1. nethunter321's Avatar
    Hi, I accidentally bricked my Nexus 5X. I was in TWRP and I restarted without an OS. Now it stays on the Google screen. Won't boot. No TWRP or Recovery. Those don't start. I have a new Nexus 6P. That works. I'd like to continue Unbricking my 5X. I tried the LGUP Flash tool. It shows the Google screen. It doesn't show the "unlocked" symbol. That's good. I had it unlocked before it bricked. So the LGUP can see my Nexus. Nothing on the Nexus Root Toolkit. I've tried flashing Stock and creating a Recovery. Still won't boot past Google screen. I read that I can press Up Volume and Power. Now I can boot into Download Mode. Not sure how to use it. I was trying that with the LGUP tool. Still won't boot. Next, I found a program called Miracle Box. I am learning to use it. My question is, what Pins (pinouts) should I use with Miracle Box? I have the OEM cable. How do I scan and find the correct pins? Also, Wipe Dalvik works on Miracle Box. So I'm guessing it CAN see it. No other options work. I tried flashing stock etc...It won't connect to the phone. So what Pins should I use so Miracle Box can connect to my phone? On my OEM cable? Please reply. Thanks
    04-20-2020 09:49 AM
  2. mustang7757's Avatar
    If it won't connect to the phone you won't be able flash nothing.
    04-20-2020 11:55 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I moved this to the Nexus 5X Rooting/Hacks forum for more specific traffic.
    04-20-2020 01:07 PM
  4. nethunter321's Avatar
    Thanks for your replies. I know I can't flash anything without the phone being connected. Dalvik connects fine but not the rest. So how do I get it connected? Does anyone know the correct Pins to use with Miracle Box?
    04-20-2020 01:56 PM
  5. mustang7757's Avatar
    Best place to find that information XDA forums
    04-20-2020 01:58 PM
  6. nethunter321's Avatar
    I will try XDA and report back if I get it working.
    mustang7757 likes this.
    04-20-2020 02:05 PM
  7. mustang7757's Avatar
    Ok thank you
    04-20-2020 02:05 PM
  1. installing the main cable on tab a
    Last Post: 04-17-2020, 05:23 AM
  2. print to asus router RT-AC88U from google fi phone Nexus 5X oreo 8.1.0
    By telecomtom in forum General Help and How To
    Last Post: 04-14-2020, 01:24 PM
  3. print to asus router RT-AC88U from google fi phone Nexus 5X oreo 8.1.0
    By telecomtom in forum New to the Forums? Introduce Yourself Here!
    Last Post: 04-14-2020, 12:59 PM
  4. Help needed to restore my Google Nexus 7 to a working state.
    By Android Central Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-09-2020, 12:26 PM
  5. Help needed to restore my Google Nexus 7 to a working state.
    Last Post: 04-09-2020, 11:50 AM
