1. Bxilal's Avatar
    Hello everyone, I have a nexus 5 (rooted, unlocked bootloader, custom rom&kernel)
    My battery drops from ( for example) 16 to 13 in 1m, what's the wrong with my phone! Is it a software of hardware problem??
    BTW, I flashed the factory image, different roms&kernels, I try to calibration Battery and it didn't work!
    Here's some screenshots
    I hope there's someone who know what can I do to fix that
    Thanks.
    Attached Thumbnails Unbelievable Battery Drain Problem (N5)-29517.jpg   Unbelievable Battery Drain Problem (N5)-29518.jpg   Unbelievable Battery Drain Problem (N5)-29516.jpg
    06-28-2015 05:00 PM
  2. Rukbat's Avatar
    1. Try to never let the battery get below 40% (unless you like buying new batteries).
    2. It looks like a hardware problem - a leaky capacitor, or a partial short, on the motherboard. Or it could just be a battery at the end of its life. Six months of draining a lithium battery to 0 can completely kill it. It has to go to the shop for diagnosis.
    06-28-2015 06:21 PM
  1. Android system battery drain
    By Evanhaller4 in forum Samsung Galaxy S6
    Last Post: 10-16-2018, 08:27 AM
  2. is battery performance the same on 32, 64 and 128 gb versions?
    By aapold in forum Samsung Galaxy S6 edge
    Last Post: 06-28-2015, 10:00 PM
  3. Replies: 2
    Last Post: 06-28-2015, 08:25 PM
  4. best extended battery case s6
    By rickg3669 in forum Samsung Galaxy S6
    Last Post: 06-28-2015, 06:09 PM
