1. robh2's Avatar
    EDIT: I finally found out the cables that I have that work are by UNU. They say they are approved for the Nexus 5X and 6P phones and so far work great all around. I have ordered more.
    I looked, but did not see this specific issue.
    I have multiple cables that I have purchased locally and they work great in wall and car chargers, but no name on them (EDIT: Found a name on them and they are by UNU, I could not see the name before in the dark car). I have purchased cables two seperate times, different models of cables from Aukey and they were mulitpacks so I had multiple to test. Both orders and all 12 cables total failed to work with any of my 4 car chargers. All different models, yet my unknown brand of cables work great.
    Who makes a good flexable cable that works with a car charger? I would prefer a multipack as they are cheaper. I need 3 and 6 foot lengths.
    Thank you.
    11-02-2016 07:14 PM
  2. B. Diddy's Avatar
    This is the one I use, which has the Benson Leung seal of approval: https://www.amazon.com/review/RGGBHI...cUvbUpU5543468
    Belkin also has a cable compatible with USB-A 3.1, but I'm not sure if Benson has approved that one.
    robh2 likes this.
    11-03-2016 12:20 PM
  3. Blurr26's Avatar
    Thank you.
    Have you checked out monoprice.com? Not sure if they have the cables you need, but worth checking out. They've been my goto source for cables of all kinds for years...
    11-07-2016 05:56 PM
  4. robh2's Avatar
    I have not. Thank you. I will check them out.
    12-22-2016 10:27 AM
  1. Google assistant works on T-Mobile variant with Bootloader Unlock and Root
    By tourbound129 in forum LG V20 Rooting, ROMs, & Hacks
    Last Post: 08-12-2017, 06:13 AM
  2. 7.1.1 crashing my 6p
    By Tomster88 in forum Nexus 6P
    Last Post: 12-20-2016, 01:51 AM
  3. Forgot my password for my Samsung s4
    Last Post: 11-04-2016, 09:12 AM
  4. Replies: 6
    Last Post: 11-02-2016, 09:25 PM
