1. wsl543's Avatar
    Hi,
    My Nexus 5x (android 8.1) has really annoying issue. Ringtone volume decreases after couple of seconds automatically. The same issue is present when turning on loudspeaker during call - loud and clear but after 2 seconds it goes 50% lower volume.
    Recovery mode and factory reset did nothing. Is it hardware problem ?
    06-21-2018 09:02 AM
  2. GSDer's Avatar
    What happens if you open the Volume controls and just watch them for a few seconds? Do you see them move on their own?
    Is it only the Phone volume that does this and not the Media volume? If that's the case then it's likely not a hardware problem.
    Does it happen in Safe mode?
    Do you have any Bluetooth devices connected? If so remove them all and reboot your phone.
    06-22-2018 02:05 AM
  3. wsl543's Avatar
    it's ok when ringtone volume is set mid strength. It's present when I crank it up. So it seems like weird speaker protection built in android 8.1
    Media volume is also affected, loudspeaker during calls also which is most annoying.
    Youtube video under chrome is loud as hell and nothing happens
    No bluetooth devices, no headphones used
    06-23-2018 09:18 AM
  1. Volume jumps up and down on its own; media pauses itself
    By Android Central Question in forum Samsung Galaxy Note 4
    Last Post: 08-10-2018, 12:35 PM
  2. Just purchased a nexus 7 (2013 new in the box.
    Last Post: 06-20-2018, 05:40 PM
  3. Automatic icon for downloaded apps
    By dj9281 in forum Samsung Galaxy S9 & S9+
    Last Post: 06-20-2018, 01:08 PM
  4. Volume jumps up and down on its own; media pauses itself
    Last Post: 06-20-2018, 06:20 AM
  5. Turn off Google voice typing from Automatic
    Last Post: 06-20-2018, 03:17 AM
