1. enigma1944's Avatar
    I've set the sound keys a dozen times and for what reason they don't hold the position I placed them I don't know.
    I thought setting them locks them
    It also happens when I turn the phone off
    Any answers
    Thanks
    02-22-2016 02:35 PM
  2. Javier P's Avatar
    Which sound settings do you mean? In your keyboard or the ones under settings - sound & notifications - other sounds? Do you have any third party app that could be causing a conflict with the stock settings?
    02-22-2016 02:40 PM
  3. eaccentsac's Avatar
    Good question. Perhaps OP should test in safe mode?
    02-22-2016 02:41 PM
  4. enigma1944's Avatar
    I have no third party
    On the phone under sound & notifications I move that little balls to the right
    I just did it again after an incoming was barely audible
    02-22-2016 03:36 PM
  5. Javier P's Avatar
    Do you use a case? Is it possible that the volume down key could be pressed by accident while in your pockets? Does the same happen if you leave the phone unattended on a flat surface?
    02-23-2016 07:20 AM
  1. Unable to download on Google Play Store | Error 963 and 907
    By McFlurzzXD in forum Samsung Galaxy S4 Google Edition
    Last Post: 03-01-2016, 09:11 AM
  2. Vulkan API in Galaxy S7 and Adreno 4xx
    By VermaEklavya in forum Samsung Galaxy S7
    Last Post: 02-22-2016, 03:22 PM
  3. Replies: 2
    Last Post: 02-22-2016, 03:05 PM
  4. Replies: 2
    Last Post: 02-22-2016, 02:03 PM
  5. Replies: 0
    Last Post: 02-22-2016, 12:36 PM
