrade is not executed
[ 1.307034] using rtc device, pm8xxx_rtc, for alarms
[ 1.307248] rtc-pm8xxx rtc-pm8xxx: rtc core: registered pm8xxx_rtc as rtc0
[ 1.307889] i2c /dev entries driver
[ 1.308499] usbcore: registered new interface driver uvcvideo
[ 1.308591] USB Video Class driver (1.1.1)
[ 1.309934] __jrchoi: msm_sensor_init_module: E
[ 1.338226] msm_eeprom_probe probe_fail
[ 1.338684] msm_server_update_sensor_info mctl_node_name[0] = video1
[ 1.368014] msm_eeprom_probe probe_fail
[ 1.368472] msm_server_update_sensor_info mctl_node_name[1] = video3
[ 1.372592] msm_cam_server_request_irq IRQ Router hw is not present.
[ 1.373294] lm3559_init
[ 1.399816] pm8xxx_tm_probe: OK
[ 1.400335] usb 1-1: new high-speed USB device number 2 using msm_hsic_host
[ 1.401068] pm8xxx_tm_probe: OK
[ 1.403143] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 1.404425] cpuidle: using governor ladder
[ 1.404761] cpuidle: using governor menu
[ 1.405524] mmc0: SDCC Version: 0x0000001a
[ 1.407355] mmc0: bam physical base=0x12402000
[ 1.407538] mmc0: bam virtual base=0xf0334000
[ 1.407630] sps:BAM 0x12402000 is registered.
[ 1.407813] mmc0: BAM device registered. bam_handle=0xef01d400
[ 1.408148] sps:BAM 0x12402000 enabled: ver:0x5, number of pipes:6
[ 1.408728] mmc0: Qualcomm MSM SDCC-BAM at 0x0000000012402000 irq 130
[ 1.408942] mmc0: Qualcomm MSM SDCC-DML at 0x0000000012400800
[ 1.409156] mmc0: No card detect facilities available
[ 1.411017] mmc0: Qualcomm MSM SDCC-core at 0x0000000012400000 irq 136,0 dma -1 dmacrcri -1
[ 1.411200] mmc0: Controller capabilities: 0x0000039e
[ 1.411292] mmc0: 8 bit data mode enabled
[ 1.411475] mmc0: 4 bit data mode disabled
[ 1.411567] mmc0: polling status mode disabled
[ 1.411658] mmc0: MMC clock 400000 -> 96000000 Hz, PCLK 0 Hz
[ 1.411841] mmc0: Slot eject status = 0
[ 1.411933] mmc0: Power save feature enable = 1
[ 1.412116] mmc0: SPS-BAM data transfer mode available
[ 1.412849] usbcore: registered new interface driver usbhid
[ 1.413032] usbhid: USB HID core driver
[ 1.413917] ashmem: initialized
[ 1.414741] usbcore: registered new interface driver snd-usb-audio
[ 1.416450] tabla_probe
[ 1.417305] amp_enable: amp enable bypass(2)
[ 1.417427] amp_enable: AMP_EN is set to 0
[ 1.418586] msm_pcm_probe: dev name msm-voip-dsp
[ 1.419014] msm-dai-q6-mi2s msm-dai-q6-mi2s: msm_dai_q6_mi2s_platform_data_validation: playback sdline 0 capture sdline 8
[ 1.419197] msm-dai-q6-mi2s msm-dai-q6-mi2s: msm_dai_q6_mi2s_platform_data_validation: playback ch_max 0 capture ch_mx 8
[ 1.420570] msm_pcm_probe: dev name msm-pcm-dsp
[ 1.421028] msm_pcm_probe: dev name msm-multi-ch-pcm-dsp
[ 1.421516] msm_pcm_probe: dev name msm-lowlatency-pcm-dsp
[ 1.421608] adding pm_qos request in low latency driver
[ 1.421791] done adding pm_qos request in low latency driver
[ 1.422890] msm_compr_probe: dev name msm-compr-dsp
[ 1.423714] msm-pcm-lpa msm-pcm-lpa: msm_pcm_probe: dev name msm-pcm-lpa
[ 1.424843] msm8930_audio_init: Not the right machine type
[ 1.425026] msm_audio_init: Not the right machine type
[ 1.425118] msm_audio_init: Not APQ8064 in I2S mode
[ 1.472852] usb 1-1: New USB device found, idVendor=05c6, idProduct=9008
[ 1.473065] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.473401] usb 1-1: Product: QHSUSB__BULK
[ 1.473584] usb 1-1: Manufacturer: Qualcomm CDMA Technologies MSM
[ 1.545032] mmc0: new HS200 MMC card at address 0001
[ 1.546528] mmcblk0: mmc0:0001 016G92 14.6 GiB
[ 1.552601] Alternate GPT is invalid, using primary GPT.
[ 1.553059] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25
[ 1.557118] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
[ 1.558034] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
[ 1.558858] asoc: snd-soc-dummy-dai <-> CS-VOICE mapping ok
[ 1.559774] asoc: snd-soc-dummy-dai <-> VoIP mapping ok
[ 1.560537] asoc: snd-soc-dummy-dai <-> MultiMedia3 mapping ok
[ 1.561452] asoc: snd-soc-dummy-dai <-> SLIMBUS0_HOSTLESS mapping ok
[ 1.562246] asoc: snd-soc-dummy-dai <-> INT_FM_HOSTLESS mapping ok
[ 1.563039] asoc: msm-stub-rx <-> msm-dai-q6.241 mapping ok
[ 1.563741] asoc: msm-stub-tx <-> msm-dai-q6.240 mapping ok
[ 1.564626] asoc: snd-soc-dummy-dai <-> MultiMedia4 mapping ok
[ 1.565389] asoc: snd-soc-dummy-dai <-> AUXPCM_HOSTLESS mapping ok
[ 1.566244] asoc: snd-soc-dummy-dai <-> HDMI_HOSTLESS mapping ok
[ 1.567068] asoc: snd-soc-dummy-dai <-> VOICE_STUB mapping ok
[ 1.567953] asoc: snd-soc-dummy-dai <-> VoLTE mapping ok
[ 1.568869] asoc: snd-soc-dummy-dai <-> MultiMedia5 mapping ok
[ 1.570334] asoc: tabla_rx1 <-> msm-dai-q6.16384 mapping ok
[ 1.575186] asoc: tabla_tx1 <-> msm-dai-q6.16385 mapping ok
[ 1.575949] asoc: msm-stub-rx <-> msm-dai-q6.12288 mapping ok
[ 1.576590] asoc: msm-stub-tx <-> msm-dai-q6.12289 mapping ok
[ 1.577353] asoc: msm-stub-rx <-> msm-dai-q6.12292 mapping ok
[ 1.578086] asoc: msm-stub-tx <-> msm-dai-q6.12293 mapping ok
[ 1.578818] asoc: msm-stub-rx <-> msm-dai-q6-hdmi.8 mapping ok
[ 1.579459] asoc: msm-stub-rx <-> msm-dai-q6.224 mapping ok
[ 1.580344] asoc: msm-stub-tx <-> msm-dai-q6.225 mapping ok
[ 1.581077] asoc: msm-stub-rx <-> msm-dai-q6.2 mapping ok
[ 1.581809] asoc: msm-stub-tx <-> msm-dai-q6.3 mapping ok
[ 1.582481] asoc: tabla_rx2 <-> msm-dai-stub mapping ok
[ 1.583213] asoc: tabla_tx1 <-> msm-dai-stub mapping ok
[ 1.583976] asoc: msm-stub-rx <-> msm-dai-q6.16386 mapping ok
[ 1.584739] asoc: msm-stub-tx <-> msm-dai-q6.16387 mapping ok
[ 1.585594] asoc: tabla_tx2 <-> msm-dai-q6.16389 mapping ok
[ 1.586357] asoc: tabla_rx3 <-> msm-dai-q6.16388 mapping ok
[ 1.587089] asoc: msm-stub-rx <-> msm-dai-q6.16392 mapping ok
[ 1.587913] asoc: msm-stub-tx <-> msm-dai-q6.16393 mapping ok
[ 1.588554] asoc: tabla_tx3 <-> msm-dai-stub mapping ok
[ 1.589256] asoc: msm-stub-rx <-> msm-dai-q6.16390 mapping ok
[ 1.590050] asoc: msm-stub-tx <-> msm-dai-q6.16391 mapping ok
[ 1.592797] input: apq8064-tabla-snd-card Button Jack as /devices/platform/soc-audio.0/sound/card0/input3
[ 1.593254] input: apq8064-tabla-snd-card Headset Jack as /devices/platform/soc-audio.0/sound/card0/input4
[ 1.597283] u32 classifier
[ 1.597466] Actions configured
[ 1.597588] Netfilter messages via NETLINK v0.30.
[ 1.597772] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.598748] ctnetlink v0.93: registering with nfnetlink.
[ 1.598901] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.599084] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.599572] xt_time: kernel timezone is -0000
[ 1.600335] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.600793] arp_tables: (C) 2002 David S. Miller
[ 1.601068] TCP: cubic registered
[ 1.601159] Initializing XFRM netlink socket
[ 1.601983] NET: Registered protocol family 10
[ 1.606317] Mobile IPv6
[ 1.606470] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.606836] IPv6 over IPv4 tunneling driver
[ 1.607721] NET: Registered protocol family 17
[ 1.607874] NET: Registered protocol family 15
[ 1.608301] Bluetooth: RFCOMM TTY layer initialized
[ 1.608545] Bluetooth: RFCOMM socket layer initialized
[ 1.608728] Bluetooth: RFCOMM ver 1.11
[ 1.609095] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.609278] Bluetooth: BNEP filters: protocol multicast
[ 1.609613] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.609980] L2TP core driver, V2.0
[ 1.610376] PPPoL2TP kernel driver, V2.0
[ 1.612238] VFP support v0.3: implementor 51 architecture 64 part 6f variant 0 rev 2
[ 1.612818] Registering SWP/SWPB emulation handler
[ 1.613032] clock_late_init: Removing enables held for handed-off clocks
[ 1.624172] MSM Watchdog Initialized
[ 1.634488] registered taskstats version 1
[ 1.635098] rtc-pm8xxx rtc-pm8xxx: setting system clock to 2016-01-06 17:15:39 UTC (1452100539)
[ 1.636044] read_ocv_trim: program rev reg is 0x54
[ 1.636105] read_ocv_trim: trim reg is 0x42
[ 1.636227] read_ocv_trim: trim delta is 7
[ 1.636288] pm8921_is_usb_chg_plugged_in: called before init
[ 1.638608] pm8921_is_usb_chg_plugged_in: called before init
[ 1.639798] pm8921_is_usb_chg_plugged_in: called before init
[ 1.640012] ocv_ir_compensation: comp ocv = 3730403, ocv = 3724074, ibatt_ua = 28900, rbatt_mohm = 219
[ 1.640225] calculate_unusable_charge_uah: Using shutdown_iavg_ma = 500 in all samples
[ 1.640286] pm8921_is_batfet_closed: called before init
[ 1.670044] pm8921_is_usb_chg_plugged_in: called before init
[ 1.670105] adjust_soc: ibat_ua = 334300, vbat_uv = 3633719, soc = 30, batt_temp=278
[ 1.672394] pm8921_get_batt_state: called before init
[ 1.672485] pm8921_bms_probe: OK battery_capacity_at_boot=30 volt = 3638493 ocv = 3774666
[ 1.673523] power_supply usb: driver failed to report `present' property: 4294967274
[ 1.673676] power_supply usb: driver failed to report `present' property: 4294967274
[ 1.673828] power_supply pm8921-dc: driver failed to report `present' property: 4294967274
[ 1.673950] power_supply pm8921-dc: driver failed to report `present' property: 4294967274
[ 1.675293] pm8921_get_batt_state: called before init
[ 1.677552] pm8921_get_batt_state: called before init
[ 1.696261] wlc: bq51051b_wlc_probe: probe
[ 1.696322] wlc: bq51051b_wlc_hw_init: hw_init
[ 1.696566] power_supply wireless: driver failed to report `present' property: 4294967274
[ 1.696749] power_supply wireless: driver failed to report `present' property: 4294967274
[ 1.696749] [Touch] CHARGER = 1
[ 1.697054] batt_temp_ctrl_init
[ 1.697207] batt_temp_ctrl_probe
[ 1.697848] android_vibrator: default amplitude 88
[ 1.697970] android vibrator probed
[ 1.698153] fsa8008 init
[ 1.698397] fsa8008 probe
[ 1.698947] input: hs_detect as /devices/virtual/input/input5
[ 1.699221] ALSA device list:
[ 1.699282] #0: apq8064-tabla-snd-card
[ 1.700198] Freeing init memory: 1036K
[ 1.810163] msm_otg msm_otg: Avail curr from USB = 500
[ 1.810315] msm_otg msm_otg: current: 0 -> 500 (mA)
[ 1.810437] pm_power_set_property_usb: usb_target_ma 0
[ 1.813551] msm_hsusb msm_hsusb: CI13XXX_CONTROLLER_RESET_EVENT received
[ 1.896627] type=1403 audit(1452100539.750:2): policy loaded auid=4294967295 ses=4294967295
[ 1.902029] type=1404 audit(1452100539.760:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 1.950129] unplug_check_worker: Stopping Unplug Check Worker USB == 500mA
[ 2.159194] init: could not import file '/init.recovery.mako.rc' from '/init.rc'
[ 2.161696] healthd: wakealarm_init: timerfd_create failed
[ 2.338501] healthd: battery l=30 v=3751 t=27.8 h=2 st=2 c=-19 chg=u
[ 2.397070] healthd: battery l=30 v=3753 t=27.8 h=2 st=2 c=-19 chg=u
[ 2.513840] healthd: battery l=30 v=3773 t=27.8 h=2 st=2 c=-56 chg=u
[ 2.520799] healthd: battery l=30 v=3754 t=27.8 h=2 st=2 c=-112 chg=u
[ 2.526232] healthd: battery l=30 v=3752 t=27.8 h=2 st=2 c=11 chg=u
[ 2.674469] enable_store: android_usb: already disabled
[ 2.675019] init: Unable to open persistent property directory /data/property errno: 2
[ 2.693178] EXT4-fs (mmcblk0p22): recovery complete
[ 2.693941] EXT4-fs (mmcblk0p22): mounted filesystem with ordered data mode. Opts:
[ 2.770425] mipi_dsi_controller_cfg: DSI status=8 failed
[ 2.770456] mipi_dsi_panel_power: mipi lcd function started status = 1
[ 2.770486] ext_dsv_load: Failed to create debugfs directory
[ 2.772501] mipi_dsi_panel_power : reset start.
[ 2.793071] mipi_lgit_lcd_on started
[ 2.814130] mipi_lgit_lcd_on finished
[ 2.834060] lm3530_backlight_off, on: 1
[ 2.880482] mipi_lgit_lcd_off started
[ 3.010468] mipi_lgit_lcd_off finished
[ 3.010499] mipi_dsi_panel_power: mipi lcd function started status = 0
[ 3.015504] lm3530_backlight_off, on: 0
[ 3.015901] mipi_dsi_panel_power: mipi lcd function started status = 1
[ 3.017488] mipi_dsi_panel_power : reset start.
[ 3.038577] mipi_lgit_lcd_on started
[ 3.090737] mipi_lgit_lcd_on finished
[ 3.097970] lm3530_backlight_on, ++ lm3530_backlight_on
[ 12.055089] healthd: battery l=30 v=3803 t=27.6 h=2 st=2 c=-173 chg=u
[ 21.631008] resout_irq_handler PMIC Initiated shutdown
[ 21.631069] PMIC Initiated shutdown cpu_power_off cpu=0
[ 21.631069] PMIC Initiated shutdown cpu_power_off cpu=1
[ 21.631069] PMIC Initiated shutdown cpu_power_off cpu=2
[ 21.631100] PMIC Initiated shutdown cpu_power_off cpu=3
[ 21.631374] Powering off the SoC
[ 21.631497] Calling scm to disable arbiter
[ 21.631588] SCM returned even when asked to busy loop rc=-4
[ 21.631649] waiting on pmic to shut msm down
No errors detected
Any ideas?
