Verizon customers are always wary — for good reason — when looking at unlocked phones. That's no different with the new Nexus 6P and Nexus 5X, which of course technically support Verizon's radio bands but aren't officially supported by the carrier.
Well, we're happy to report that both new Nexuses do work on the Verizon network, with one expected caveat — you're going to need a SIM that's already set up and ready to go on the carrier. As is standard operating procedure for the carrier with unlocked phones, Verizon isn't going to start up service for you and hand over a fresh SIM if you walk in the door with a Nexus 6P or 5X.
But if you already have an active line and are just ordering a new phone to put it in, you'll be good to go for the most part. There's no guarantee of the best network quality, extra features or customer support — but the phones are compatible with the network and you'll be able to pop in a SIM and go.
Can I just plug the sim card from my Moto X (2013) into the Nexus 5x?
Received my 32gb Carbon 5x today.
I have a Verizon prepaid account but my old phone uses a micro sim. At the Verizon retail store they could not activate a nano size with the Nexus 5x IMEI and refused to activate a nano size for the old phone IMEI so that I could just pop it in and try it on the Nexus. Went home and cut the sim to nano size using a template I found online and it is working great. Just for the heck of it, I bought a Verizon nano sim on Ebay that I will try to activate with the old IMEI. Might fit better than my little hack job. If not, the trimmed version appears to be fine. No Google Fi early access in my area so stuck with Verizon for now....
I've never used the same SIM on different phones, do you literally and simply just move it from one phone to the other (assuming same size and it's currently activated, that part I understand) and the new phone is ready to rock?
So far the only Verizon issue I've had is the data widget doesn't work. Of course I'm likely switching to T-Mobile soon so not a big deal. Everything else works fine after I moved my SIM card over from my Moto X 2014.
what are you using for visual voicemail? the VZW Vis Voicemail app for Nexus isn't getting past the authorizing screen... I assume I need to wait until these phones are in there system?
I use Google Voice for voicemail and to be fair no one ever leaves me messages anyway so it doesn't really matter for me anyway.
