1. Exalted's Avatar
    I would like to know if I can use my Nexus 5X in Europe. I read some articles about this but not so good info. Some say if I change the SIM card and others the opposite. I will be Going to Portugal, Spain, France and Italy. Thanks
    02-04-2018 08:31 AM
  2. frankras's Avatar
    As Long its the GSM version you have, then there will be no problems.
    Frank
    02-04-2018 11:49 PM
  3. Exalted's Avatar
    OK thanks
    02-05-2018 06:52 AM
  4. anon(123856)'s Avatar
    I used a 5X in Italy (Tuscany) and had great coverage using a Vodaphone sim. The sim cost me 25 Euro and I got a bunch of minutes and 4 GB of data. Can't help you with the other countries.
    02-05-2018 03:51 PM
  5. Javier P's Avatar
    +1 for Vodafone. You can check it first, but I think they have some cheap prepaid plans that include free roaming in most European countries.
    anon(123856) likes this.
    02-05-2018 03:57 PM
  6. swebb's Avatar
    I had no problems using it for text and talk when I was in Portugal a couple years ago. Was on T-Mobile at the time. Data was a bit unreliable for anything data intensive, but email worked well.
    02-06-2018 09:51 AM
  7. rhea's Avatar
    OP, don't know if you're interested or what your needs are, but I use google fi when traveling to Europe. I only ever use the data (mostly for navigation/bus travel, etc), but for $30. or less, it's been an easy solution for multi-country travels. If there should be others traveling with you, Fi offers free data-only sims for other GSM phones. Both work off the one account.
    02-07-2018 06:21 AM
  1. Microphone does not work when I put my headset in
    Last Post: 02-06-2018, 01:38 AM
  2. How to see our all contact after delete all contact in contact list?
    Last Post: 02-04-2018, 09:49 AM
  3. Problem with simultaneously connection in game (NavyField Mobile)
    Last Post: 02-04-2018, 08:01 AM
  4. Unable to locate app.data in Android
  5. Battery used by cell radio
    Last Post: 02-04-2018, 05:13 AM
