1. chris20nyy's Avatar
    Chrome is always the #1 or #2 battery draw. I disabled chrome, went with chrome beta, same thing.
    For instance my screen is 28%, chrome is 25%. Yesterday chrome was 32%, screen was 29%. Anyone else experiencing this?
    11-06-2015 01:36 AM
  2. jonebk12's Avatar
    How much time are you actually spending surfing the web on chrome when you use the phone?
    11-06-2015 05:27 AM
  3. eaccentsac's Avatar
    Chrome is always #2 even w brightness set to around 20%.
    Have you tried wiping the cache partition? Un-Install chrome updates and then reinstall? Wipe chrome app data?
    11-06-2015 05:29 AM
  4. chris20nyy's Avatar
    I've disabled chrome, which uninstalls chrome updates. Wiping the cache partition is pointless as it was doing this out of the box without even being signed into an account.
    I spend a fair amount of time using chrome. But it shouldn't be consuming as much battery as the display. Chrome was never more than 12-15% of the battery on any of my other devices. On the moto x, if the display was 28-35%, chrome was 12-15%. Used under the same circumstances...
    11-06-2015 11:39 AM
  5. N4Newbie's Avatar
    Maybe it's not Chrome using more, but the display using less...
    11-07-2015 08:52 PM
  6. chris20nyy's Avatar
    No, definitely not the case...
    11-07-2015 10:35 PM
  7. MartinMPL's Avatar
    Chrome Beta seems better for me.
    11-08-2015 02:17 AM
  8. N4Newbie's Avatar
    How can you be so certain? You are only comparing relative percentages with little else to go on ...
    I'm just curious.
    11-08-2015 06:44 AM
  9. klau25's Avatar
    one thing I noticed chrome is really slow sometimes. anyone else experience this?
    11-08-2015 07:28 AM
  10. MartinMPL's Avatar
    Yes, another reason I use Beta. It's less laggy in scrolling too.
    11-08-2015 09:47 AM
  11. chris20nyy's Avatar
    I'm just curious.
    Because it's now happening on my nexus 7 2013 after the marshmallow update. My moto X 2014 still on 5.1 chrome uses 1/3 of what the screen uses. I don't think the 5x has a display that much more efficient.
    11-08-2015 11:29 AM
  12. exodite's Avatar
    I just wanted to say I'm having the exact same problem. Right now after a couple hours off the charger, where I visited one website, put the phone to sleep and not touched it since, Chrome is at 8% battery usage and the screen is at 1%...did you happen to find a way to fix it?
    Like you I also have a moto x 2014 on lollipop 5.1 and chrome would use a fraction of the battery. And if it's also happening on your nexus 7 with marshmallow...a chrome + marshmallow battery issue perhaps?
    11-20-2015 02:08 PM
  13. chris20nyy's Avatar
    I actually haven't found a solution, but I've sent the 5x back. I can't justify keeping it when for all intents and purposes I find the moto x 2014 to be a better device. It was my first non nexus device in years, now I'm finding it hard to go back.
    11-21-2015 09:17 PM
  14. raqball's Avatar
    Interesting... I hated my Moto X (2014) Pure Edition and sent it back right before the return period was up.. The Amoled screen on it was absolute garbage! (on mine at least) and the whites were very pink..
    At that time i went back to my N5 but have since went to the 5X.
    11-22-2015 06:25 PM
  15. chris20nyy's Avatar
    My nexus 5x had a pink hue in comparison to my MotoX and Nexus 7. I didn't mind it so much due to all the **** yellow displays out there...
    But head to head the Moto X 2014 display crushes the 5x. 5x looks washed out, dull compared to the Moto X. Forget comparing blacks. But colors are so much more lively and vibrant on the Moto X. It was the first thing my gf pointed out when I got it, and my mom who uses a nexus 6 said the same thing.
    I'm not big on 'natural' looking displays. I'd much rather have a slightly over saturated punchy amoled than a washed out LCD.
    11-23-2015 04:08 AM
  16. chris20nyy's Avatar
    Chrome extensively uses cpu resources that's why it drags your battery.
    Well...obviously.
    The question is why does it do that on the Nexus 5x, but not on the Moto X 2014? My Nexus 7 is on the OTA marshmallow and also doesn't suffer from Chrome eating so much battery.
    11-23-2015 04:10 AM
  17. exodite's Avatar
    Even if Chrome DID use a lot of CPU resources while using it...fine, I could fathom that. But it doesn't make sense how it eats up so much battery when the phone is sleeping. It's a browser. Chrome will be at 1% battery usage when I unplug it and use it for a couple minutes, I'll let the phone sleep for a couple hours, check back, it's up to 5% or so. What exactly could it be doing to kill the battery while the phone is asleep? Pinging location? Searching for wifi? Background services?
    11-24-2015 01:25 PM
  18. Equinsu ocha's Avatar
    No.
    11-24-2015 04:07 PM
  19. chris20nyy's Avatar
    No.
    Welp, you're wrong.
    11-25-2015 02:54 AM
  20. Equinsu ocha's Avatar
    Welp, you're wrong.
    Really? How so?
    11-25-2015 03:29 AM
  21. chris20nyy's Avatar
    really? How so?
    i just wanted to say i'm having the exact same problem.
    post #12. Next.
    11-25-2015 03:33 AM
  22. Equinsu ocha's Avatar
    post #12 is not me. You and him might have that "problem" but I don't, and I didn't speak for him, or anyone else.
    11-25-2015 03:36 AM
  23. chris20nyy's Avatar
    You did when you quoted my question "Anyone else experiencing this problem?", and you answered " No". A proper response would be "I'm not".
    11-25-2015 03:45 AM
  24. Equinsu ocha's Avatar
    Your question was asked improperly and assumes I, or anyone else, has ESP and can speak for anyone but themselves, is mistaken, because no one has any idea of the exact status of every single person with a 5X.
    Unless you really do believe everyone can read everyone elses minds? If not then your question was asked improperly.
    11-26-2015 12:23 AM
  25. chris20nyy's Avatar
    I'm speaking to a forum of individuals. Say I'm surveying a group of individuals who witnessed a crime where the perp fled. I would ask "did anyone see which direction he went?". If someone saw, they would answer. I wouldn't expect the 15 others to individually answer just " No".
    So my question was asked properly. You're understanding of how a question is asked in a group dynamic is what's improper.
    11-28-2015 01:15 PM
  1. Switched to Android, does my battery look healthy? Please help
    By MotherAyahuasca in forum Samsung Galaxy S5
    Last Post: 11-06-2015, 02:51 PM
  2. My battery life is bad after lollipop
    By Kenbz in forum Moto X
    Last Post: 11-06-2015, 01:08 PM
  3. My battery life sucks after lollipop
    By Kenbz in forum Hardware Hideaway
    Last Post: 11-06-2015, 01:07 PM
  4. Security warning Battery Virus
    Last Post: 11-06-2015, 12:03 AM
