How badly do you want this feature?
I found this over at XDA... You have to root and load a custom kernel, but it's possible.
I don't think this was originally made to work with Nougat, so you might want to look around for an update or head over to XDA to confirm this actually works with Nougat FIRST.
I feel I should also add here that you probably should not attempt this if you are not comfortable with rooting, flashing or anything in the instructions. You can make your phone unusable and this sort of thing typically voids warranties
With all that said... Here's a video...
https://youtu.be/vOJzVlS2PMg
