If that's true, why would the 6P charge faster than the 5X?
It does?
USB Type-C is only a connector spec though.
But the 5X and 6P are USB 2.0 devices.
So.. yeah. I'm still confused.
Is Fast Charge on the 5X and 6P Quick Charge 2.0 compatible?
The 5X ships with this charger: USB Type-C 15W (5V/3A) charger.
Curious to see charging tests.
And here is a link to something called "Quick Charge 3.0". Could this be what the new standard will come to be known as? http://www.amazon.com/gp/product/B015ZJKWFS
Read the article below, but basically QuickCharge was a mechanism to cheat the maximum power limits allowed by legacy USB standards. The cheat involved adding a hardware handshake between the charger and the device. Apple has theirs, and Qualcomm has QuickCharge.
USB type C changes the power standards such that similar performance to QuickCharge is available with options for much higher performance for larger devices such as laptops. USB "C" allows for something like 3A at 5V or 15W. Google for whatever chose not to incorporate QuickCharge as a transitory legacy technology until more USB-C chargers are on the market. The negative is that you need to go run out and purchase new chargers for your Nexus 5X or 6P.
Well, since there is this stupid policy for newbs to post links, Google for this phrase. The article is on phonenews.
Intel, Qualcomm, and Why Your Nexus 5X & 6P Can’t QuickCharge with USB-C
And to be clear, the 5V at 3A is the standard USB-C power delivery with the PD option going up to 100W (for laptops and such). Per the article, QuickCharge allowed for 18W. There may be other standards that go higher. Don't know much about those.
It's a quite sensible policy if you think about it . . .
Just because Google promotes only USB Type-C charging does not mean that other fast charging methods aren't also supported. I've verified (using a USB Type-C adapter) that my new Nexus 5X will fast charge on a Ventev Quick Charge 2.0 car charger and on a PowerGen 12W wall charger (using a USB Type-C adapter). The phone does say "Charging" instead of "Charging rapidly", but the actual charging rate is still fast, comparable in speed to the included USB Type-C LG charger. (In the image below, PowerGen on the left, LG on the right, both charging at about 1% per minute, roughly the same as my old Nexus 5.)
