08-31-2018 04:03 PM
55 123
tools
  1. Simmz1987's Avatar
    Hey guys. I had the same issue this week and the only thing I thought it had to be was the battery needed replacing. I was right. Swapped them today and all is fine. I admit I didn't take care of it charging wise and that must of lead to its death. Froze randomly and only half booted again and again. Till it wouldn't charge or boot at all. It's easy and cheap to fix. Just need a screwdriver and be able to take the back off. YouTube it there's a few videos on it. The battery was only £10 but had to wait nearly a week to get here.
    It fixed it tho, guaranteed it's your battery. They aren't built to last forever. Especially when its charging/discharging incorrectly.
    08-16-2017 08:49 PM
  2. Verminhater's Avatar
    Good morning all!
    A friend and have had the same happen to us and we have both had the same results and have been running fine ever since. So I'm on vacation and I plugged in my phone to the usb A to C cable (didn't have the USB C charger in the truck) go into the store to get a pack of butts and DOA when I come back 5 minutes later....can't boot to recovery or see it charge...nothing just a brick. Now mind you this happened to a friend as well, same exact thing. FYI both phones are LG Nexus 5X on Google Project Fi. I left the phones unplugged (this happened @5 pm) overnight til 8 am, as it turns out the battery is still draining even though you really only have a brick. DO NOT plug in your phone during this time, be patienX, the battery must bottom out. I touched the power button in the morning and saw a flashing red light at he bottom of the screen (the other 5X previously the red light was already blinking by that time). Immediately plugged in the power supply and started the phone. Battery is charging from DOA as we speak. No return or customer service headache so far even with the first 5X. I did survive with Google Hangouts in my down time taking calls and sms on my Chromebook (should work with any tablet or laptop) so it wasn't that painful. Hope this helps someone out!!
    08-18-2017 07:59 AM
  3. jmazz889's Avatar
    Good morning all!
    This worked (somehow)! The same type of problem had happened to me 6 months ago and I sent in to LG and they replaced the motherboard. I was afraid I would have to do the same, but I let the phone sit overnight then hit the power button in the morning and saw the red light. Plugged in the charger and turned it on, working fine.
    Does anyone know if this means the battery is on it's way out?
    10-01-2017 07:52 AM
  4. Harald Brandner's Avatar
    Well, my Nexus 5X would not turn on, when charger plugged in nothing happened. I tried all what is
    mentioned on the internet.
    Finally I found my problem: The internal battery has a mini plug, when I pressed hard on the plug, the phone
    worked again and still is. plug in the charger while you do that.
    You could try to press hard on the back cover where the sim slot is, or better remove back cover - find instructions on Google for that.
    Hope that helps.
    GSDer likes this.
    07-22-2018 06:25 PM
  5. OrpCowboy's Avatar
    HOW I SOLVED IT
    Hi all,
    We had the exact same thing here.
    My wife and I both have a Nexus 5X.
    A couple of weeks ago my wife's phone was experiencing this boot loop issue (on-off-on-off..).
    Eventually it dropped dead.
    Now, a couple of weeks later, my phone started to show the same behaviour.
    This is how I solved it:
    Note: during this procedure you'll browse through a couple of screens that are very un-smartphone like and kind off techie’ish. No worries, it's supposed to be safe and according to some websites no personal data or app data will be altered or deleted. I applied the procedure to my phone and after 24 h it is still working with no apparent data loss
    - during an "on"-moment, 1) shut down your phone using the power button
    (perform the first step as soon as you notice your phone is showing the reported behaviour; the "on"-moments will become less frequent and last shorter with time)
    - after your phone shut down, 2) press the power button and volume down button simultaneously for about 8-10 sec. Your phone will start in "Fast boot" mode (SCREEN 1).
    (do not be alarmed by the interface you'll see. As stated before get ready for a couple of un-smartphone like techie’ish screens. On your screen you’ll see an android character lying on his back with his belly opened; right above the android character you ‘ll see a big arrow with “Start” written in it)
    - Browse through the menu with the volume up/down button. Options are:
    • Start
    • Power Off
    • Recovery Mode
    • Restart boot loader
    - 3) Choose “Recovery mode” and 4) press the power button
    (will appear in the following order: “Google” > a black screen with an android character lying on his back (belly open) and the text “No command (SCREEN 2)”
    - 5) Press the power button and the volume up button simultaneously
    (You’ll end up at another techie’ish screen (SCREEN 3): the first line (orange bold type) reads “Android Recovery”)
    - Use the volume-down button to 6) scroll down to “Wipe cache partition”
    (Yep. That is exactly what you are going to do. If you’re in blind panic now, take a deep breath and read the Note at the start of this message; or google around and find solace in some of the posts on the subject)
    - 7) Press the power button on your phone (you can do it)
    (The third techie’ish screen will appear where they’ll try to scare the **** out of you. (SCREEN 4) Remember: you are in Brave & Bold mode now; think “can’t touch this”)
    - Use the volume-down button and 8) choose “Yes”
    - 9) Press the power button (don’t listen to your girl/friend)
    (After 0,5-3 sec you’ll return to SCREEN 3; at the bottom of SCREEN 3 you’ll see three lines of text: the third line reads: “Cache wipe complete”)
    - Still in SCREEN 3 use the volume-down button to 10) scroll to “Power off”
    - 11) Press the power button and your phone will shut down
    - 12) Restart your phone the normal way
    - You’re done.
    Let me know how it went (orp.cowboy@gmail.com)
    Hope this helps.
    Cheers
    Hi All,
    I have an issue with my Nexus 5X showing no signs of life. A few days ago I noticed when I woke up that the phone had restarted randomly in the middle of the night as it was on the "enter your PIN to start Android" screen. Not a big deal - but never had this happen before. The phone was charged in and battery at 100%. Good thing I didn't have any alarms set!
    Then yesterday, while plugged in and charged about 80%, the phone completely froze. I've had this phone freeze before, but only while running an intense application or something with high load, never while just sitting idle. I waited about 30 seconds just to see if it would recover, and then held down power to restart it. Then, when it restarted, it seemed to get stuck on a boot loop where it kept showing the Google splash screen, then going black for a second and then repeat. It did this about 5 or so times, until I unplugged the power cord, and it booted after this (not sure if the unplug had anything to do with it).
    After it started, I was thinking how odd that was and that I hope it's not messed. I plugged it back in so it could finish charging. I checked back about 5 minutes later, to find it completely frozen again just on the home screen. I unplugged the power so I could sit down with it (why does it come with such a short cord? ), and when I did that the screen went black. That was the last time it ever worked.
    Since then I've tried everything from the usual steps including:
    -leaving it alone for a few hours, not connected to anything
    -plugging it into the wall charger and waiting
    -plugging it into a computer and waiting
    -every combination of holding just power, and holding power and volume down in the above combinations
    -removing the back cover and disconnecting the battery for a few minutes, then reconnecting
    The only sign of anything I got was, after disconnecting and reconnecting the battery, when I plugged it into the computer, and pressed and held power, the red led blinked about once every 10-15 seconds so long as I held power. Then I plugged it into the wall, and the red led blinked about 1 time per second for 5 seconds, and then that was it. Never any battery icon or anything on the screen.
    I contacted Google, who put me on the line with LG. I was told the phone needs to go into a servicing, and because it is a year and one week old, I would need to pay them for the repairs. Of course I don't want to do this, especially considering I've owned multiple LG phones (including the completely terrible Nexus 4 - an experience so bad it made me not buy the 5, and almost not buy the 5X) over the years and spend lots of money on Google products (mainly G Suite for work). Although I believe the warranty issue is fully with LG, as they make the phone?
    Does anyone have any ideas as to what might be wrong? Since it always seems to be charging related could it be a battery issue? Would a broken battery prevent the phone from turning on even if plugged in? I would like to point out this phone doesn't and has never had any other damage, and physically appears to be in excellent condition.
    Thanks!
    08-31-2018 04:03 PM
55 123
  1. Can't change background settings on chromecasts?
    By Gangrel in forum Google Chromecast
    Last Post: 11-07-2016, 11:49 AM
  2. Storage full, Not enough space on internal storage.
    Last Post: 11-06-2016, 08:58 PM
  3. My phone stuck on boot screen recovery mode and freezing
    Last Post: 11-06-2016, 08:33 PM
  4. Can't play music on Samsung 4?
    Last Post: 11-06-2016, 07:59 PM
  5. Replies: 0
    Last Post: 11-06-2016, 07:55 PM
