1. AC Question's Avatar
    Considering getting the Nexus 6p, I like a lot of the features that it has. What accessories does it come with, does it come with a stylus?
    09-29-2015 10:50 PM
  2. Aquila's Avatar
    No.
  3. Aquila's Avatar
    No.
    09-29-2015 11:36 PM
  4. calicocat2010's Avatar
    Only the Note series have Stylus.
    09-29-2015 11:55 PM
  5. LezCronut's Avatar
    Nope. No stylus.
    09-30-2015 08:49 AM
  6. anon(5506951)'s Avatar
    Marshmallow apparently comes with stylus support via Bluetooth, so you could buy a stylus and use it with the 6P if you wanted.
    09-30-2015 09:02 AM
  7. fatboy97's Avatar
    No stylus, but it does come with the following:
    • SIM tool
    • USB Type-C 15W (5V/3A) charger
    • USB Type-C to USB Type-C cable
    • USB Type-C to USB Standard-A plug cable
    • And then mostly Paperwork
    09-30-2015 09:17 AM
  8. calicocat2010's Avatar
    If you are concerned for a stylus, get a Galaxy Note series.
    09-30-2015 09:18 AM
  9. Trym Bjerkvik's Avatar
    It comes with the fast charger right?
    09-30-2015 05:29 PM
  1. Can I get the Nexus 5x on AT&T?
    By AC Question in forum Nexus 5X
    Last Post: 10-03-2015, 06:51 AM
  2. Replies: 5
    Last Post: 09-30-2015, 12:32 PM
  3. Nexus 6 vs Note 5?
    By jsk108 in forum Ask a Question
    Last Post: 09-30-2015, 03:45 AM
  4. How is the battery on the Nexus 5x?
    Last Post: 09-29-2015, 11:37 PM
