1. Giovanni Lauria's Avatar
    Hi all,
    all of a sudden my nexus 5 lost the wifi.
    Getting "Activating..." but nothing happened.
    Thought it was a bug I went back to a newer version 5.1.1.
    Same issue.
    Downgraded to 4.4.4 and 4.4 same issue.
    Is there some "Permanent" Config file where info on the wifi adapter are stored across Android Releases and installations ?
    06-18-2015 07:24 AM
  2. srkmagnus's Avatar
    Hi all,
    Same issue.
    Welcome to the forums! I'm not sure that you resolved this problem, but if not, try resetting your wireless router. If that doesn't work then try clearing cache through recovery. Be sure to clear cache only, not data.
    07-13-2015 12:31 PM
  3. drucassam's Avatar
    It sounds to me that you might have a hardware issue instead of a software issue which is a lot worse. Considering you switched to different Android versions and the same error occurred.
    07-31-2015 09:58 PM
  1. How do I choose a gesture for a certain action on my S6?
    Last Post: 06-18-2015, 10:58 AM
  2. What if my screen is not working and also its just where I left?
    Last Post: 06-18-2015, 08:05 AM
  3. Why do my photos show up on my husband's phone?
    Last Post: 06-18-2015, 07:31 AM
  4. How to recover phone from deleted android operating system?
    Last Post: 06-18-2015, 06:16 AM
  5. Replies: 0
    Last Post: 06-18-2015, 06:06 AM
