A
AC Question
any app on nexus 5X support OTG? if yes which app should be used? can storage on nexus 5X can be increased through any app?
Welcome to Android Central!
OTG will work on 5x.
ES File Explorer is a compatible app.
You can not use an app to give you more storage over all. You can use a file explore app to delete any unneeded files, documents, and pictures. You can use cloud services such as Google Drive and like cloud based apps to free up available memory on your device. Google Photo is a good place for pictures and videos.
Hi dumpedduce! I don't know why but ES File Explorer can't see my flash drive type-c.
The USB OTG File Manager for Nexus is working...but I hate this app.
What can I do?
