1. danielcj's Avatar
    So I noticed my 5x doesn't doze on WiFi at home but does on WiFi at work. My router is several years old and is only G no N or AC. Anyone with older routers also noticing this. I would think that with Marshmallow it should be backwards compatible.
    11-05-2015 12:25 PM
  2. eaccentsac's Avatar
    Weird. I wouldn't think that the phone would care what type of connection so long as it was connected to WiFi.
    Sure you don't have any other location based services set up?
    11-05-2015 01:14 PM
  3. danielcj's Avatar
    Location services are the same whether I'm at home or work so that shouldn't be a problem. I just don't get the same flat line that I see when doze kicks in. It's a steady decline at home.
    11-05-2015 01:53 PM
  4. eaccentsac's Avatar
    I would test in Safe Mode while at home to see if it is an app issue.
    11-05-2015 02:12 PM
  5. Zendroid1's Avatar
    Is your house on a severe slant by chance?
    11-05-2015 03:07 PM
  6. danielcj's Avatar
    Phone doesn't doze unless horizontal?
    11-05-2015 09:22 PM
  7. eaccentsac's Avatar
    Hmmm, never tested that.
    11-05-2015 09:26 PM
  1. How do I bypass the Google account on an LG Leon?
    By AC Question in forum LG Leon
    Last Post: 07-19-2016, 01:46 AM
  2. I cannot get Wifi or Bluetooth enabled on my Tab Pro 12.2
    Last Post: 11-05-2015, 05:16 PM
  3. Replies: 1
    Last Post: 11-05-2015, 05:07 PM
  4. Replies: 1
    Last Post: 11-05-2015, 11:58 AM
  5. How do I lock the icons on my Note 4?
    By Micherie in forum General Help and How To
    Last Post: 11-05-2015, 11:51 AM
