**update 2**
so i received the cd slot mount and it's a huge disappointment. i cannot recommend this product due to the weak magnetic force. With a name like Magneto, you'd think the magnetic charge is strong enough to hold a nexus 5. nope, it's soooo weak. at first, i thought maybe it had to do with the skin i have on. so i removed it and it didn't make a big enough difference. oh, and it definitely cannot hold the nexus 7. i am returning this product.
**update**
alright guys, i placed the order for the magnetos universal cd slot mount (same as infinitiapp but cheaper) yesterday and it's been delivered to my house already. As soon as i get home tonight, i'll rip that sucker open and do a quick little review.
so i can't wait for the indiegogo's magnetic/wireless charging dock i ordered. i need something for now.
i'm stuck between two choices and i'd appreciate some input from people with car mounts (i never had one). both are magnetic but they are mounted differently.
choice 1:
InfiniApps Slyde CD Slot Mount for Smartphones
Amazon.com: InfiniApps Slyde CD Slot Mount for Smartphones, Cradle-less Universal cell phone holder with Quick-snap technology, magnetic cell phone mount: Cell Phones & Accessories
pro: this one is pretty cool because you utilize the cd slot and the way my car's dash is setup, the location is ideal.
possible con: just by looking at the pics, i can tell the neck of this mount is the weak point. i plan on using this mount for both my n5 and n7 so i'm not sure if it can handle the weight of my n7.
choice 2:
Nite Ize STCK-11-R8 Steelie Car Mount Kit for Cellphones
Amazon.com: Nite Ize STCK-11-R8 Steelie Car Mount Kit for Cellphones - Retail Packaging: Cell Phones & Accessories
pro: takes up very little space and it looks so clean compared to all the other car mounts.
possible con: not sure if it'll work with my n7 due to nite ize's design.
anybody have experience with either mounts? better yet, if you know something that's even better, let me know.
ps
it turns out infinityapp (choice #1) is just a generic design which is sold under many alias'. i just found another one (same design just different name/logo) for $17. it's called
Magnetos Universal CD Slot Magnetic Cradle-less Smartphone Car Mount.
**update**
choice 1:
choice 2:
ps
