Originally Posted by
West Coast Wolverine 've been going running with my 5X connected via bluetooth to Silicon Volcano headphones. The headphones sound great with one horrible exception. During the first 5-10 minutes, the sound breaks up constantly. I'll hear a quick beep and then the sound start skipping. It'll work for anywhere from a couple seconds to, maybe 30 seconds and then beep and start skipping again. After it finally stops doing this, it works beautifully. This has been happening while I'm listening to Google Music in download only mode. Unless I'm mistaken, this means the problem is not due to buffering because the music is already on my phone rather than streaming live.
When it first started happening, it would happen in the house and on the first part of my run. Now it seems to be working fine in the house, but literally the moment I stepped out the door to walk my dog tonight, it started roughly 10 minutes of breaking up. My wi-fi connects 10-20 yards from my front door (and I was in download only mode) so I don't understand why stepping outside my door would matter, but I'm just trying to give as much info as possible. I have no idea if this is a problem with the headphones or my Nexus 5X.
Does anyone have any ideas what is causing this? Is anyone else having a similar issue with their 5X?
Thanks!
Have you tried clearing/erasing the pairing info (on both the phone and the BT headset) and re-pair?
Alternatively, try turning WiFi off to see if things improve. WiFi and BT have been known to interfere with each other as they both run on 2.4GHz
I have two sets of Motorola BT headsets and a cheapie BT set from Amazon (can't remember the brand off hand....). None of them exhibit this issue.
