1. thisissonice's Avatar
    I was showering and when I went out to dry myself some drops of water came on my phone and probably one on my speaker. What should I do and should I be worried?
    11-07-2017 04:52 PM
  2. SpookDroid's Avatar
    If it was only a few droplets you shouldn't be worried. If you want to be on the safe side (super paranoid), turn it off, leave it out to dry (in rice if you're REALLY worried) and then perhaps use compressed air in the speaker (short burst). Power back on and be on your way.
    11-07-2017 05:14 PM
  3. LeoRex's Avatar
    The speaker... Hmm... The tricky thing about water is surface tension. Water likes to squeak it's way between cracks. I'd let it dry out and you are probably fine. Speakers have a lot of boys for water to stick on and not let it pass into the inside of the phone.
    Water directly into the 3.5mm port, charging port and holes around the buttons are usually the bigger concern.
    11-14-2017 05:13 PM
  1. SafetyNet Check Fails on Recently Unrooted XT1644
    By mel2000 in forum Moto G4 Plus
    Last Post: 11-10-2017, 10:30 PM
  2. Replies: 1
    Last Post: 11-07-2017, 11:12 PM
  3. Replies: 1
    Last Post: 11-07-2017, 11:11 PM
  4. Why has my photo gallery become a folder?
    Last Post: 11-07-2017, 11:08 PM
  5. People on recvg end getting double texts from me
    Last Post: 11-07-2017, 04:32 PM
