1. AC Question's Avatar
    I have nexus 4 16 gb , for 3 years now, and I am about to but nexus 5x 32gb
    and I 'd like to know before hand how to transfer complete data from nexus 4 to nexux 5x
    thanks,
    Benzi
    03-09-2016 06:27 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Since you have a Nexus 4, all of your contacts should be in your Google account (rather than the local Phone account, which Nexus devices don't have). On your computer browser, go to contacts.google.com--if all of your contacts are there, then they will sync automatically with the new 5X once you log in there with your Google account.
    All of your Google app data (like Calendar, Google Drive, etc.) should be synced to your Google cloud, and will therefore sync automatically with the new phone. But 3rd party apps may or may not backup data to your Google account--it's usually difficult to tell which ones do. If individual 3rd party app data is important to you, you might consider using Helium to back it up, then restore it to the new phone.
    libra89 likes this.
    03-09-2016 06:59 PM
  3. mr_nobody's Avatar
    If you are rooted (both devices) use titanium backup for app settings/data. Otherwise you can try helium but it's pretty flakey honestly.
    /sdcard contents can be copied between devices via computer.
    B. Diddy likes this.
    03-10-2016 12:10 PM
  1. galaxy s6 stuck in ODIN mode without me trying to reboot
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-09-2016, 07:18 PM
  2. Replies: 3
    Last Post: 03-09-2016, 07:24 AM
  3. Replies: 1
    Last Post: 03-09-2016, 07:04 AM
  4. move music from google play to media player for syncing
    Last Post: 03-09-2016, 06:34 AM
  5. MP3 file splits when added to Samsung
    By Steve48Golf in forum Ask a Question
    Last Post: 03-09-2016, 06:28 AM
