1. Ricky Gonzalez2's Avatar
    I have downloaded the Android N and want to sideload it. Has anyone done this yet? If so do I need to do a factory reset? How is it working for you?
    Thanks for the help!!!
    04-17-2016 05:59 AM
  2. LittleRedDot3's Avatar
    I would suggest running the sideload through Wuggs Nexus Toolkit, just to avoid any goofs and to have step by step instructions and details, like what to wipe. I did it last night and I will tell you to TAKE OFF and pin, password, or pattern for unlocking the device or you will be restoring androids due to bootloops.
    02-03-2017 02:11 PM
  1. Android Emulator for Windows 10
    By taviyo in forum General Help and How To
    Last Post: 06-23-2016, 03:27 AM
  2. Why can't android file be deleted in sdcard..
    By myyumi11 in forum Ask a Question
    Last Post: 04-17-2016, 09:38 AM
  3. Replies: 1
    Last Post: 04-17-2016, 05:27 AM
  4. how to cancel software update on android when it in process
    Last Post: 04-17-2016, 04:31 AM
  5. Bluestacks 1.x 2.x Review - Best Android emulator for win 10?
    Last Post: 04-17-2016, 03:57 AM
