1. SaltyBrine's Avatar
    I am considering getting a wireless charger for my Nexus 6. Is Qi or Powermat safe for the phone? I have heard of phone batteries swelling in some cases. Any recommendations would be appreciated.
    06-12-2015 09:13 PM
  2. berdinkerdickle's Avatar
    There's probably a few threads in the 'Nexus 6 Accessories' forums.
    Here's one related thread:
    http://forums.androidcentral.com/sho...d.php?t=499695
    Crest4 likes this.
    06-12-2015 09:28 PM
  3. tech_fan's Avatar
    I love my TYLT. Its nice because I do not have to mess with aligning it with the back to get it charged. Also, I leave the case on the phone and the phone does not get hot. Also, when I take it off charge in the morning it is at 100% battery.
    RonW3 likes this.
    06-12-2015 09:36 PM
  4. Clocks's Avatar
    Choe stadium qi charger works great
    06-12-2015 10:01 PM
  5. Crest4's Avatar
    I just ordered an Anker Qi charger hopefully it will be here tomorrow.
    06-17-2015 07:39 PM
  6. bluefalcon13's Avatar
    I noticed something different with the behavior of the N6 vs N5 for the same chargers (two I own, both cheap ones). The N6 will 'disconnect' from the charger once full, while the N5 would stay connected. The lights on my chargers actually switch from green to red when its full. Phone stays at 100% though. Think its a feature to protect the battery mostly.
    Sent from my Nexus 6 using Tapatalk
    Crest4 likes this.
    06-19-2015 11:46 AM
  7. Crest4's Avatar
    Got the Anker today and it works just as advertised and I was able to use my old Samsung charger.
    I assume that the wireless will charge more like a traditional charger and not the turbo speed that I am not used to.
    06-19-2015 07:28 PM
  8. bluefalcon13's Avatar
    It'll be slower than a normal charger, roughly 1a depending on qi charger and power supply. Due to how it charges the phone, it will also generate more heat than a regular charger that provides the same current.
    Crest4 likes this.
    06-19-2015 11:58 PM
  9. Crest4's Avatar
    Thanks, that's what I figured about the charging speed. I really like how thin the charging pad is really takes up no space at all.
    06-20-2015 07:21 AM
  10. james491225's Avatar
    i really want to know
    07-14-2015 03:57 AM
  11. TacoKingYo's Avatar
    To answer the question that you asked that was only indirectly answered, get a Qi charger. Powermat chargers do NOT work with Nexus phones. They use different technology and therefore are not compatible with each other
    kct1975 likes this.
    10-12-2015 03:33 PM
  12. Mike-Mike's Avatar
    Got one at home and one at work. TYLT is the only way to go
    10-12-2015 11:45 PM
  13. RDamon Salvatore's Avatar
    Wireless charger?
    Did it works well and steady?
    Because many of chargers have lots of problem.
    10-14-2015 05:29 AM
  14. TacoKingYo's Avatar
    But so expensive....
    10-16-2015 03:30 PM
  15. YAYTech's Avatar
    11-30-2015 06:06 PM
  16. 84181227's Avatar
    SaltyBrine, I ordered wireless efficiency's iPhone 6S wireless charger and receiver case for my wife's iPhone as I use the GN6. However, I find myself using it for my Nexus6 more than my wife uses it for her iPhone.
    It comes with a well constructed case for the iPhone which you need for the wireless charging pad to work with your iPhone. I can use it for my N6 as well. The pad itself looks very cool. It's made out of transparent strong glass looking plastic I'm guessing. During the day, the charger gives out a nice led light pattern as it charges and at night it dims it automatically so it doesn't bother you.
    All in all, a must have for iPhone users who are deprived of native wireless charging and also a great and cool gadget to have for all your other Qi enabled devices.
    12-08-2015 03:08 AM
  17. Q115115's Avatar
    Has anyone done any tests to see if quick charge using wireless has the same speed as quick charge with cable?
    12-16-2015 07:18 PM
  18. 541rrhse's Avatar
    Agreed.
    They are on sale from time to time $35-$45 ?? or something?
    12-29-2015 04:10 PM
  19. Eric The Duke's Avatar
    I have an Ikea nightstand with built in wireless charging and it works great! Obviously it charges slower than using the charger that came in the box but I usually charge over night so I doesn't really matter.
    01-02-2016 11:12 PM
  20. yankeesusa's Avatar
    I found that the newest wireless charger from Samsung is the best. It has a built in fan that keeps unit cool and phone barely gets hot while charging.
    01-06-2016 08:35 PM
  1. LG G4 Wireless Qi Charging
    By merlec92 in forum LG G4
    Last Post: 07-14-2016, 03:45 PM
  2. How long should I first charge my S6 Edge for?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 06-13-2015, 02:40 AM
  3. Replies: 1
    Last Post: 06-13-2015, 02:36 AM
  4. Is Google Liable for excess data?
    Last Post: 06-12-2015, 09:30 PM
  5. Wireless Charger not charging to 100%
    By mcefalu in forum Samsung Galaxy S6
    Last Post: 06-12-2015, 08:07 PM
