How does fingerprint unlock work on 6P and 5X?
maxburn
973
Do you have to hit the power button in addition to the fingerprint scanner or is the scanner also a button? Or is it just always waiting for you to touch it?
Shadnic
475
35
28
In another thread (or maybe a hands on, I can't remember), I saw someone say that you do not need to hit the power button. The fingerprint scanner will wake the phone all on its own.
jdot104
439
7
Based on what the hands-on videos have said, it should work with just a touch. If you've seen the OnePlus 2's fingerprint scanner, it works the same way. It's not a clickable button, but there's no need to wake the phone first.
maxburn
973
Interesting, sounds like the scanner is active all the time. Should make for a pretty natural gesture taking it out of the pocket.
mchockeyvette27
1,539
It is always active. Just tap it and it will wake/unlock at the same time. I wonder if there's any settings to control its actions, however.
Paul Nevin
How well is the scanner going to work with a case? I see cases online that say they are for either the 6 or the 6P...I'd assume those would cover the scanner and can't really be for both....
Zendroid1
Trusted Member
Aug 22, 2011
2,087
6
I'd assume they have a cutout for the scanner.
Might be a bit more difficult to access but will work.
fatboy97
4,820
891
The 6 and 6P are different sizes. I don't think the scanner will work if it's covered up.
****EDIT: The 6 has the curved back and the 6P has a flat back... even if they were exactly the same size, which I seriously doubt, but I did not check... a 5.7" screen on the 6P is not the same as a 6" screen on the 6.
fatboy97
4,820
891
How?
Dimensions
Nexus 6: 159.3 x 83 x 10.1 mm (6.27 x 3.27 x 0.40 in)
Nexus 6P: 159.3 x 77.8 x 7.3 mm (6.27 x 3.06 x 0.29 in)
Would anyone really want a case that was not built for your device?
Zehata
3
Most likely China cheap cases companies who thought that Nexus goes with the Apple naming system. Ie 6 has same size as 6s so they thought that n6 is the same as n6p
Adamd1169
107
Most likely the op misread the case description and it didn't say it worked with 2 different sized phones. Or the item description was wrong. Either way the cases aren't gonna be compatible with both phones.
knowledge is power
