1. .jacob's Avatar
    I "upgraded" to the 5X from a 2014 Moto X as soon as it came out and have been disappointed right from the beginning but lately my phone has become so slow that it's simply unusable. Using imprint to unlock the phone takes 5-7 seconds, scrolling articles in the NYT app or photos on Instragram are absurdly choppy and lagging, pulling down notifications from the top bar can take 4-5 seconds to appear, double tapping the power button to conjure up the camera is a 4+ second wait. Once when using Maps for directions I received a phone call and the phone rang but the Phone app itself couldn't load in time for me actually answer the call. On top of all of this (or maybe because of it) the batter life is atrocious. The phone is an utter joke.
    I suspect that there's some app on my phone that works fine in Lollipop but does not play nice in Marshmallow. Does anyone know how I can troubleshoot this without factory wiping my phone and reinstalling everything app by app? There's not an obvious culprit from the memory usage screen:
    My 5X is so slow it is not usable. Thinking of returning unless someone can help.-screenshot_20151202-110128.jpg
    Thanks.
    12-02-2015 01:03 PM
  2. eaccentsac's Avatar
    Thanks.
    I'm sure that you are right otherwise we'd all be complaining of horrendous lag.
    How many apps are we talking about?
    How often do you power down?
    Have you ever wiped the cache partition using the Recovery menu?
    12-02-2015 01:14 PM
  3. .jacob's Avatar
    I have 101 apps including the system / default apps. I reboot maybe 1x/week. I've never booted in the Recovery menu but I just Googled it and gave it a shot. Cache partition has been cleared.
    12-02-2015 01:31 PM
  4. eaccentsac's Avatar
    Well, at this point we won't be messing with the system apps.
    You could test in Safe Mode and see how the device performs. If it is normal, then you definitely know that one or more of the 3rd party apps are causing your lag issue.
    How many 3rd party apps do you have?
    12-02-2015 01:34 PM
  5. bpe4's Avatar
    Step 1: Factory Reset - Is it quick again? Move on to Step 2. (If it's still dog-slow, RMA it)
    Step 2: Add apps one by one, checking performance as you go.
    Step 3: Remove the app that causes the phone to take a dump.
    12-02-2015 01:35 PM
  6. eaccentsac's Avatar
    +1
    I would add that you can do an FDR after disabling the auto restore feature in settings>>>backup and reset. If you don't disable that feature, you run the risk of re-loading the same configuration that is currently problematic.
    Also, for some, adding apps one by one is beyond painful. For those folks, consider adding in small batches (3-5 apps at a time?). Document what apps get added and when. When your device destabilizes, it makes retracing your steps (back to a stable state) much easier.
    Good luck!
    aysiu likes this.
    12-02-2015 01:52 PM
  7. PhiPsi32's Avatar
    Facebook has been reported as a problem app. Otherwise, return the phone and find something that works out of the box.
    12-08-2015 08:12 PM
  1. How do I replace a Nexus 5x rear camera glass cover?
    By AC Question in forum Nexus 5X
    Last Post: 12-02-2015, 05:57 PM
  2. why sms is deposited into my email folder
    Last Post: 12-02-2015, 03:50 PM
  3. Replies: 1
    Last Post: 12-02-2015, 03:49 PM
  4. Replies: 1
    Last Post: 12-02-2015, 03:48 PM
  5. Replies: 0
    Last Post: 12-02-2015, 12:40 PM
