1. King Kong Bundy's Avatar
    Hello... As the title says, I'm unable to send or receive MMS messages on my Nexus 5X. My provider is Verizon. I noticed it when my group messaging stopped working in the default messaging app. It used to work perfectly fine up until about a week ago. Does anyone have some thoughts on what night be causing this?
    12-10-2015 11:39 AM
  2. benhaube's Avatar
    Does SMS messaging and data still work? Unfortunately Verizon won't be very useful because they don't officially support the 5X.
    I would first try removing the sim card, reinserting it, and doing a reboot of the phone.
    Also, I would try other messaging apps such as hangouts, and see if the issue persists.
    The Nexus 5X has full capability on the Verizon network, so I'm sure there is some sort of software error going on. However, like I stated above, Verizon does not officially support the 5X. This makes it near impossible to get any help on their end.
    Posted via the Android Central app on my Nexus 5X with Project Fi
    12-10-2015 11:45 AM
  3. eaccentsac's Avatar
    Have you received the update to 6.0.1? See this article Android 6.0.1 Fixes The Annoying Failed MMS Bug In Marshmallow.
    12-10-2015 12:00 PM
  4. Kamin's Avatar
    Awesome! I'm on T-Mobile and I've also been experiencing the MMS issue. I got the 6.0.1 update today and I'll be installing when I get home.
    12-10-2015 02:19 PM
  5. landale's Avatar
    Check your APN settings. I was having all kinds of issues in the past week with delayed MMS messages. I went into the APN setting and added http://mms.vtext.com/servlets/mms as the MMSC, the MMS port as 80 and changed the APN type to internet + mms. Within a few minutes all of my mssing MMS messages came through and I haven't had an issue since.
    12-10-2015 08:39 PM
  6. King Kong Bundy's Avatar
    Ahhhhh...I have received the 6.0.1 update but I haven't installed it yet.
    I will also try the APN settings. Thanks for the responses! Hopefully one of these work.
    12-10-2015 09:01 PM
  7. strawbee's Avatar
    the APN settings will definitely work. I stared at my phone for ten minutes waiting for MMS to download but they kept running into errors.in full 4G LTE coverage. Like wtf?
    Filled in the APN settings, rebooted, and voila!
    12-10-2015 09:35 PM
  8. landale's Avatar
    Yeah, I wish I had known these when I first got the phone. Glad to help others.
    12-10-2015 09:43 PM
  1. Replies: 5
    Last Post: 12-15-2015, 08:52 PM
  2. Replies: 2
    Last Post: 12-15-2015, 03:02 AM
  3. Replies: 3
    Last Post: 12-10-2015, 06:00 PM
  4. my galaxy s4 won't receive texts from iPhone users?
    Last Post: 12-10-2015, 12:45 PM
  5. HDR+ ON vs Auto HDR+?
    By puch96 in forum Nexus 6P
    Last Post: 12-10-2015, 11:46 AM
