Just a heads up for anyone wanting to use the combo of a Nokia DT-910 and a Spigen case on their N5 (I tested it with both the Neo Hybrid and Slim Armor) the added thickness around the edge of the phone from either Spigen case I tested will stand the phone too high up on the DT-910 where it misses the "sweet spot" for charging. It won't work standing upside down either, I tried that. Take the case off and just use the bare caseless phone and it charges perfect on the DT-910. If you hold it sideways on the DT-910 it charges fine through either Spigen case so it's not the thickness of the back of the cases since they've been proven to work with the flat DT-900 Nokia it's just that the case thickness around the phones edge stands it up too tall and just out of range to charge on the vertical DT-910.
So, anyone need a DT-910 since it won't work for me with the Spigen Slim Armor I like best on the phone? :'(
To be clear, this is the DT-910
The flat DT-900 is fine with any case.
