1. Peter Dirken's Avatar
    Here is the thing : my phone upgraded to Marshmallow, but after that only the infamous Google logo came up.
    The phone is not rooted, it is not unlocked and USB debugging has not been enabled (why would I).
    I first tried the hard reset, factory wipe, but it gets an error message : E:failed to mount /cache (Invalid argument)
    I tried to flash the stock image via ADB via sideload, but since the boot loader is locked and the USB debugging and developer options have not been enabled I am stuck.
    Any thoughts? TWRP could be an option?
    02-04-2016 03:11 PM
  2. Ricky Moore2's Avatar
    Did you ever get your phone fixed, I'm having the same problem
    Attached Thumbnails Nexus 5 : E:failed to mount /cache (Invalid argument)-37009.jpg
    02-20-2016 03:14 PM
  3. Peter Dirken's Avatar
    No I got no response and my phone is still stuck. All the forums say you need to turn on USB debugging and then connect it to a PC, but of course if you have this message, you can't get into the phone in the first place. Nobody seems to suggest anything useful......what have you tried?
    02-20-2016 04:58 PM
  4. alvintimothyjr's Avatar
    02-29-2016 02:09 PM
  5. jetbadger's Avatar
    A bit late with this response, but I have just had the same problem with my old nexus 5.
    In desperation, I simply tried repeatedly doing a factory reset and on about the third attempt it successfully formatted all three mounts (/system, /data and /cache)!
    08-06-2018 05:06 PM
  1. I want my alarm clock app to stay on all night.
    Last Post: 02-25-2016, 01:33 AM
  2. How do I remove the cover to get to the battery?
    Last Post: 02-04-2016, 03:15 PM
  3. Google nexus 4
    Last Post: 02-04-2016, 02:53 PM
  4. Wallpaper Resets to Default
    Last Post: 02-04-2016, 01:56 PM
  5. Replies: 1
    Last Post: 02-04-2016, 01:48 PM
